Hello everyone.
I'd made my wedding film in Pinnacle Studio 7 (with a miro DC10 from a friend) and I want to convert it in a VCD (or SVCD) but I don't know how. Plase could anyone help me.
Thanks in advance.
Mat
It's been a while since I used Studio but here are some general guidelines. Edit your project by adding title and background music with smart sound. Don't add too many transitions since this is the flakiest part of the program. Save your project frequently. Then go to Make Movie and select the AVI tab. Make an AVI file with the indeo codec. Do not use the MPEG output since it is also flaky. Use TMPGEnc to encode the resulting AVI file using the standard VCD template. Burn you VCD with VCDEasy. If you want more help look at the guides on the left or ask a detailed question and give more information on your system and OS. Hope this helps.
PIV-2.4G ASUS MB, 1G Mem, WinXP
Pinnacle Studio 8
By Victri in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2007, 04:18 -
Pinnacle Studio 11
By fjmr in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 03:44 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
pinnacle studio 11
By serega in forum Latest Video NewsReplies: 14Last Post: 13th Sep 2007, 18:14 -
Is anyone using Pinnacle Studio 11 ???
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 22:56
