"I am trying to extract audio from an avi/divx file with Virtual Dub 1.4.10 but get the following error. "The requested audio compression is not compatible with the input format. Check the sampling rate and channel count of the input match those of the required format." Can anyone give advice? I am new to this and am following directions of www.vcdhelp.com/divxtovcd.htm. Thanks." (posted by mistagord)
I have having the same problem. Please help!
Your divx file may well contain AC3 audio. Search the forum for a solution as this problem has been encountered by many before you.
Hey I have tried everything that I have came upon. I try using Vir. Dub with the Full Pro. Mode and I get an error. I have tried using AVI2VCD, Got an error. I really need some help. If anyone could give me hint, many thanks would be given. Thanks again!
Ok, if your file does contain AC3 audio the solution is to use BeSweet to extract the AC3 and convert to stereo wav format. One of the gudes on this site covers this I believe.
error message when adding SSA. file to virtual dub
By fredsieg1937 in forum SubtitleReplies: 1Last Post: 24th Sep 2009, 20:53 -
virtual dub "non-zero start position" error
By DaneClark in forum EditingReplies: 1Last Post: 17th Aug 2009, 20:24 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Error when trying to compress with Virtual Dub
By las7h0p3 in forum Video ConversionReplies: 2Last Post: 7th Oct 2008, 13:39 -
Auto Gordian Knot error issued by Virtual Dub
By loninappleton in forum Video ConversionReplies: 10Last Post: 30th Apr 2008, 11:56
