Page 5 of 6
FirstFirst ... 3 4 5 6 LastLast
Results 121 to 150 of 175
  1. Member Bridgy's Avatar
    Aug 2024
    Sydney
    You must be on a slow internet connection with a download speed that slow.
    I have a 500Mbps NBN connection, and that 245mb folder downloads in a flash for me, like 2 seconds.
    I actually get almost 540Mbps from Sydney without my Proton VPN.
    [Attachment 92298 - Click to enlarge]
    Using my VPN from Australia i get 490 routing thru New Zealand, and 350 thru Tokyo.
    [Attachment 92299 - Click to enlarge]
    [Attachment 92300 - Click to enlarge]
    Jan 2006
    I have 1Gig internet.
    [Attachment 92301 - Click to enlarge]
    I tried another download.
    [Attachment 92302 - Click to enlarge]
  3. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Dam well you got a great internet speed, not a speed i would bother paying for, but that aside, something is definitely going on there, my download was around 10 to 12MB/sec
    Jan 2006
    I click on & the smart media cutter exe file in order to run it.
    Message on screen says to drop a file or click to browse.
    I click to browse & go to my Video folder & select an .mpg file. Tried a couple .mpg files.
    Screen message says Opening media file - Please wait.
    Then is just closes & disappears.
    Any idea what's happening?
  5. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Dam, i never had any crash like that from my files, then again the only files that i have used in SMC are my 4k/60p HEVC camera recorded files.
    Might have to try and find a crash file report (if SMC has one) and send it to the Developer or post it in here for him, or others to look at.
    May 2005
    PAL User
    No problem opening MPGs here.
    SMC downloaded in les than 60 seconds here.
    Jan 2006
    When I first downloaded SMC from the VideoHelp forum's link the other day it was slow. I cancelled & re-tried & it then downloaded fast.
    I just now tried the VideoHelp link & it fluctuated around 800 KB/sec.
    Jan 2006
    I tried a couple VOB files & got the same thing.
    May 2005
    PAL User
    @Mike99, yes, I can't open a VOB either, the thingee spins for a second or so and then SMC goes back to the "Drop media or project files here to start" screen.
    But, if I convert a VOB to MPG with AVIDemux (Smart-Change) SMC will open it OK.
  10. Originally Posted by Alwyn View Post
    I afraid that something went wrong and version 2.4.4 is broken. VOBs can be opened and joined in 2.4.1. Moreover, 2.4.4 cannot open a ts (tested h264 DVB-S streams) which was created by it, including version 2.4.1 - causes the program to close without warning.
    Jan 2006
    I tried version 2.4.4 again & it opened & played an .mp4 and .MOV video. At least I know the program can play somethings.
    May 2005
    PAL User
    Processing VOBs is probably not a common use-case for SMC. Most VOBs would come from a DVD, which already has no ads nor needs cutting up. Recoding to MP4 would be handy but in the priority list, not at the top, IMO.
  13. Member Bridgy's Avatar
    Aug 2024
    Sydney
    VOB and MPG are ancient now, and i can't believe it has already been so many years since i moved from DVD, i never worked with Bluray because i considered it totally pointless.
    May 2005
    PAL User
    All TV broadcasts, if not HD, are in MPEG 2. They are not ancient.
  15. Member Bridgy's Avatar
    Aug 2024
    Sydney
    All TV broadcasts, if not HD, are in MPEG 2. They are not ancient. in your opinion
    I said nothing about TV broadcast, i was referring to DVD and BD, and given that it now 2026 all TV broadcast should be in HD as a minimum in my opinion, and if mpeg2 is still being used in TV broadcast then we TV viewers are being ripped off by the crap quality we get.
    I personally can't believe anyone still works with these formats, but i guess those recording from TV have no choice.
    May 2005
    PAL User
    In your opinion.
  17. Member Bridgy's Avatar
    Aug 2024
    Sydney
    In your opinion.
    Yes, you claimed that They are not ancient, as if it was a fact, so i was just reminding you that it was just your opinion too.
    In my previous post i did say that what i had typed was my opinion.
    Cheers m8.
  18. Member
    May 2005
    PAL User
    The fact is that MPEG 2 is still being broadcast and therefore it is not ancient. You can opine all you like. Stop your nonsense and stick to the topic.
  19. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Don't you start telling me what to do or say, you have taken this thread off topic just as much as i have, just by responding like you have.
    My point is, they should not be broadcasting in such an ancient format and giving us fodder quality on our TV, what is it that you don't get.
    Again, it is my ownm opinion, so you back off and no need to respond if you disagree.
    You stick to the Topic and so will i, Geez
  20. Originally Posted by Bridgy View Post
    Imagine that people still use DVDs, and want to convert them to format which is easier to prepare, handle, and/or enables streaming. Except of that MPEG2 HD is a standard primarily utilized in legacy digital television systems in the US. (Of course, it is impossible to create a DVD from such a stream without conversion.)
    It is you who demands SMC has option to convert to other codec and resolution. So then, remember that people have different needs but also interests.
  21. Member Bridgy's Avatar
    Aug 2024
    Sydney
    I do not, nor have i ever DEMANDED anything from the developer of SMC, so get your dam facts right before sprouting that rubbish.
    I have asked him in here, as well as via PM, if he will ever be offering support for recoding to other Resolutions in the AV1, VP9, HEVC, and AVC codecs that he already has for his current Full Recode export option, this is the only other feature that i personally want to see in SMC, as well as maybe add a feature to add titles, BUT i already have my own custom method of creating my titles and i use VRD to add them to my export files, so if SMC does not ever have a title feature i won't be too worried, it would just bring SMC more into line with VRD as a comparable option.
    As far as the Developer including export to other resolutions or Formats, i can assure you right now that i would never ever ask for him to add an option to allow conversion to older formats such as MPEG-2 because i personally would never have the need to use them, HOWEVER it is up to him to include any other format for those who still work with them.
    For those who might take offense and crap me out for referring to mpeg-2, or any other older format as being ancient, then they just need to deal with it, and move on, it is just my own personal opinion, because they are very old formats from many years ago, even if they still may be used by some, including the TV broadcast industry, but why they still do this in 2026 i have no idea, maybe someone can enlighten me.
  22. Member
    May 2005
    PAL User
    A suggestion/feature request:
    A shortcut (say P [next to I O) to automatically delete a marked section.
    Example scenario: I'm cutting out ads from a TV recording. When I get to the start of an ad bracket, I hit I. When I get to the end of the ad bracket, I hit O. But I then have to hit Delete to actually delete the ad bracket. It would be good to simply hit I then P and move on to the next section.
    Thanks for considering!
  23. Member Bridgy's Avatar
    Aug 2024
    Sydney
    Nice request from one of our fellow Aussie users
  24. I'm curious why skeskinen chose to go from selection to cut, rather than direct to cut. You can currently edit cuts, and a snap to cursor option would resolve any current limitations when editing previous cuts.
  25. Member Bridgy's Avatar
    Aug 2024
    Sydney
    I hope that the GUI does not change now that i am use to using it the way it is, there are a few other internal settings that i prefer to be a bit different, but those are not important.
    I also never use my keyboard when using editing tools, i am a mouse clicker and i love buttons to click on.
  26. Yep, prefer to use buttons myself (don't mind ctrl clicking etc).
    For me the only two things I would like to see in SMC is that those buttons be placed a little more central. This will of course depend on screen size. With wider screens the Mark In/Out buttons are little to far over for my liking.
    The only other issue I have, I have already mentioned, is the Invert option. I prefer to Keep segments and would like this to be some kind of option during Export.
    Of course the most important aspect is that it does what it is designed to do accurately and consistently. I have no complaints in that department.
  27. Member Bridgy's Avatar
    Aug 2024
    Sydney
    This is my preferred GUI layout if i had a choice, but i am ok with it the way it is if need be.
    [Attachment 92388 - Click to enlarge]
    Everything is centered below the preview screen, i just got so used to it with VRD.
    [Attachment 92389 - Click to enlarge]
  28. In all the time I’ve been using SMC I never had the segment list open. Looking at your first image I now realise this pushes the buttons away from the far right to a more comfortable location. Also, unlike the Tools panel this is a more useful panel to leave open during general editing.
    Now, if that Skip Cuts button (it already exists on the Playback control bar) could be replaced with an Invert Cuts button (as a compromise to an option in the Export dialogue) I would be a very happy bunny.
    And yes, I think the Play button not being centred on the Playback control bar is a minor design faux pas. The layout I created in my first post also shows this centred. No big deal of course.
  29. Member Bridgy's Avatar
    Aug 2024
    Sydney
    I am just so used to using VRD and in my 2nd image above this is the way i have always had the GUI laid out under the preview screen, and these buttons have always been centered, so using my photo editor i placed the main cutting tools in the same place from where they are by default.
    Like i said before, i can live with the GUI as it is now if i had to.
  30. Originally Posted by Bridgy View Post
    Likewise, particularly as the dev appears to be conentrating on ironing out any bugs and performance issues, which is no bad thing.
