Whenever there is a new update for Subtitle Edit I always see updates to translations in the version history. Perhaps not all the same every time.
* Update Chinese translation - thx nkh0472
* Update Italian translation - thx bovirus
* Update Polish translation - thx admas
* Update French translation - thx Pierre
* Update Greek translation - thx PMitsakis
* Update Spanish translations - thx jmaraujouy
I’m unaware of SE doing it’s own translation so what are these updates referring to?
They refer to the people who update/create translations.
Subtitle Edit - delete video and subtitle file after processing?
By svcds in forum SubtitleReplies: 0Last Post: 4th Jan 2024, 05:45 -
Subtitle edit - How to put 'A with a dash on top' in subtitle edit?
By SSEN in forum SubtitleReplies: 5Last Post: 21st Sep 2023, 20:57 -
Subtitle Edit : Capitalize Subtitle to Normal Subtitle incomplete
By kalemvar1 in forum SubtitleReplies: 6Last Post: 5th Aug 2023, 12:28 -
Subtitle Edit - Shortcut to set a subtitle minimum gap
By tren in forum SubtitleReplies: 2Last Post: 1st Aug 2023, 06:44 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52
