For a long time MKVMerge used to mess with headers on default settings, which broke rewinding on my BluRay player. I used this workaround to make a scannable file out of it: https://forum.videohelp.com/threads/352097-After-remux-with-MKVMerge-to-add-subs-scanning-is-slow
It drove me crazy since it's savings on the level of 100-500 KB for a 5 GB file. Old files sometimes come out smaller when remuxed! Luckily the dev reversed the change eventually, tyty for that
I don't know a good way of figuring out which files need the treatment, other than ignoring versions < 5 and >50-60 or so. I end up trying most long files manually on the player but I'm getting bored of it.
Someone suggested looking for "Muxing method : Header stripping" but compressed headers never showed that for me on MediaInfo (v24.05.1)
Is that the info tab in MKVToolNix? I just checked about a dozen files and was about to pronounce KaxSeekHead as required for scanning, then found a file that scans without it (checked again on the player right now). Weird
Sorry for not mentioning, I always use the plain text view, not the default one. -
mkvinfo (https://mkvtoolnix.download/doc/mkvinfo.html) comes with mkvtoolnix.
I suspect that it is also shown in mkvtoolnix, but I haven't used that properly in years. I only use mkvmerge, mkvextract and mkvinfo via command line.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Yeah seems to be the same thing, only needs -a to show everything that can be expanded in the GUI.
I can't put my finger on what the differences are. So far it seems all files where scanning/seeking works have the KaxSeekHead entry and most files where it's doesn't don't have it, but not all. (Tested about a dozen large files)
It would be nice if anyone could figure out if/where these options here leave a signature, since that's what I use to fix my mkv files:
--clusters-in-meta-seek
--engage no_cue_duration
--engage no_cue_relative_position
What would the headers be?
By axnspain in forum Video Streaming DownloadingReplies: 13Last Post: 19th Jun 2024, 18:08 -
Best Compressed Storage of mts files ?
By NewTwoVideo in forum Video ConversionReplies: 23Last Post: 10th Nov 2023, 17:03 -
Headers using curlconverter
By titotrinidad in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2023, 11:17 -
Not getting headers from this Licence
By ihuman in forum Video Streaming DownloadingReplies: 18Last Post: 25th May 2023, 09:43 -
Create .ts files from a .mkv file while still recording the .mkv
By RKJ in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2020, 22:51
