    Sep 2024
    I'll past 60 years old so I burned a fair share of DVDS and music CDS and whatever I've used a couple other authoring programs, but, I wanted to try this one, Winx dvd author, and this one does not recognize my drive at all its basic DVD player from Amazon every other program I use doesn't have a problem with it but this software does. It doesn't give an error message because there's no need to, it can't recognize my drive it's like it's not even there so it gives me no options to fix it. Anybody out there have the same problem and did you get some good advice as how to fix that? I've been to several other places but nobody seems to have an answer, so if anybody has an answer I'll be glad to share it with them. This is difficult to say after living six decades, but I'm new. (To the forum)
    Processor AMD Ryzen 9 3950X 16-Core Processor 3.50 GHz
    Installed RAM 64.0 GB
    Device ID XXXXXXXXXXXXXXXXXXXXXXXXXXX
    Product ID XXXXXXXXXXXXXXXXXXXXXXXXXXX
    System type 64-bit operating system, x64-based processor
    Pen and touch Pen support
    Edition Windows 11 Pro
    Version 23H2
    Installed on xxxxxxxxxxxxxx
    OS build 22631.4112
    Experience Windows Feature Experience Pack 1000.22700.1034.0
  2. Extraordinary claims require extraordinary evidence -Carl Sagan
    Sep 2024
    Bless you!
    Originally Posted by TreeTops View Post
    I got you beat: I'm past 80.
    Be well, take care.
    canada
    Just one thought,if a program doesn't read your drive it's not much of a program.
    Dec 2024
    Stevensville, Montana
    WinX DVR Author must run elevated privileges to access the SPTI (SCSI pass through interface). Either right click the icon and "Run as administrator", or modify the advanced properties of the desktop icon (check the box for "Run as administrator").
