Page 3 of 3
FirstFirst 1 2 3
Results 61 to 73 of 73
    Sep 2024
    St. Louis, MO USA
    MuxMan did the job instantly with no issues, Jag. But thanks though!
    Here's the original version that I'd gotten from the DVD that's in PAL:
    https://1drv.ms/v/s!AltuOyWPfg39hG5b17YJigEEnivC
    And here's the version that was converted from PAL to NTSC using DGPullDown:
    https://1drv.ms/v/s!AltuOyWPfg39hG-ti2dOAIXcTkE3
    Let me know if it looks okay, or if I need to make any changes.
    Thank You once again!
    If everything looks okay, then I need to start researching on how to author the correct way with menus, music, images, video clips, and all of that stuff that they show on the DVD Menu of the original DVD.
  2. FINAL.VOB looks good. 25p with pulldown flags to 29.97i. Good A/V sync.
    May 2005
    Australia-PAL Land
    What process is being used to change from 720x576 to 720x480?
    Sep 2024
    St. Louis, MO USA
    Thank You SOO Much, Jagabo!
    I appreciate that!!
    Do you know what would be the best program or method to author it?
    Sep 2024
    St. Louis, MO USA
    I just used FFmpeg to Frame Match and turn it into 25 FPS progressive rather than de-interlace, as well as change the resolution from 720x576 to 720x480, Alwyn.
    I also had it separate the video and audio as well.
    Then I used DGPullDown to convert the m2v file from PAL to NTSC and MuxMan to merge the converted m2v file and the ac3 back together again.
    May 2005
    Australia-PAL Land
    Thanks Chris.
  7. Originally Posted by Chris Hooper View Post
    I haven't really authored DVDs in 20 years so I can't really recommend anything these days.
    Sep 2024
    St. Louis, MO USA
    Gotcha. I'm trying to find a decent DVD Authoring program that won't re-encode any of the files that I convert.
    I asked ChatGPT and it said DVD Styler can do it without re-encoding, as long as my files are in their correct format, but I swear after just doing a quick test run via iso preview, it looks like the colors are faded and it may've messed with the frames. Just looks a little jittery, but it could just be me being all paranoid about using the program now.
    May 2005
    Australia-PAL Land
    Right click for Properties on the title set at the bottom, then choose "Copy" for both the video and audio. I think that'll give you a smart-render.
  10. This is a DVD formatted VIDEO_TS folder in a .zip file.
    That is the only way Google Drive would upload it as a folder.
    It is a lot like the one Alwyn did.
    The difference is I used Tittle Writer to create the menu.
    I downloaded the episode posted by Chris Hooper in post # 40.
    Then I split it into 3 parts so it can be seen how the menu works.
    I joined it back together with AVStoDVD in NTSC format.
    This kept the 3 titles that the menu can select.
    This is not exactly what Chris wanted but I would have needed the whole DVD to try to keep the original menu.
    It has been a very long time since I tried to do that.
    Title Writer creates a simple menu with a very small footprint.
    That is what I prefer.
    I will leave it on Google Drive for a week or so. Then delete it.
    https://drive.google.com/file/d/193iz32LfkxG16GY5U_m3SjIKl53Mvip0/view?usp=sharing
    Last edited by cholla; 19th Sep 2024 at 15:12. Reason: The link was not working & it took me a while to get it right
    Sep 2024
    St. Louis, MO USA
    I'm sorry I'm just now seeing this message, Cholla.
    I'd already authored the DVD using DVDStyler a few days ago after writing my last message.
    DVDStyler is so simple to use; there's really nothing to it.
    I just recreated everything the same way as it was on the original disc.
    My only hope is that the video remained the same. As fast as it authored, I'm guessing there was no encoding involved other than with the menus; hopefully anyway.
    If someone who knows what they're doing with investigating videos like Jagabo did on Post #63, I'd sure appreciate the ISO image I uploaded to be looked over and scrutinized to see if everything is as it should be.
    I will delete the file after a week.
    Thank You all for your help!
    https://1drv.ms/u/c/fd0d7e8f253b6e5b/EVeb5HjktwNBqsDk9OsrKVsBLmXw3eQJIDz_AnU16HN24A?e=AkclMH
  12. I only looked at one of the 1 GB VOB files. It was 25p with soft pulldown to 29.97i. Exactly what you want. VLC was able to navigate the menu successfully. It could use some deblocking and noise reduction.
    Sep 2024
    St. Louis, MO USA
    Thank You SO Much, Jagabo!
    You're the BEST!
