Recently discovered AnyDVD is no more.
My setup is as follows :
Main PC is used to RIP the discs. I installed Xreveal there and was able to rip the Bluray in its full native folder structure.
Server PC. This is running EMBY. This is where I transfer the ripped movies to (from the main PC located in office).
HTPC is in the theater room and runs Win7 with WMC and the Emby for WMC program. I use this interface in the theater room to browse and play my movie collection which is located on the Server PC (also running Emby Server). The HTPC uses TMT6 to play the movies from the server.
The PROBLEM :
The movie I just ripped with Xreveal will not play on the HTPC (which is using TMT6 as the playback program).
Any ideas of how to get the ripped movie to play through TMT6?
I should state that I did purchase Xreveal PRO.
THANKS!
Results 1 to 1 of 1
Blurry Playback from ONLY SOME Ripped DVDs in UK PAL
By Johnnysh in forum DVD RippingReplies: 0Last Post: 12th Mar 2023, 10:47 -
USA bluray (23.9fps) vs EU bluray (24-25fps): how are created?
By precipizio in forum Blu-ray RippingReplies: 12Last Post: 29th May 2022, 13:44 -
Matrix Resurrections Bluray - Can I rip with an old Pioneer Bluray writer??
By projinf3d in forum Blu-ray RippingReplies: 3Last Post: 11th Apr 2022, 03:54 -
Anyway to tell if a video was ripped from BluRay?
By guy24s in forum Blu-ray RippingReplies: 3Last Post: 6th Aug 2021, 12:10 -
Panasonic BDT110 Does not Playback DTS of Ripped DVD/Blue Ray Streaming
By Laz Baz in forum Video Streaming DownloadingReplies: 3Last Post: 26th Nov 2019, 20:14
