I'm encoding a television show. After deinterlacing, several of the episodes have a shimmer in certain scenes of the episode. QTGMC InputType=1 cleans this up nicely. That said it's taking me a lot of time to go through every episode. Is QTGMC InputType=1 destructive? I would like to filter all episodes with QTGMC InputType=1 to save time but if it is destructive I'll check each episode.
And more, are you sure you need to deinterlace at first? Many TV Shows are not interlaced. Add then apply additional QTGMC with progressive settings?
Post a sample of the source -
Yes, like (as good as) every filter out there, QTGMC with InputTpe=1 can cause issues depending on the source and the other settings.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
It's a telecined animation with some scenes and credits completely interlaced. I'm bobing them to keep the additional 59.94fps motion in the areas where it is interlaced. There is also a lot of dot crawl which QTGMC is fixing. Here is a clip of a scene I'm dealing with that has some shimmering. Look at the books/magazines in the back after using QTGMC(Preset="medium"). Filtering with QTGMC InputType=1 after deinterlacing fixes this.
QTGMC(InputType=1) does eliminate the shimmering but it does causes some sharpening and mild damage to other parts of the picture. You can eliminate the sharpening with Sharpness=0. You can interleave() before and after and use an editor to step back and forth between the two.
I use VirtualDub2 to view the results and Windows Magnifier to zoom in 4x. Judge for yourself whether it's a problem.Code:# output of your QTGMC() Interleave(last, QTGMC(InputType=1, Sharpness=0)
The better fix would be to use TFM().TDecimate().ChangeFPS(60000,1001) on the parts that IVTC cleanly, then trim and paste the IVTC and QTGMC sections together.
Why is QTGMC so destructive and why do so many people still recommend it?
By sebastiaaan in forum RestorationReplies: 84Last Post: 11th Apr 2026, 16:54 -
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 02:01 -
deflicker with QTGMC
By taigi in forum RestorationReplies: 1Last Post: 12th Oct 2021, 06:48 -
different fps with QTGMC
By taigi in forum RestorationReplies: 5Last Post: 29th May 2021, 06:28 -
Help with QTGMC
By Xyena in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2020, 12:25
