I have a Soundblaster Audigy with SPDIF optical out which I have connected to my Yamaha RX-V377 5.1 receiver.
How do I setup Potplayer in order to play the 5.1 sound via SPDIF passthrough and the optical cable connection?
I'm a bit confused by all the available settings so any assistance would be greatly appreciated!
Many thanks!
I connected via HDMI just to test it and I get the exact same.. I tried to configure via Windows directly to produce 5.1 sound, not messing with Potplayer or anything. So this is HDMI from PC to AVR, HDMI from AVR via ARC to TV. I used HDMI 4, I select HDMI 4 and then I go to Windows - Sounds and I try to configure the speakers to 5.1 and it keeps playing all other channels through the 2 front speakers.. all speakers have been tested and working fine on their own so it's not the speakers..
Panasonic DMR-ES15 PAL - how to setup for TBC passthrough
By spotty in forum Capturing and VCRReplies: 9Last Post: 30th May 2023, 05:06 -
How to setup Daum PotPlayer to output TrueHD and DTS-HD
By c627627 in forum Software PlayingReplies: 9Last Post: 16th Feb 2022, 21:33 -
ES10 passthrough
By lojelo5 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 30th Dec 2021, 18:59 -
PotPlayer SPDIF EAC3 - DTS Plus (No 5.1 Audio)
By dskazan in forum Software PlayingReplies: 0Last Post: 16th Mar 2020, 04:13 -
PotPlayer SPDIF AAC AC3 DTS PCM
By blopblop in forum Software PlayingReplies: 12Last Post: 16th Mar 2020, 04:05
