I have this device. I can connect a single pair of headphones to using bluetooth
But I'd like to connect TWO headphones to it with each of the two having it's own independent volume control.
Can this be done?? If so, how??
Boo
Results 1 to 9 of 9
I checked the price of this device and it is about $20 in the USA (in my country it is $52)
I think the easiest solution for me if I was living in the USA would be to buy another one. Any other solution would mean buying a hardware which might work or not.
As I don't see your country in your profile this might not be a good solution for you. -
@Boowho III, in the past Bluetooth did not support more than 1 connection at a time. Since 2017, BT v5.0 and above support connection to multiple devices (such as headphones). This is often called "multi-point" (with or without the hyphen). However, for this to work, ALL devices (host + all endpoints) must fully support this feature. This, of course, comes at a premium ($$). You'll have to see which models that support it are available to you.
Scott -
The OP says he has a set-top box. The newer $50 Onn streaming device is a set-top box that runs Google TV. I don't have one yet.
The $20 Onn streaming device, which I have, is not a set-top box. It is a dongle that runs Android TV. However, I don't have any BT headphones so I can't test anything. Even if I did have 2 BT headphones, my Onn device has different hardware from the newer Onn model and runs a slightly different OS.Ignore list: hello_hello, tried, TechLord, Snoopy329
Downloading videos using a 4K set-top box
By nadya86 in forum Video Streaming DownloadingReplies: 6Last Post: 20th Sep 2025, 18:36 -
Amino Amigo 7X Set Top Box ( Streaming TV)
By muusicman in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2023, 21:31 -
Capturing in 1080i from set top box
By pthebest19 in forum Capturing and VCRReplies: 8Last Post: 17th Nov 2022, 21:24 -
How to use MPEG 4 set top Box of only playing USB
By shrikant.tillu in forum Latest Video NewsReplies: 3Last Post: 31st May 2021, 01:53 -
VLC cannot read .TS files from set-top box
By pchan in forum DVB / IPTVReplies: 14Last Post: 15th Mar 2020, 10:30
