Hi together,
i applied a patch for ffmpeg which makes it possible to decrypt mpd dash streams with multiple keys.
It‘s the option -cenc_decryption_keys
https://patchwork.ffmpeg.org/project/ffmpeg/patch/20231113084019.5081-1-adrien@guinet.me/
https://github.com/matthias1232/FFmpeg
The compilation and build worked with Ubuntu 22.04
I got the command running and decryption works with a singe key.
/usr/local/bin/ffmpeg -f dash -cenc_decryption_keys b9931924531e5d22967a749ab110xxxx=5763de9f8d969yxxx ca57f6527f5e6e41
But i dont know how i should write the command to apply more than one key.
> This commit introduces new options to support more than one decryption
> keys:
> * add a decryption_keys option to MOV, that supports a dictionnary of
> KID=>key (in hex), using AV_OPT_TYPE_DICT
> * add the corresponding cenc_decryption_keys option to DASH
I tried it seperated with a „,“ and also to applied the -cenc_decryption_keys command multiple times but i didnt work in any way.
Can someone please explain me how the command should look like?
Thank you guys
Results 1 to 9 of 9
Off topic but did you try asking in ffmpeg dev IRC ffmpeg https://www.ffmpeg.org/contact.html#IRCChannels
discord=notaghost9997 -
Wow amazing @LZAA, this worked.
I just have an problem with playback. The Stream initial Load takes about 15 Seconds to start and interrupts after about 5-10 Seconds of Streaming
HTML Code:ffmpeg -f dash -cenc_decryption_keys xxxxxxxxxxxxxxxx=xxxxxxxxxxxxxxxx:xxxxxxxxxxxxxxxx=xxxxxxxxxxxxxxxx:xxxxxxxxxxxxxxxx=xxxxxxxxxxxxxxxx -user_agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:81.0) Gecko/20100101 Firefox/81.0" -re -i https://orf1-247.mdn.ors.at/orf/orf1/drmqxa-247/manifest.mpd -ignore_unknown -map 0:v -map 0:a -c:a copy -c:v copy -sn -movflags +faststart -map -0:s -f mpegts pipe:1
Code:2024-09-06 09:45:09.420 spawn: Stream mapping: 2024-09-06 09:45:09.420 spawn: Stream #0:0 -> #0:0 (copy) 2024-09-06 09:45:09.421 spawn: Stream #0:1 -> #0:1 (copy) 2024-09-06 09:45:09.421 spawn: Stream #0:2 -> #0:2 (copy) 2024-09-06 09:45:09.421 spawn: Stream #0:3 -> #0:3 (copy) 2024-09-06 09:45:09.421 spawn: Stream #0:4 -> #0:4 (copy) 2024-09-06 09:45:09.421 spawn: Stream #0:5 -> #0:5 (copy) 2024-09-06 09:45:09.421 spawn: Stream #0:6 -> #0:6 (copy) 2024-09-06 09:45:09.422 spawn: Stream #0:7 -> #0:7 (copy) 2024-09-06 09:45:09.422 spawn: Output #0, mpegts, to 'pipe:1': 2024-09-06 09:45:09.422 spawn: Metadata: 2024-09-06 09:45:09.422 spawn: encoder : Lavf61.5.101 2024-09-06 09:45:09.423 spawn: Stream #0:0: Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 512x288 [SAR 1:1 DAR 16:9], q=2-31, 306 kb/s, 600 fps, 25 tbr, 90k tbn (default) 2024-09-06 09:45:09.423 spawn: Metadata: 2024-09-06 09:45:09.423 spawn: variant_bitrate : 426000 2024-09-06 09:45:09.423 spawn: id : video=426000 2024-09-06 09:45:09.423 spawn: Side data: 2024-09-06 09:45:09.423 spawn: unknown side data type 24 (1898 bytes) 2024-09-06 09:45:09.424 spawn: Stream #0:1: Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 640x360 [SAR 1:1 DAR 16:9], q=2-31, 541 kb/s, 600 fps, 25 tbr, 90k tbn (default) 2024-09-06 09:45:09.424 spawn: Metadata: 2024-09-06 09:45:09.424 spawn: variant_bitrate : 877600 2024-09-06 09:45:09.424 spawn: id : video=877600 2024-09-06 09:45:09.424 spawn: Side data: 2024-09-06 09:45:09.425 spawn: unknown side data type 24 (1898 bytes) 2024-09-06 09:45:09.425 spawn: Stream #0:2: Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 960x540 [SAR 1:1 DAR 16:9], q=2-31, 1152 kb/s, 600 fps, 25 tbr, 90k tbn (default) 2024-09-06 09:45:09.425 spawn: Metadata: 2024-09-06 09:45:09.425 spawn: variant_bitrate : 1402400 2024-09-06 09:45:09.425 spawn: id : video=1402400 2024-09-06 09:45:09.425 spawn: Side data: 2024-09-06 09:45:09.426 spawn: unknown side data type 24 (1898 bytes) 2024-09-06 09:45:09.426 spawn: Stream #0:3: Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 960x540 [SAR 1:1 DAR 16:9], q=2-31, 1395 kb/s, 600 fps, 25 tbr, 90k tbn (default) 2024-09-06 09:45:09.426 spawn: Metadata: 2024-09-06 09:45:09.426 spawn: variant_bitrate : 1927600 2024-09-06 09:45:09.426 spawn: id : video=1927600 2024-09-06 09:45:09.427 spawn: Side data: 2024-09-06 09:45:09.427 spawn: unknown side data type 24 (1898 bytes) 2024-09-06 09:45:09.427 spawn: Stream #0:4: Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 1959 kb/s, 600 fps, 25 tbr, 90k tbn (default) 2024-09-06 09:45:09.427 spawn: Metadata: 2024-09-06 09:45:09.427 spawn: variant_bitrate : 2557600 2024-09-06 09:45:09.427 spawn: id : video=2557600 2024-09-06 09:45:09.428 spawn: Side data: 2024-09-06 09:45:09.428 spawn: unknown side data type 24 (1898 bytes) 2024-09-06 09:45:09.428 spawn: Stream #0:5: Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 2220 kb/s, 600 fps, 25 tbr, 90k tbn (default) 2024-09-06 09:45:09.428 spawn: Metadata: 2024-09-06 09:45:09.429 spawn: variant_bitrate : 3187600 2024-09-06 09:45:09.429 spawn: id : video=3187600 2024-09-06 09:45:09.429 spawn: Side data: 2024-09-06 09:45:09.429 spawn: unknown side data type 24 (1898 bytes) 2024-09-06 09:45:09.429 spawn: Stream #0:6(de): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 189 kb/s (default) 2024-09-06 09:45:09.429 spawn: Metadata: 2024-09-06 09:45:09.430 spawn: variant_bitrate : 294400 2024-09-06 09:45:09.430 spawn: id : audio_298782_deu=294400 2024-09-06 09:45:09.430 spawn: Side data: 2024-09-06 09:45:09.430 spawn: unknown side data type 24 (1898 bytes) 2024-09-06 09:45:09.430 spawn: Stream #0:7(mis): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 189 kb/s (default) 2024-09-06 09:45:09.430 spawn: Metadata: 2024-09-06 09:45:09.431 spawn: variant_bitrate : 294400 2024-09-06 09:45:09.431 spawn: id : audio_298783_mis=294400 2024-09-06 09:45:09.431 spawn: Side data: 2024-09-06 09:45:09.431 spawn: unknown side data type 24 (1898 bytes) 2024-09-06 09:45:09.431 spawn: Press [q] to stop, [?] for help 2024-09-06 09:45:09.932 spawn: frame= 26 fps=0.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 247KiB time=00:00:01.00 bitrate=2024.0kbits/s speed= 2x 2024-09-06 09:45:10.432 spawn: frame= 39 fps= 39 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 420KiB time=00:00:01.52 bitrate=2263.4kbits/s speed=1.52x 2024-09-06 09:45:10.932 spawn: frame= 51 fps= 34 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 483KiB time=00:00:02.00 bitrate=1978.4kbits/s speed=1.33x 2024-09-06 09:45:11.432 spawn: frame= 64 fps= 32 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 588KiB time=00:00:02.48 bitrate=1940.6kbits/s speed=1.24x 2024-09-06 09:45:11.933 spawn: frame= 76 fps= 30 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 679KiB time=00:00:02.96 bitrate=1877.4kbits/s speed=1.18x 2024-09-06 09:45:12.433 spawn: frame= 89 fps= 30 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 840KiB time=00:00:03.44 bitrate=1999.3kbits/s speed=1.15x 2024-09-06 09:45:12.933 spawn: frame= 100 fps= 29 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=1.12x 2024-09-06 09:45:13.433 spawn: frame= 100 fps= 25 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.98x 2024-09-06 09:45:13.933 spawn: frame= 100 fps= 22 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.871x 2024-09-06 09:45:14.434 spawn: frame= 100 fps= 20 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.784x 2024-09-06 09:45:14.934 spawn: frame= 100 fps= 18 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.713x 2024-09-06 09:45:15.434 spawn: frame= 100 fps= 17 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.653x 2024-09-06 09:45:15.934 spawn: frame= 100 fps= 15 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.603x 2024-09-06 09:45:16.434 spawn: frame= 100 fps= 14 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.56x 2024-09-06 09:45:16.935 spawn: frame= 100 fps= 13 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.523x 2024-09-06 09:45:17.435 spawn: frame= 100 fps= 12 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.49x 2024-09-06 09:45:17.935 spawn: frame= 100 fps= 12 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.461x 2024-09-06 09:45:18.435 spawn: frame= 100 fps= 11 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.436x 2024-09-06 09:45:18.935 spawn: frame= 100 fps= 11 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.413x 2024-09-06 09:45:19.435 spawn: frame= 100 fps= 10 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.392x 2024-09-06 09:45:19.936 spawn: frame= 100 fps=9.5 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.373x 2024-09-06 09:45:20.436 spawn: frame= 100 fps=9.1 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.356x 2024-09-06 09:45:20.936 spawn: frame= 100 fps=8.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.341x 2024-09-06 09:45:21.436 spawn: frame= 100 fps=8.3 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.327x 2024-09-06 09:45:21.937 spawn: frame= 100 fps=8.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.314x 2024-09-06 09:45:22.437 spawn: frame= 100 fps=7.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.302x 2024-09-06 09:45:22.937 spawn: frame= 100 fps=7.4 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.29x 2024-09-06 09:45:23.437 spawn: frame= 100 fps=7.1 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.28x 2024-09-06 09:45:23.937 spawn: frame= 100 fps=6.9 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.27x 2024-09-06 09:45:24.437 spawn: frame= 100 fps=6.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1025KiB time=00:00:03.92 bitrate=2141.5kbits/s speed=0.261x 2024-09-06 09:45:24.938 spawn: frame= 101 fps=6.5 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1269KiB time=00:00:03.92 bitrate=2651.6kbits/s speed=0.253x 2024-09-06 09:45:25.438 spawn: frame= 101 fps=6.3 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1269KiB time=00:00:03.92 bitrate=2651.6kbits/s speed=0.245x 2024-09-06 09:45:25.938 spawn: frame= 101 fps=6.1 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1269KiB time=00:00:03.92 bitrate=2651.6kbits/s speed=0.238x 2024-09-06 09:45:26.438 spawn: frame= 101 fps=5.9 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1269KiB time=00:00:03.92 bitrate=2651.6kbits/s speed=0.231x 2024-09-06 09:45:26.938 spawn: frame= 101 fps=5.8 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1269KiB time=00:00:03.92 bitrate=2651.6kbits/s speed=0.224x 2024-09-06 09:45:27.438 spawn: frame= 101 fps=5.6 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1269KiB time=00:00:03.92 bitrate=2651.6kbits/s speed=0.218x 2024-09-06 09:45:27.939 spawn: frame= 101 fps=5.5 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1269KiB time=00:00:03.92 bitrate=2651.6kbits/s speed=0.212x 2024-09-06 09:45:28.439 spawn: frame= 101 fps=5.3 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 1269KiB time=00:00:03.92 bitrate=2651.6kbits/s speed=0.206x 2024-09-06 09:45:28.894 tsfix: The timediff for AAC is big (298851), using current dts 2024-09-06 09:45:28.906 spawn: [dash @ 0xaaaaeab9bac0] No longer receiving stream_index 8 2024-09-06 09:45:28.939 spawn: frame= 101 fps=5.2 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.404x 2024-09-06 09:45:29.439 spawn: frame= 101 fps=5.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.394x 2024-09-06 09:45:29.582 spawn: [mov,mp4,m4a,3gp,3g2,mj2 @ 0xaaaaebf56900] Failed to seek for auxiliary info, will only parse senc atoms for encryption info 2024-09-06 09:45:29.939 spawn: frame= 101 fps=4.9 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.384x 2024-09-06 09:45:30.439 spawn: frame= 101 fps=4.8 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.375x 2024-09-06 09:45:30.940 spawn: frame= 101 fps=4.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.366x 2024-09-06 09:45:31.440 spawn: frame= 101 fps=4.6 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.358x 2024-09-06 09:45:31.940 spawn: frame= 101 fps=4.5 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.35x 2024-09-06 09:45:32.440 spawn: frame= 101 fps=4.4 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.343x 2024-09-06 09:45:32.940 spawn: frame= 101 fps=4.3 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.335x 2024-09-06 09:45:33.440 spawn: frame= 101 fps=4.2 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.328x 2024-09-06 09:45:33.941 spawn: frame= 101 fps=4.1 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.322x 2024-09-06 09:45:34.441 spawn: frame= 101 fps=4.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.315x 2024-09-06 09:45:34.941 spawn: frame= 101 fps=4.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.309x 2024-09-06 09:45:35.441 spawn: frame= 101 fps=3.9 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.303x 2024-09-06 09:45:35.941 spawn: frame= 101 fps=3.8 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.297x 2024-09-06 09:45:36.441 spawn: frame= 101 fps=3.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.292x 2024-09-06 09:45:36.942 spawn: frame= 101 fps=3.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.287x 2024-09-06 09:45:37.176 subscription: 008D: service instance is bad, reason: No input detected
8598b8f7b4ab51f8896a4595e79f0178:93c312329ca3a547a06806ac65ee38db ce2628865e78561abddf0be999375c3e:b8003eef33b48401893311623cb722ca 5ed1d6ff484d530db7a0b0d835b31b0a:187c603ad4a5de7fbcb3c641ba28075d
Thanks but unlocking is not the Problem... ffmpeg doesnt play it out in a pipe. Just a few seconds then it stops playing und stucks again with that logs:
ffmpeg:
Code:2024-09-06 09:45:28.906 spawn: [dash @ 0xaaaaeab9bac0] No longer receiving stream_index 8 2024-09-06 09:45:28.939 spawn: frame= 101 fps=5.2 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.404x 2024-09-06 09:45:29.439 spawn: frame= 101 fps=5.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.394x 2024-09-06 09:45:29.582 spawn: [mov,mp4,m4a,3gp,3g2,mj2 @ 0xaaaaebf56900] Failed to seek for auxiliary info, will only parse senc atoms for encryption info 2024-09-06 09:45:29.939 spawn: frame= 101 fps=4.9 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.384x 2024-09-06 09:45:30.439 spawn: frame= 101 fps=4.8 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.375x 2024-09-06 09:45:30.940 spawn: frame= 101 fps=4.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.366x 2024-09-06 09:45:31.440 spawn: frame= 101 fps=4.6 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.358x 2024-09-06 09:45:31.940 spawn: frame= 101 fps=4.5 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.35x 2024-09-06 09:45:32.440 spawn: frame= 101 fps=4.4 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.343x 2024-09-06 09:45:32.940 spawn: frame= 101 fps=4.3 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.335x 2024-09-06 09:45:33.440 spawn: frame= 101 fps=4.2 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.328x 2024-09-06 09:45:33.941 spawn: frame= 101 fps=4.1 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.322x 2024-09-06 09:45:34.441 spawn: frame= 101 fps=4.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.315x 2024-09-06 09:45:34.941 spawn: frame= 101 fps=4.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.309x 2024-09-06 09:45:35.441 spawn: frame= 101 fps=3.9 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.303x 2024-09-06 09:45:35.941 spawn: frame= 101 fps=3.8 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.297x 2024-09-06 09:45:36.441 spawn: frame= 101 fps=3.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.292x 2024-09-06 09:45:36.942 spawn: frame= 101 fps=3.7 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 q=-1.0 size= 3961KiB time=00:00:07.88 bitrate=4117.4kbits/s speed=0.287x 2024-09-06 09:45:37.176 subscription: 008D: service instance is bad, reason: No input detected
Hi @matthias1232
If I may ask, I have been trying compile/build the ffmpeg with your patch, but unfortenently when I have cloned your repo, configured it, and build it I am always stuck at: Unrecognized option 'cenc_decryption_keys'.
Can you assist how to compile it with your patch?
help with new license server for get decryption keys. (i have cdm keys)
By savi4u in forum Video Streaming DownloadingReplies: 11Last Post: 11th May 2024, 04:30 -
Widevine Content Key Decryption
By vfa1 in forum Video Streaming DownloadingReplies: 26Last Post: 12th Jan 2024, 06:23 -
NPO widevine decryption no longer working
By StukBetonijzer in forum Video Streaming DownloadingReplies: 35Last Post: 3rd Oct 2022, 10:29 -
MPD CENC Encrypted stream on ffmpeg
By Near773 in forum Video Streaming DownloadingReplies: 10Last Post: 6th Aug 2022, 09:57 -
widevine decryption help
By birbal1 in forum Video Streaming DownloadingReplies: 2Last Post: 5th Dec 2021, 11:11
