Hello kind forum residents!
I'm facing this problem, I can't upload a video:
https://privnote.com/DeSZt4ce#5DO1XlCXf
The link m3u8 does not give any stream, yt-dlp gives an error:
WARNING: [generic] Falling back on generic information extractor
WARNING: [generic] URL could be a direct video link, returning it as such.
ERROR: [generic] dcec2046-4c2b-4367-8ca5-ebf9da43ffc1: Requested format is not available. Use --list-formats for a list of available formats
Can you please tell me which way to dig? As I understand, the stream is encrypted? I will be grateful for any help.
https://www.transfernow.net/dl/20240905qCkPAAg9
Edit: no idea why you've hidden that video URL on a link that will soon expire.
https://stream.online-academy.ir//axqatxyj3i3y//iframe--[----->+<]>.++++++++++++.---.--------.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Thank you so much!
But can you explain to me at least briefly how exactly you downloaded it?
Is this program widefrog for this? -
It has nothing to do with it since it's not in the list of supported sites (you can read the post to see what's supported). As for how I did it briefly, I extracted the m3u8 file from the JS code.
video.txt
Change to m3u8 and run
For the extraction I went in the source code of adaptor.js and Ctrl+F searched for "parseLevelPlaylist = function" then I injected this code at the beginning of the functionCode:N_m3u8DL-RE video.m3u8
I refreshed the page, selected the 720p stream and downloaded locally the m3u8 file. Then I used N_m3u8DL-RE on it. For some reason the 360p doesn't work. Gives a lot of 403s. I am 100% sure there are easier and smarter solutions than this but I didn't care that much to bother looking for them. If it's too complicated, wait for someone else to post an easier solution.Code:const blob = new Blob([t], { type: "text/plain" }); const link = document.createElement("a"); link.href = window.URL.createObjectURL(blob); link.download = "video.m3u8"; document.body.appendChild(link); link.click(); document.body.removeChild(link);--[----->+<]>.++++++++++++.---.--------.
Very interesting.Code:
Kindly tell, is this a standard injected piece of code or is this code unique to this site?
A little explanation of this code would be interesting.
Thanks -
Eh, so-so. It's dependent on the input variable (among others). In this case it was a parameter that was only keeping a text string value. Usually I would have just placed a breakpoint and directly copy the value of the text. But it was too long to copy in debugger so I just saved it directly.
The piece of code is more like a template. You have to modify it accordingly to each site and know where to place it. Sometimes it may not be enough. For example you may want to save N keys for a HLS AES stream.
Eh, you basically save the text variable in a blob. Spawn a node <a></a> on the page. Make it redirect to a URL that points to that blob variable you created. Auto click it and then get rid of the spawned node.
But you shouldn't bother with such things. I only did it because I didn't wanna waste time understanding their m3u8 decryption method. It's laziness.--[----->+<]>.++++++++++++.---.--------.
@Pepe
Thanks for the reply and the explanation.
Not in my opinion. I consider it to be brilliant. This piece of code deserves a lot more studying (by me).Code:But you shouldn't bother with such things. I only did it because I didn't wanna waste time understanding their m3u8 decryption method. It's laziness.
You're an absolutely amazing programmer
Download/rip video Prime video (amazon)
By HDstream in forum Video Streaming DownloadingReplies: 3Last Post: 8th Jun 2024, 03:48 -
DOWNLOAD protected DRM video separated video and audio from (learnyst)
By yassin in forum Video Streaming DownloadingReplies: 4Last Post: 8th Jan 2024, 05:36 -
Cannot download encrypted m3u8 video, the video works on the website
By krestek in forum Video Streaming DownloadingReplies: 6Last Post: 21st Feb 2022, 15:27 -
Download HLS video using FFMPEG with separate video and audio URLs?
By oschrndz in forum Video Streaming DownloadingReplies: 2Last Post: 15th Dec 2020, 14:53 -
how to download a portion of video from m3u8 that has separate video audio.
By adi111 in forum Video Streaming DownloadingReplies: 8Last Post: 5th Aug 2020, 15:53
