Hello,
Can someone share the N_m3u8dl code to decrypt clearkeys.
Results 1 to 12 of 12
I've never used this tool before, but if I want to find the key (not the kid), would using the MPD be enough?
N_m3u8DL-RE "https://website.com/file.mpd" --key-text-file key.txtLast edited by Babuino; 23rd Dec 2024 at 04:53.
if use --key-text-file key.txt no need --key "KeyId:Key" don't you think?
RE "mpd" --key-text-file key.txt -
Once I run the command, it asks for quality, I select it and then it starts an endless-looking scan. Should I wait a long time? During the scan, it shows the PSSH and the KID, but not the key. The MPD is a live stream. Should I add the Widevine license URL?
Code:N_m3u8DL-RE "https://otte.live.ll.ww.aiv-cdn.net/dub-nitro/live/clients/dash/enc/fx6zubsovz/out/v1/eabbafa4b209459da45bdde8298676e6/cenc.mpd" --save-name "video" -M format=mp4 --key-text-file key.txt
yes, RE show only pssh and kid but no key. about your long time to wait no, isn't normal
btw i've tried to download from your mpd (without key.txt, just for test) and download start fast, no waiting times -
yea, this ext is a guesser, to get kid+key (click on + to see key found)
RE show only kid on download
N_m3u8DL-RE to decrypt and then merge video and audio how ?
By Loryanam2 in forum Video Streaming DownloadingReplies: 5Last Post: 6th Jun 2024, 11:32 -
clearkey problem of getting key
By d9111 in forum Video Streaming DownloadingReplies: 13Last Post: 25th May 2024, 11:54 -
help with clearkey and eme logger
By gaby45 in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Apr 2024, 02:42 -
Can N_m3u8DL-RE be used just to decrypt an m3u8 list?
By Frankss in forum Video Streaming DownloadingReplies: 3Last Post: 16th Mar 2024, 18:17 -
[Solved] How to decrypt the clearkey?
By adidaz in forum Video Streaming DownloadingReplies: 3Last Post: 11th Mar 2022, 21:06
