Results 1 to 11 of 11
  1. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Try eme logger. If you can't find it even with that, then it doens't use DRM most likely, check for the small DRM icon in the adress bar
  2. Member aqzs's Avatar
    Mar 2024
    Paris
    Indeed :
    N_m3u8DL-RE "https://vod05.msf.cdn.mediaset.net/farmunica/2024/08/1932417_1917a772c75645/dashrcclean/hd_no_mpl.mpd" --save-name "Oscar.Pistorius" -sv best -sa all -ss all -mt -M format=mkv  --log-level OFF
    Download link : https://gofile.io/d/A5Kn8Q
  3. Thanks aqzs , only possible way with N_m3u8DL-RE ?
  4. Thanks Lomero, only possible way with yt-dlp ?
  5. Member aqzs's Avatar
    Mar 2024
    Paris
    Enter video URL: https://mediasetinfinity.mediaset.it/video/giocosporco/diego-armando-maradona_F313159202001C01
    N_m3u8DL-RE "https://vod05.msf.cdn.mediaset.net/farmunica/2024/08/1932416_1917a74552d645/dashrcclean/hd_no_mpl.mpd" --save-name "Diego.Armando.Maradona" -sv best -sa all -ss all -mt -M format=mkv  --log-level OFF
    I don't see a PSSH there
  6. aqzs if it's drmless there's never a pssh?
  7. Originally Posted by aqzs View Post
    my mistake maybe.
