Results 1 to 30 of 30
  1. Hello,
    Kindly suggest which program Avidemux or Vlc, to use to convert .ts files to mp4 that will maintain the quality.
    Thank you in advance.
  2. If the video/audio codecs are mp4 container compatible, then you can simply remux to mp4.
    No recoding occours, no quality loss. Avidemux can do it.
  3. Originally Posted by ProWo View Post
    Thank you for addressing my query..
    Here is the Media Info.. Can you please suggest me if I should use Avidemux..
    Complete name                            : D:\Xilli\Holidays.ts
    Format                                   : MPEG-TS
    File size                                : 5.10 GiB
    Duration                                 : 2 h 54 min
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 4 182 kb/s
    Frame rate                               : 25.000 FPS
    Video
    Menu ID                                  : 1 (0x1)
    Format profile                           : High@L4.1
    Format settings                          : CABAC / 2 Ref Frames
    Format settings, Reference frames        : 2 frames
    Codec ID                                 : 27
    Bit rate mode                            : Constant
    Nominal bit rate                         : 4 000 kb/s
    Width                                    : 1 920 pixels
    Height                                   : 1 080 pixels
    Bits/(Pixel*Frame)                       : 0.077
    Writing library                          : x264 core 155
    Encoding settings                        : cabac=1 / ref=2 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=4 / lookahead_threads=1 / sliced_threads=0 / slices=1 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / stitchable=1 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / weightb=0 / open_gop=0 / weightp=1 / keyint=50 / keyint_min=1 / scenecut=0 / intra_refresh=0 / rc_lookahead=50 / rc=cbr / mbtree=1 / bitrate=4000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=4000 / vbv_bufsize=4050 / nal_hrd=cbr / filler=1 / ip_ratio=1.40 / aq=3:1.00
    Audio
    Menu ID                                  : 1 (0x1)
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Format version                           : Version 4
    Muxing mode                              : ADTS
    Codec ID                                 : 15-2
    Bit rate mode                            : Variable
    Channel layout                           : L R
    Sampling rate                            : 48.0 kHz
    Frame rate                               : 46.875 FPS (1024 SPF)
    Delay relative to video                  : -40 ms
    Thank you
    May 2005
    Australia-PAL Land
    Use AVIDemux. Follow this procedure on my website.
  5. To make it easy, you can also use clever FFmpeg-GUI.
    Load your ts, click main, click multiplex, set mp4 as container and click multiplex.
    Done
    There is an automatic compatibility check for the involved codecs.
  6. Originally Posted by Alwyn View Post
    Thank you... I converted the file to mp4..
    Here is the Media Info.. Does everything look ok?
    General
    Complete name                            : D:\Yumm\Holidays.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/avc1/mp41)
    File size                                : 4.92 GiB
    Overall bit rate                         : 4 033 kb/s
    Writing application                      : Lavf58.76.100
    Video
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Source duration                          : 2 h 54 min
    Bit rate                                 : 3 965 kb/s
    Frame rate mode                          : Constant
    Bits/(Pixel*Frame)                       : 0.076
    Stream size                              : 4.84 GiB (98%)
    Source stream size                       : 4.84 GiB (98%)
    mdhd_Duration                            : 10476200
    Codec configuration box                  : avcC
    Audio
    Format                                   : AAC LC
    Codec ID                                 : mp4a-40-2
    Bit rate                                 : 60.6 kb/s
    Maximum bit rate                         : 128 kb/s
    Stream size                              : 75.7 MiB (2%)
    Default                                  : Yes
    Alternate group                          : 1
    Thank you.
  7. Originally Posted by ProWo View Post
    Done
    Thank you.. I did give clever ffmpeg a try. Its a good tool. I need to convert 100 videos with each video having an approximate length of 2hrs. So, I thought to ask about Avidemux to save time.
    Here is the Media Info of Mp4 file after using clever ffmpeg
    General
    Complete name                            : D:\Completed\Holidays_muxed.mp4
    File size                                : 4.62 GiB
    Overall bit rate                         : 3 785 kb/s
    Writing application                      : clever FFmpeg-GUI
    Video
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, Reference frames        : 4 frames
    Codec ID                                 : avc1
    Bit rate                                 : 3 716 kb/s
    Bits/(Pixel*Frame)                       : 0.072
    Stream size                              : 4.53 GiB (98%)
    Writing library                          : x264 core 164 r3191 4613ac3
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Format                                   : AAC LC
    Maximum bit rate                         : 63.2 kb/s
    Source stream size                       : 75.7 MiB (2%)
    Default                                  : Yes
    Alternate group                          : 1
    Thank you.
    May 2005
    Australia-PAL Land
    In that case, AVIDemux isn't the one. It can't easily do batching. But that file looks OK, although the bitrate is different to both the original and @ProWos (Clever FFMPEG). Did it process fairly quickly?
    I'm pretty sure FFMPEG can be set up to do batch processing without recoding; @ProWo will know.
  9. Originally Posted by Alwyn View Post
    For a 2hr video file, avidemux is taking me 2-3 Mins to convert one and Clever FFMPEG, is taking 2hrs to get one conversion done.
    I am ok with manual conversion.
    Should I opt for avidemux ?
    Thank you.
  10. Originally Posted by Jacobs View Post
    Then you have recoded the video, not remuxed it.
    As already mentioned above, load your ts video, click main, click multiplex, select mp4 as container and click multiplex at the bottom left.
    After a few seconds this should be done.
  11. Originally Posted by Alwyn View Post
    Batch processing isn't implemented yet in my GUI.
    May 2005
    Australia-PAL Land
    I think then that Clever is recoding/rendering it whereas AVIDemux isn't.
    It's doing the job, it's just that it'll require 100 setups. I suggest you wait to hear from the FFMPEG experts about smart rendering in batch. I believe AVIDemux is using FFMPEG under the hood so FFMPEG must do smart-rendering; it's just that AVIDemux won't batch-process using the GUI.
    Depending on your coding ability, I did find these ideas on the web:
    https://www.gaelanlloyd.com/blog/batch-processing-video-files-with-avidemux/
    https://www.reddit.com/r/Avidemux/comments/10eof7b/batchbulk_convert/
  13. Originally Posted by ProWo View Post
    Hi,
    I have sent you a pm regarding the steps I took. I have taken a screenshot video of the conversion. I dont know how to send the video.
    Thank you.
  14. You can post it here as attatchment.
    May 2005
    Australia-PAL Land
    Disclaimer: I have no idea what I am doing!
    I had a play with that Reddit script and it "seems" to work to run batching with AVIDemux. I basically followed the post to convert some VOBs to MPGs.
    It all happened quite quickly so I suspect it was a smart-render process.
    Full Reddit script:
    set avidemux="C:\Program Files\Avidemux 2.8 - 64 bits\avidemux.exe"
    set videocodec=Copy
    set audiocodec=Copy
    for %%f in (*.mkv) do %avidemux% --video-codec %videocodec% --audio-codec %audiocodec% --force-alt-h264 --load "%%f" --save "%%f.mp4" --quit
    echo.
    Pause
    In your case, just change the ".mkv" to ".ts".
    I think I can see what they've done but I don't understand the "force-alt-h264" part, not that it seemed to make any difference in my experiment.
    You just need to make sure that the link to avidemux.exe is correct.
    To create a BAT, just make a TXT file then change the extension to BAT. Edit it with Right-Click>Edit.
    Note, this (Copy, Copy) will only work if your TS files are H264-based.
    It should rip through your hundred files in a flash!
    I normally dislike command lines but this wasn't particularly onerous considering the benefit. CBA=tick.
  16. Originally Posted by Alwyn View Post
    Full Reddit script:
    set videocodec=Copy
    set audiocodec=Copy
    echo.
    Pause
    Thats a great job mate.. Thank you for the efforts.
  17. You may want to try this simple ffmpeg alternative:
    - Copy the code below into notpad and save it as container_change.cmd to your desktop.
    - Then multiple select (in explorer) and drag and drop all the files you want to convert onto that icon on your desktop. They will be converted one by one.
    :next
    if "%~1"=="" goto done
    ffmpeg -i "%~1" -c copy "%~1.mp4"
    shift
    goto next
    :done
  18. Member
    May 2005
    Australia-PAL Land
    @Sharc, I don't know how you have your FFMPEG set up; I had to put the full path to ffmpeg.exe in that CMD file. Then it worked. I do have ffmpeg.exe in System32.
    Interesting that both methods (and a VideoRedo test I did) are obviously smart-rendering indicated by the conversion speed but the file sizes come out different to the originals, in one case an original TS 2.1GB, converted MP4 1.8GB.
  19. Originally Posted by Alwyn View Post
    I have it in its own folder and put its path into the PATH of windows for convenience.
    If it is not in the PATH one can always specify the full path in the commandline as you did.
    .ts and .m2ts are transport streams which have more overhead than .mp4 and .mkv files, hence the difference in filesize.
    The overhead in .ts or .m2ts allows a fast resync when the stream is interrupted during transmission.
    May 2005
    Australia-PAL Land
    Could you explain that? What is the "path of Windows"?
    OK, good to know.
  21. Originally Posted by Alwyn View Post
    Type PATH into windows search, then
    System properties -> Environment variables -> System variables -> Path (add the bin folder of ffmpeg.exe to the list there).
    Details depend on the OS. This may help:
    https://www.computerhope.com/issues/ch000549.htm
    (I wonder why it doesn't work when you put ffmpeg.exe into one of the windows folders as these are already in the PATH....)
  22. Member
    May 2005
    Australia-PAL Land
    Dunno, but manually adding it to the path as you described has fixed it. Now I just have to remember to rejig the path variable when I update my ffmpeg folder. I might just stick with pasting in the full path.
  23. Originally Posted by Alwyn View Post
    Shouldn't be necessary when you update ffmpeg in the same folder.
  24. @Sharc & Alwyn
    You must add -map 0, or only the first stream of any type (video, audio, subtitle) is muxed.
  25. Originally Posted by ProWo View Post
    @Sharc & Alwyn
    Yep. Thanks for the hint.
  26. Member
    May 2005
    Australia-PAL Land
    Thanks @ProWo, where in the string would we put that?
  27. Code:
    ffmpeg -i "%~1" -map 0 -c copy "%~1.mp4"
  28. Member
    Jun 2022
    Dublin
    Adding a folder containing the ffmpeg utils ffmpeg.exe etc to the Windows PATH.
    You need to download and install say a static version of ffmpeg and add it to the windows PATH.
    Example ... https://www.gyan.dev/ffmpeg/builds/
    Adding the ffmpeg "BIN" folder to the "PATH" ...
    Search for "env" in Windows "search" ...
    or Select "Settings" "System", then Search ...
    Select "Edit the System enviornment variables" ... Not "Edit enviornment variables for your account"
    With the "advanced" tab selected click the "Enviornment Variables" button at the bottom right ...
    Select "Path" in the bottom "System variables" window pane.
    Select "Edit" at the bottom.
    Select "New" and then type in for example ... D:\ffmpeg\bin
    Click "Ok" when done.
    I use my "Remux" batch file based util to typically convert TS to other extensions, multiple input files as Sharc shows by using the "shift" command. Post #18.
  29. Originally Posted by JN- View Post
    Thank you Gyan babu... Great Inputs... Unfortunately.. I am not so technical. I am kind of an end user ..
