Hey and welcome to All,
I'm a total beginner and glad that I found this nice board.
I have some questions concerning Video downloading:
1.) How can I Extrakt or find out the stream-url of live tv channels that can be played in a Webbrowser? I once had a Firefox-Addon who could do that but forgot about it. I need this for my own playlists and tvheadend.
2.) How is it possible to recird from services like netflix? I recently read in a magazine that you can do this with the help of a dvd-t modulator. Is this true?
Thanks in advance for your answer. Have a nice day![]()
1. Have you tried stream detector addon? Or you can always just check the network requests for m3u8
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Thanks for your help. I'll try the stream Detektor as I never found a m3u8 link so far.
Hey, I tried that and it really found some .m3u8 urls. But vlc player couldn't play that. I think these weren't the url for the real livestream.
I tried it on this page https://www.kan.org.il. These are israelian channels. I opened the live section but like I said no useable m3u-files. Any ideas? -
Use stream detector. Enable it. Refresh page, wait for it to dectect m3u8. Take the one at the bottom. You have a dropdown list somewhere, select Copy stream as streamlink command (obviously you need to install streamlink). Open terminal in a folder, paste that command, delete -o "file_name" parameter and hit enter. It will open VLC or other media player automatically. It's not working in VLC directly because you most likely need to pass some additional headers.
All of the m3u8 are usable. They have to be used in a specific way though--[----->+<]>.++++++++++++.---.--------.
[Attachment 82408 - Click to enlarge]
Code:https://kan11w.media.kan.org.il/hls/live/2105694/2105694/master.m3u8
Thanks a lot. Being busy the next days but I'll try my best to install and learn about the streamlink program. Giving you a feedback in a couple of days. Thanks so far. Great that you help noobs to get along.
You can find more information here about its usage
https://streamlink.github.io/cli.html
Stream detector will just generate the command for you automatically, but it's always good to know additional parameters according to your specific use case.--[----->+<]>.++++++++++++.---.--------.
unable to find the right urls
By nicanor_locke in forum Video Streaming DownloadingReplies: 16Last Post: 24th Oct 2025, 20:44 -
Download Multiple URLs with N_m3u8DL-RE
By HemaElqady in forum Video Streaming DownloadingReplies: 1Last Post: 18th May 2024, 01:21 -
How to distinguish correct license urls
By ghostexaid_1516 in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Sep 2023, 08:42 -
Extracting token for m3u8 stream
By aeregeneratel38 in forum Video Streaming DownloadingReplies: 3Last Post: 27th May 2021, 12:20 -
Extracting token for stream url.
By aeregeneratel38 in forum DVB / IPTVReplies: 0Last Post: 26th May 2021, 09:41
