Page 3 of 6
FirstFirst 1 2 3 4 5 ... LastLast
Results 61 to 90 of 153
  1. Originally Posted by poisondeathray View Post
    Do you have avs+ installed, or is it a "portable" version with megui ? That might be why vdub2 doesn't work for you
    I have "portable" version with megui.
    What does this do? And to use it - I just Import() it in the script?
  2. Originally Posted by cinephil View Post
    Recall the error message was "I don't know what 'AvsPlusVersionNumber' means"
    There is an AvsPlusVersionNumber function included in Zs_RF_Shared.avsi, and you can Import() or let it autoload if it's in the Plugins directory
  3. THANKS poisondeathray! Now LSFmod is loading.
    But in older version of MeGUI/AviSynth+ not loading mlrt_ncnn, so I need to use MeGUI-6666.2308_x64 again
  4. If you want it fixed - someone should report the issue to the megui developers for that branch that AVS error messages are not being conveyed, instead it's just crashing (it shouldn't just crash)
  5. You should be able to "update" the old Megui version by dropping a newer Avisynth.dll version into the MeGui avs folder. (Make a backup of the old Avisynth.dll first)
    I'm assuming that's why it's not loading mlrt_ncnn ; since mlrt_ncnn has modern requirements including avs version
  6. Originally Posted by poisondeathray View Post
    I sent the report.
    It works that way, thanks.
    But not gives error messages
  7. Sadly with LSFmod I'm not get the look I wanted. So I trying the other way with WarpDeRing. But get this error
    [Attachment 82238 - Click to enlarge]
    LoadPlugin("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\ffms2.dll")
    FFVideoSource("E:\VR.5\SAMPLE\video\05-5D[JP]+.avi")
    #FFVideoSource("E:\VR.5\SAMPLE\video\video-film.avi")
    #FFVideoSource("E:\VR.5\SAMPLE\video\03-Sisters[JP].avi")
    #crop(6, 0, -8, 0)
    ColorYUV(gamma_y=-35, cont_y=48, gain_y=-10, off_y=0) #adjust gamma and contrast
    Tweak(bright=16, coring=false)  #adjust brightness
    Tweak(Sat=1.2, startHue=80, endHue=135) # "red" pixels (boost up)
    Tweak(Sat=1.2, startHue=325, endHue=15) # "blue" pixels (boost up)
    LoadPlugin("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\fft3dfilter.dll")
    FFT3DFilter(bt=-1, sharpen=0.7, interlaced=true)
    #FFT3DFilter(bt=1, sigma=0.3, plane=0, bw=16, bh=16, ow=8, oh=8, ncpu=4, sharpen=0.6, interlaced=true)
    #FFT3DFilter(bt=1, sigma=0.7, plane=3, bw=16, bh=16, ow=8, oh=8, ncpu=4, sharpen=0.9, interlaced=true)
    LoadPlugin("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\nnedi3.dll")
    LoadPlugin("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\FillBorders.dll")
    Import("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\Zs_RF_Shared.avsi")
    Import("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\WarpDeRing.avsi")
    SeparateFields()
    warpdering()
    Weave()
    ConvertBits(32)
    ConvertToPlanarRGB(matrix="Rec709", interlaced=true)
    #SeparateFields()
    #LoadPlugin("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\mlrt_ncnn.dll")
    #mlrt_ncnn(network_path="1x_BleedOut_Compact_300k_net_g.onnx")
    #Weave()
    ConvertBits(8)
    ConverttoYv12(matrix="Rec709", interlaced=true)
    WarpDeRing:
    # WarpDeRing v1.0 by mirkosp
    # HBD mod 1.1
    # 	Uses aWarpSharp2's flattening to clean out ringing/smaller halos,
    # 	then runs some masks to preserve the edges and avoid the thinning.
    # 	This is nothing really new but it kind of just works, so eh.
    #	Calling the filter more times in a row is probably more effective than toying with the parameters.
    #	Only really tested out with a DVD, probably only works as intended on SD sources.
    #	For HD, it might need some more mt_expand() in the owarp clip (I don't think, though).
    #	Oh, and it's for newer and minor stuff, like downscaled HD sources released only on DVD and so on.
    #	Don't expect this to work on Trigun. Or, well, I guess it could work, but... you know the deal.
    # strength is the warpsharpening depth, so higher values nail more things
    # tmax and tmin work out the hysteresis mask for the final masking pass
    # Requirements:
    # 	awarpsharp2 http://forum.doom9.org/showthread.php?t=147285
    # 	mt_masktools https://github.com/tp7/masktools
    # 	nnedi3 http://web.missouri.edu/~kes25c/
    # 	fillmargins http://www.avisynth.nl/users/warpenterprises/
    function warpdering(clip c, int "strength", int "tmax", int "tmin") {
    sisavs26 = !(VersionNumber() < 2.60)
    strength = default(strength,6)
    tmax = default(tmax,10)
    tmin = default(tmin,7)
    c
    addborders(4,4,4,4)
    fillmargins(4,4,4,4)
    warp = awarp4(nnedi3_rpow2(rfactor=2).nnedi3_rpow2(rfactor=2),asobel(thresh=255).ablur(),depth=strength)
    owarp = mt_merge(last,warp,sisavs26 ? vsTEdgeMask(threshY=0,threshU=0,threshV=0).mt_expand().mt_expand().mt_expand().mt_expand().mt_expand().blur(1) : tedgemask(valon=-1).mt_expand().mt_expand().mt_expand().mt_expand().mt_expand().blur(1),true,u=3,v=3)
    mt_merge(owarp,last,mt_hysteresis(sisavs26 ? vstedgemask(threshy=tmax) : tedgemask(threshy=tmax),sisavs26 ? vstedgemask(threshy=tmin) : tedgemask(threshy=tmin)).blur(1),true,u=3,v=3)
    crop(4,4,-4,-4)
    function warpdering_faster(clip c, int "strength", int "tmax", int "tmin") {
    sisphbd = AvsPlusVersionNumber > 2294
    sischbd = sisphbd ? c.BitsPerComponent() > 8 : false
    c
    addborders(4,4,4,4)
    warp = awarp4(nnedi3_rpow2(rfactor=2).Spline36Resize(width*4, height*4, 0.25, 0.25),asobel(thresh=255).ablur(),depth=strength, chroma=1)
    owarp = mt_merge(last,warp,sischbd ? vsTEdgeMask(threshY=0,threshU=0,threshV=0, u=1, v=1).mt_expand().mt_expand().mt_expand().mt_expand().mt_expand().blur(1) : TEMmod(threshY=0,chroma=0).mt_expand().mt_expand().mt_expand().mt_expand().mt_expand().blur(1),true,u=1,v=1)
    mt_merge(owarp,last,mt_hysteresis(sischbd ? vstedgemask(threshy=tmax, u=1, v=1) : sischbd ? vstedgemask(threshy=tmax, u=1, v=1) : TEMmod(threshy=tmax,chroma=0),TEMmod(threshy=tmin,chroma=0)).blur(1),true,u=1,v=1)
    crop(4,4,-4,-4)
    Mergechroma(c)
  8. Do you have new version of FillBorders.dll or old version of FillMargins ?
    https://github.com/Asd-g/AviSynth-FillBorders/releases
  9. Originally Posted by poisondeathray View Post
    I got FillBorders-1.4.2.
  10. Not sure, it works for me
    How about simple colorbars with warpdering ? Do you get same error ?
    colorbars(pixel_type="YV12")
    warpdering()
  11. Originally Posted by poisondeathray View Post
    Yes. The same error.
  12. Try explicitly filling in the values, such as fillmargins(clip=c, left=4, top=4, right=4, bottom=4)
  13. Originally Posted by poisondeathray View Post
    If I use it like this in the script:
    warpdering(fillmargins(clip=c, left=4, top=4, right=4, bottom=4))
    then get the error:
    [Attachment 82242 - Click to enlarge]
    If like this:
    warpdering(fillmargins(left=4, top=4, right=4, bottom=4))
    The error is the same as was before.
  14. I meant edit line 31 in warpdering.avsi to say fillmargins(clip=c, left=4, top=4, right=4, bottom=4) , save it
    In the script you still call with warpdering()
    What avs version are you using ? If you don't know
    version()
    Do you have a clean plugins folder ? could there be conflicting functions or plugins with same name that autoloaded ? If so , clean out the plugins folder
  15. Originally Posted by poisondeathray View Post
    I cleaned the folders (leaving archived plugins inside) and after loading MeGUI - it auto-downloaded plugins and wiped out archives, that was left in folders
    So I returned the needed plugins.
    The one that able to give error messages:
    [Attachment 82243 - Click to enlarge]
    New error is:
    [Attachment 82244 - Click to enlarge]
  16. fillmargins has an argument named clip, so I don't know what that error message is about, but try omitting the clip argument, just explicitly enter the left,top,right,bottom , save it
    FillMargins (clip, int "left", int "top", int "right", int "bottom", int "y", int "u", int "v")
    Also update your avs+ version, avs+ 3.5 r3106 is a few years old and incompatible with things like avs-mlrt . Hundreds of bug fixes since then
  17. Originally Posted by poisondeathray View Post
    The error the same
    [Attachment 82245 - Click to enlarge]
    If I replace it with the new one (avs+ 3.7.3 r4003) - it crashing on the loading script attempt and not give error messages.
    Guess I'm not in luck with the fight against halos and ghosts
  18. No idea, might be a megui issue. I can't reproduce the error with avs+ only
    Not sure if it will make a difference, but I'm using r4066 from here
    http://forum.doom9.org/showthread.php?t=181351
  19. Guess I need take a break and wait for new MeGUI releases.
  20. It's a bad thing that some part of the Histogram sink in 0-16 area? Or it's just a noise in there?
    FFVideoSource("E:\VR.5\SAMPLE\video\05-5D[JP]-endT.avi")
    ConvertBits(16)
    ColorYUV(gamma_y=-35, cont_y=46, gain_y=-10, off_y=0)
    Tweak(bright=10, coring=false)
    Tweak(Hue=-16)
    Tweak(sat=1.1)
    FFT3DFilter(bt=-1, sharpen=0.3, interlaced=true)
    ConvertBits(bits=8, dither=1)
    ConvertToYV12(matrix="rec601", interlaced=true)
    Histogram("levels")
    TurnRight().Histogram().TurnLeft()
    [Attachment 82331 - Click to enlarge]
  21. Originally Posted by cinephil View Post
    Yes and no. In that particular case the data below Y=16 is just overshoots from over sharpening or compression artifacts around the bright white text. What you want to avoid is significant parts of the picture falling below that level. In that shot the black background is a little above Y=16.
  22. Originally Posted by poisondeathray View Post
    It is not named argument - it is simply first argument in a call and it must be clip (source clip to process). So in AVS it is either 'last' auto-argument in a script or user-provided clip (of any name).
    Like
    my_clip=ColorBars()
    FillMargins(my_clip, left=5)
    should work the same (in simple example)
    ColorBars()
    FillMargins(left=5)
    as standard AVS filters. Sometime filter do not accept name=value method (that allow to provide arguments in any order) and require arguments to be in order as compiled.
    See sources where AddFunction() is located - it have list of all agruments (and names if persent) - https://github.com/Asd-g/AviSynth-FillBorders/blob/e641c36e99f8d55b6e58b7f82e5ba282588...rders.cpp#L759 First param is c - it is unnamed param of clip-type. If param have name it is encoded as [name]type .
  23. Originally Posted by DTL2023 View Post
    my_clip=ColorBars()
    ColorBars()
    FillMargins(left=5)
    In my setup I still get this error: the named argument "left" was passed more than once to FillBorders.
  24. Is there a version of ContrastMask filter that works in 16 Bit depth? I have good result with it, but since it works only in 8 Bit depth - I ended up with banding in histogram
  25. Assuming ContrastMask, is this script:
    function ContrastMask(clip v, float "gblur", float "enhance")
      enhance = default (enhance, 10.0)
      tvcolor = default (tvcolor, true)
      gblur = default (gblur, 20.0)
      enhance = (enhance>=0.0 && enhance<=10.0) ? float(enhance*0.1) : 1.0
      v2=v.Tweak(sat=0)
      v2=v2.invert()
      v2=v2.gaussianblur(50.0,50.0+gblur)
      photoshop_overlay=mt_lutxy(v,v2,"x 127.5 > y 255 x - 127.5 / * x 255 x - - + y x 127.5 / * ? ")
      merged=overlay(v,photoshop_overlay,opacity=enhance)
      return merged
    source: https://forum.doom9.org/showthread.php?p=1514814#post1514814
    try:
        enhance = default(enhance, 10.0)
        gblur = default(gblur, 20.0)
        enhance = (enhance >= 0.0 && enhance <= 10.0) ? float(enhance * 0.1) : 1.0
        # Get the bit depth and scaling factors
        bit_depth = v.BitsPerComponent()
        max_val = pow(2, bit_depth) - 1
        half_max_val = max_val / 2.0
        # Convert to grayscale and invert
        v2 = v.Tweak(sat=0)
        v2 = v2.Invert()
        # Apply Gaussian blur
        v2 = vsTCanny (v2, sigmaY=gblur, mode=-1)
        # Construct the expression for mt_lutxy
        expr = "x {} > y {} x - {} / * x {} x - - + y x {} / * ?".format(half_max_val, max_val, half_max_val, max_val, half_max_val)
        # Apply the contrast mask effect
        photoshop_overlay = mt_lutxy(v, v2, expr)
        # Merge the original and overlay clips
        merged = Overlay(v, photoshop_overlay, opacity=enhance)
        return merged
    # requires: https://github.com/Asd-g/AviSynth-vsTCanny and  https://github.com/pinterf/masktools
    Example script usage:
    ClearAutoloadDirs()
    SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LSMASHSource.dll")
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\vsTCanny.dll")
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\masktools2.dll")
    Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi")
    # Load source
    LWLibavVideoSource("G:\TestClips&Co\files\10bit Test.mkv", cache=false, format="YUV420P10", prefer_hw=0, repeat=true)
    org = last
    # Apply ContrastMask
    ContrastMask(enhance=2.5)
    StackHorizontal(org, last)
    # Set output fps and prefetch
    AssumeFPS(25, 1)
    PreFetch(16)
    return last
    Here's also Vapoursynth variant if someone needs it-
    Cu Selur
    Last edited by Selur; 5th Oct 2024 at 11:04. Reason: Avisynth: mode=-1, link to Vapoursynth version
  26. Thanks, Selur.
    But I have some error:
    [Attachment 82675 - Click to enlarge]
    FFVideoSource("E:\VR.5\SAMPLE\video\03.avi")
    ConvertBits(16)
    LoadPlugin("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\aWarpsharpMT.dll")
    SeparateFields()
    MergeChroma(last, Spline36Resize(width/2, height).aWarpSharp2(depth=30).nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=width, fheight=height))
    Weave()
    LoadPlugin("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\vsTCanny.dll")
    LoadPlugin("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\masktools2.dll")
    Import("M:\edit\MeGUI-6666.2308_x64\tools\avs\plugins64\ContrastMask2.avsi")
    SeparateFields()
    even = SelectEven(last).ContrastMask(enhance=3.0)
    odd = SelectOdd(last).ContrastMask(enhance=3.0)
    Interleave(even, odd)
    Weave()
    ColorYUV(gamma_y=-35, cont_y=46, gain_y=-10, off_y=0) #gain_y=-10
    Tweak(bright=3, coring=false)
    Tweak(cont=0.9)
    Tweak(Hue=-16)
  27. You are using Avisynth+, right?
    https://avisynthplus.readthedocs.io/en/master/avisynthdoc/syntax/syntax_internal_funct...ng.html#format
    if not, replace that line with:
    expr = f"x {half_max_val} > y {max_val} x - {half_max_val} / * x {max_val} x - - + y x {half_max_val} / * ?"
    from the original version code. (not sure whether vsTCanny and current masktools work with old Avisynth versions)
  28. My bad, I opened script with older MeGUI version (that able to give script error messages) and had this error. But it work with latest MeGUI/Avisynth+ fine. Just not match with brightness from my old ContrastMask script, but I guess will find right values.
    Thanks.
  29. Hmm... I getting this line in the histogram, that not was there before. And some color bars on the black border from MergeChroma/aWarpSharp, that was eliminating with old ContrastMask. Can it be fixed?
    [Attachment 82676 - Click to enlarge]
    FFVideoSource("E:\VR.5\SAMPLE\video\03-Sisters[US].avi")
    ConvertBits(16)
    SeparateFields()
    Weave()
    SeparateFields()
    ContrastMask(enhance=1.2)
    Weave()
    Tweak(cont=0.9)
    Tweak(Hue=-16)
    Histogram("levels")
    Histogram("color2")
  30. Originally Posted by cinephil View Post
    The horizontal line is the midpoint indicator for histogram() - it's normal . It might have displayed slightly differently in older avs versions. You can test it yourself on a black synthetic video, it's still there
    blankclip(pixel_type="YV12")
    turnright()
    histogram()
    turnleft()
    You can crop() the borders and add clean borders back with addborders() near the end of the script
