    Sep 2024
    France
    Hello everyone,
    I found this forum yesterday and honestly it's a true treasure and it helped me a lot. So thanks !
    Anyway, i need some help with N_m3u8DL-RE.
    I am desesparately trying to find a way to get the right argument to get the main dub of the video and my language dub (if available) downloaded.
    I tried stuff like :
    -sa role="main":for=best | lang="fr":for=best
    -sa role="main":for=best & lang="fr":for=best
    -sa role="main", lang="fr":for=best2
    -sa role="main":for=best -sa lang="fr":for=best
    But i failed each time.
    If i select all possible languages (depending of the source) :
    -sa lang="fr|jp|ko|en":for=best2
    then it downloads the main dub and english's dub if the english one is available...
    Could someone tell me what i am doing wrong ?
    Thanks !
  2. Member aqzs's Avatar
    Mar 2024
    Paris
    Hey, I assume you'd prefer french audio if it's available, right? I usually download all the available audio tracks since they're around 20MB compared to roughly a gig per video. Could you check this?
    -sa "lang=fr|for=best"
    Sep 2024
    France
    thanks for your answer but i don't only want the french dub.
    I want to get the video as vostfr, and add the fr dub if it's avaliable.
    But the main dub language (the VO) might be different, depending if it's an anime, a k-drama, or an US movie...
    That's why i try to to simplify to get all possibles cases. But it looks like i can't use the "-sa role" and the "-sa lang" together.
    Or perhaps i am missing something...
  4. Member aqzs's Avatar
    Mar 2024
    Paris
    Did you try using --drop-audio ?
    Sep 2024
    France
    Nope...
    Right now my script looks like this :
    N_m3u8DL-RE "mpd_link" --key-text-file keys.txt -sv best -sa lang="ko|fr|jp|en":for=best2 -ss "lang=fr:for=best" -M format=mkv --header "User-Agent" --header "Referer:" --save-name "name"
    It works, but if there are 3 dubs available (ex. jp, fr and en), the program download the main dub and english...
    And i don't want to modify manually each time the script, hence my attempt to ask the program to only select the main dub and french...
  6. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    What you want is too complex for N_m3u8DL-RE
    edit: at best you could do
    -sa all
