I found a simple solution to prompt my old Toshiba DR340KU DVD recorder to finalize a failed recorded DVD.
If the message: "Recording error. Cannot record on this disk. E03"
Step 1. While the DVD is still in the DVD recorder try finalizing the DVD disc using the Finalize function from the DVD menu 2 more times and if the same error message appears next try step 2.
Step 2. Eject the DVD and copy the DVD to another blank DVD using Nero Burning ROM or any other DVD copying software on your computer.
Step 3. Once the copying process has finished eject the copied DVD from your computers DVD drive and insert the copied DVD into your Toshiba DR340KU DVD recorder and select Finalize from the DVD menu.
Step 4. Eject the DVD disc from the DVD recorder and test the disc for playback on your PC. if the DVD disc plays back the disc has been successfully finalized for playback on your and any other DVD player.
I use IsoBuster to extract video files from unfinalized DVD discs. Unfortunately it doesn't do the finalizing because the software doesn't allow writing to the disc.
I usually keep them on the HDD but convert them to *.mp4
If I still need to burn them to a DVD then I use the converted video files.
Help Toshiba Dvd recorder clicking loading problem d-r400 dr430 dvr
By adam2514 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 13th Mar 2024, 15:42 -
Toshiba DVR620KU VHS/DVD Combo Player-Recorder
By Gio99 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 6th Feb 2024, 15:50 -
A Toshiba RD-XS34SB Video Recorder with HDD, can you edit Title info
By Izzy Eck in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Apr 2021, 09:55 -
(Old Thread) Re: Finalize DVD-R, is this possible?
By Disco Makberto in forum DVD & Blu-ray RecordersReplies: 14Last Post: 16th Feb 2021, 10:31 -
Problem with finalize dvd
By JERRYCHOPIN in forum Video ConversionReplies: 4Last Post: 25th Nov 2020, 12:39
