  1. I was hoping someone here could help me out with a problem that got me stumped. I'm trying to watch the livestream at https://www.srf.ch/play/tv/live/srf-1 outside of their app or site. Apart from the fact that you need a Swiss IP, things *should* be simple. But while I got a key that seems legit, it fails to work. Here's what I did:
    1. Easy to find the MPD url from their site and it seems static: https://srf1-lsvs.akamaized.net/out/v1/408194b773ab4035bb3693d14f5c40cb/index.mpd
    2. The PSSH is right there in the MPD:
    AAAAOnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABoSEN1nG5U3R0Lyt2KF1xSHTkc4AEjj3JWbBg==
    3. The license server is at a fixed url as well, with no special headers or data: https://srg.live.ott.irdeto.com/licenseServer/widevine/v1/SRG/license?contentId=SRF1DRM
    4. This gives me the following key:
    dd671b95374742f2b76285d714874e47:9018adeb6426da52b46c6f260c0c06e1
    If you decode the PSSH. the key id corresponds to what I found in (4) above, so everything seems fine. But if I try to play the MPD link in TiviMate or from the JW Developer page it just won't work.
    So yes, as the title says: what could I be doing wrong? The only thing I can think of is that the although the license call seems to work, it actually does need something extra and instead of returning a 403 error for example, it provides me with the wrong key?
  2. Member aqzs's Avatar
    Mar 2024
    Paris
    Key is the right one. It start playing but crash in the browser for some reason (I tried others web players same issue..)
    Edit : there are 2 keys not only one !
    dafc8406fe084a7c9793216a31bfec4a:8b3497633cffb1ccf020996e625058f9
    [Attachment 82303 - Click to enlarge]
  3. It doesn't even start playing when I try it in JW, but yes, it does show an image for like half a second in TiviMate. So would you say there is something wrong with the MPD?
    Edit: nevermind, you listed both keys. Thanks!
  4. Originally Posted by aqzs View Post
    sorry for off-topic do you know any online DRM stream tester site like
    https://kratosrepo.github.io/drm-player/
    https://developer-tools.jwplayer.com/stream-tester
    but with 2 keys support?
  5. Hi there, you can try StreamFab. They have a DRM MPD Downloader.
