N_m3u8DL-RE_v0.2.1-beta just released
What's Changed
ver. 20240828
Dash Role Scheme support by @Diazole
Fix the error caused by multiple decryptions of local files The input data is not a complete block by @BlueHtml
try using shaka packager, which can handle WebM, to get KID by @hyww
Support Dolby Vision ISM parsing by @nilaoda
Force the display of progress bar and other information in non-ansi environment by @RikaCelery
Optimize the log file generation logic by @nilaoda
Add a retry mechanism when loading a URL for the first time by @nilaoda
Fix the abnormal reading of KID of multiple DRM files by @AdiEcho
Add a bitrate selector and fix 2 bugs by @geniuszxy
New option --use-ffmpeg-concat-demuxer 836a908
New option --max-speed eb85df8
New option --live-take-count e3c4cbb
https://github.com/nilaoda/N_m3u8DL-RE/releases
Results 1 to 13 of 13
This version was out for a while already. You can fork the repo and edit the workflow on your own to release the latest build :
Or grab the artifacts from the build even if publish release is unticked : https://github.com/nilaoda/N_m3u8DL-RE/actions/runs/10598853685Code:.github/workflows/build_latest.yml
On this repo only nilaoda is able to build but if you fork you will be able to lunch a build after each change. -
[Attachment 81833 - Click to enlarge]
btw i have this problem the video is downloading but no downloading infos in command line very weird
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
ok which command to use for mkvmerge muxing?
last question which ffmpeg version ?
https://www.gyan.dev/ffmpeg/builds/ffmpeg-release-essentials.zip
https://www.gyan.dev/ffmpeg/builds/ffmpeg-release-full.7z
https://www.gyan.dev/ffmpeg/builds/ffmpeg-release-full-shared.7z -
You can always get direct help from the command line
>N_m3u8DL-RE.exe --morehelp mux-after-done
More Help:
--mux-after-done
When all works is done, try to mux the downloaded streams. OPTIONS is a colon separated list of:
* format=FORMAT: set container. mkv, mp4
* muxer=MUXER: set muxer. ffmpeg, mkvmerge (Default: ffmpeg)
* bin_path=PATH: set binary file path. (Default: auto)
* skip_sub=BOOL: set whether or not skip subtitle files (Default: false)
* keep=BOOL: set whether or not keep files. true, false (Default: false)
Examples:
# mux to mp4
-M format=mp4
# use mkvmerge, auto detect bin path
-M format=mkv:muxer=mkvmerge
# use mkvmerge, set bin path
-M format=mkv:muxer=mkvmerge:bin_path="C\:\Program Files\MKVToolNix\mkvmerge.exe"--[----->+<]>.++++++++++++.---.--------.
download any one you just need the ffmpeg.exe file located in the BIN folder of the package, this is fine
https://www.gyan.dev/ffmpeg/builds/ffmpeg-git-essentials.7z -
Not sure if it's a bug or if the developer changed it, but with --log-level OFF, it’s supposed to show only the download progress. However, in version v0.2.1, it's showing nothing, and the download progress is just hidden
'--log-level OFF' with 'v0.2.0':
[Attachment 81837 - Click to enlarge]
N_m3u8DL-RE: Giving It A Try
By Tom Saurus in forum Video Streaming DownloadingReplies: 110Last Post: 5th Aug 2025, 23:08 -
N_m3u8DL-RE Tutorial
By Subtitles in forum Video Streaming DownloadingReplies: 13Last Post: 28th May 2025, 09:19 -
Need help me getting the N_m3u8DL-RE
By mrsimple8x in forum Video Streaming DownloadingReplies: 2Last Post: 19th Dec 2023, 08:29 -
Help with N_m3u8DL-RE and MPD
By sparklescale in forum Video Streaming DownloadingReplies: 4Last Post: 21st Jun 2023, 00:31 -
ED Beta Metal tape in a Regular Beta VCR ? Does it work?
By Tom81 in forum MediaReplies: 1Last Post: 4th Mar 2020, 02:55
