Hello everyone,
I have another network address here that I would like to record:
https://s6.hopslan.com/orfx11/tracks-v1a1/mono.m3u8?token=3a4267a9cdcb3c724cdaea66960b...953-1727009153
For a limited time.
Which program? Does it work with yt-dlp?
Many thanks,
Heiko
Results 1 to 14 of 14
streamlink is a good choice, especially since your stream doesn't use DRM. Works nice with the parameter --hls-duration
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
yt-dlp -f 0 https://s6.hopslan.com/orfx11/tracks-v1a1/mono.m3u8?token=3a4267a9cdcb3c724cdaea66960badffe3149e3c-9bfc70c82ddc5c55fcb06d525c7e97de-1727019953-1727009153
Thank you very much.
Now I just need to limit the recording to a certain time. Can I do that with yt-dlp?
Or is it better to use streamlink?
Best regards
Heiko -
I can use -f to specify the format, but what does -f 0 mean?
Best regards
Heiko -
I have another .m3u8 link here:
https://s.hdtvizlecanli.com/rtl2d.m3u8
It's another portal with channels.
Best regards
Heiko -
Good evening.
Does anyone have any idea how I can record RTL2 and others?
Thank you,
Heiko -
Your question was already answered. Use streamlink for livestreams
Hi.
I now have Streamlink 6.10.0:
I googled it, but I don't know what I have to install.Code:heiko@Worf:~/Downloads$ cd '/home/heiko/Downloads/streamlink-6.10.0' heiko@Worf:~/Downloads/streamlink-6.10.0$ ls -la insgesamt 256 drwxr-xr-x 8 heiko heiko 4096 Sep 6 17:23 . drwxr-xr-x 145 heiko heiko 45056 Sep 28 23:46 .. -rw-r--r-- 1 heiko heiko 221 Sep 6 17:23 AUTHORS drwxr-xr-x 3 heiko heiko 4096 Sep 28 23:53 build_backend -rw-r--r-- 1 heiko heiko 109129 Sep 6 17:23 CHANGELOG.md drwxr-xr-x 4 heiko heiko 4096 Sep 6 17:23 completions -rw-r--r-- 1 heiko heiko 442 Sep 6 17:23 dev-requirements.txt drwxr-xr-x 8 heiko heiko 4096 Sep 6 17:23 docs -rw-r--r-- 1 heiko heiko 332 Sep 6 17:23 docs-requirements.txt -rw-r--r-- 1 heiko heiko 18593 Sep 6 17:23 icon.svg -rw-r--r-- 1 heiko heiko 1350 Sep 6 17:23 LICENSE -rw-r--r-- 1 heiko heiko 384 Sep 6 17:23 MANIFEST.in -rw-r--r-- 1 heiko heiko 6515 Sep 6 17:23 PKG-INFO -rw-r--r-- 1 heiko heiko 7635 Sep 6 17:23 pyproject.toml -rw-r--r-- 1 heiko heiko 4486 Sep 6 17:23 README.md drwxr-xr-x 2 heiko heiko 4096 Sep 6 17:23 script -rw-r--r-- 1 heiko heiko 38 Sep 6 17:23 setup.cfg -rw-r--r-- 1 heiko heiko 3149 Sep 6 17:23 setup.py drwxr-xr-x 5 heiko heiko 4096 Sep 6 17:23 src drwxr-xr-x 12 heiko heiko 4096 Sep 6 17:23 tests heiko@Worf:~/Downloads/streamlink-6.10.0$
I have Ubuntu 22.04.
Best regards
Heiko -
In addition to @silver's comment you can also check
https://streamlink.github.io/install.html#linux-and-bsd
https://streamlink.github.io/install.html#macos
and https://streamlink.github.io/cli.html for usage--[----->+<]>.++++++++++++.---.--------.
Download videos from ORF ON
By 10362227 in forum Video Streaming DownloadingReplies: 4Last Post: 16th Aug 2024, 05:02 -
Orf.at, on.orf.at
By ProWo in forum Video Streaming DownloadingReplies: 8Last Post: 6th Aug 2024, 17:13 -
Download from tvthek.orf.at
By lvdou in forum Video Streaming DownloadingReplies: 2Last Post: 21st Nov 2023, 05:49 -
Screen recording of streaming sites
By techmot in forum Video Streaming DownloadingReplies: 11Last Post: 13th Jul 2023, 08:28 -
How to recording the streaming service ?
By Valentin98 in forum Video Streaming DownloadingReplies: 5Last Post: 18th Sep 2021, 15:42
