Hi , any recommendations or alternatives to streamlink and ffmpeg to restream as there's high latency when using this method, it's a live stream and the latency is much important I usebut there is still high latency is there any solutions or applications I can use ?streamlink --ffmpeg-dkey 'th3Key' 'http://stream.com/dash/index.mpd' best --stdout | ffmpeg -flags low_delay -fflags +genpts -i - -map_metadata -1 -c:v copy -c:a copy -f mpegts out-to-server
thanks
hello, its possible to stream it without using streamlink or ffmpeg, but you would need a server to run it, only with mp4decrypt and custom software to generate the hls output.
hi , thanks for your reply, how can I do this what software should I use and of course I have servers
hi, for live streams you can use some converters like xaccel but i use another a custom made one which consumes much less resources.
Best way to Streamlink MPD DRM?
By membervip39 in forum Newbie / General discussionsReplies: 4Last Post: 18th Dec 2023, 07:55 -
TVheadend + streamlink-drm
By UrselP in forum Video Streaming DownloadingReplies: 0Last Post: 4th Dec 2023, 17:09 -
Best way to streamlink my DRM MPD?
By membervip39 in forum Video Streaming DownloadingReplies: 2Last Post: 27th Nov 2023, 12:34 -
streamlink + DRM keys
By skipmack46 in forum Video Streaming DownloadingReplies: 6Last Post: 6th Aug 2023, 17:35 -
restreaming to non-drm m3u8 from drm mpd
By grabyea in forum Video Streaming DownloadingReplies: 1Last Post: 8th Aug 2022, 00:35
