Hello everyone,
I'm trying to create a pretty basic Blu-ray menu using TMPGEnc Authoring Works 7, but I'm running into some issues. My menu only needs three options: Play Movie, Subtitles, and Bonus, but I can't figure out how to assign a menu button to turn on subtitles or switch to a different audio track.
Has anyone worked with this program before? I’ve been searching through the settings, but I’m stuck on how to link the buttons to these specific functions. Any help or guidance would be really appreciated!
I have similar problem...
The software seems too simplified to be able to make "simple" Blu-rays...
I would like something simple: A main page containing : "Play / Set Up / Chapters / Bonus" buttons and each of the buttons would lead to another page...
But when I add tracks (bonus) it creates a top menu for me to access each element, and each element has its own chapters / Set up page...
Maybe there is a way to make a classic blu-ray but I can't find it. -
Yep, I am not seconding, I think I'm thirding?
Here, or maybe on their site, it describes the license as "Shareware (Free download but time limited software. Full version from $100)". WTH does that mean? Time limited but does it stamp the produced disk? From $100?!?! Different time length of use rights license?
I also want something simple to "create a pretty basic Blu-ray menu" as @nostalgia described. But I don't want to waste a bunch of disks to find out it's not for me.
If not TAWS, what is a simple Blu-Ray authoring program, preferably open source, that a chubby, old, retired guy can use? @nostalgia I know it was last fall when you posted this, but did you get it figured out or move to a different program? @Atillart, maybe we will find a way to make ""simple" Blu-rays..."
Trial limitations:
Usable for 30 days after initial startup.
License screen appears at every startup.
A logo movie track is inserted at the beginning of each authoring data.
https://tmpgenc.pegasys-inc.com/en/download/taw7.html#content -
So @Atillart, what are you going to do? Are you going to continue trying author with TMPGEnc Authoring Works or try a different program?
TMPGEnc Authoring Works 6 Menu help
By rbatty11 in forum Authoring (DVD)Replies: 14Last Post: 11th Mar 2025, 13:02 -
TMPGenc Authoring Works 6 - Subtitels and Menu questions
By Tyrell63 in forum Authoring (Blu-ray)Replies: 1Last Post: 28th Feb 2023, 16:18 -
TMPGEnc Authoring Works 6 Motion Menu Help
By nostalgia in forum Authoring (Blu-ray)Replies: 1Last Post: 29th Sep 2022, 18:02 -
TMPGEnc Authoring Works 5 Menu Help
By hurricane1951 in forum Authoring (Blu-ray)Replies: 3Last Post: 26th Feb 2022, 15:28 -
Adding background audio to menu using TMPGenc Authoring Works 6
By mulliganman in forum Authoring (Blu-ray)Replies: 4Last Post: 25th Dec 2020, 08:57
