Results 1 to 14 of 14
  1. I cant get it to work, it constantly says that it fails, translating individual works.
    Thanks,
    Mondriaan
  2. Ok i know enough for the LibreTranslate (14 dollar per month, are they crazy?).
  3. I installed the Ollama plugin because SubtitleEdit has it in the list for batch translation, the plugin works for normal translation but in a batch Subtitle Edit freezes and becomes unresponsive so i have to terminate the process
  4. You can translane any subtitles in Chrome. Open srt file with Google browser.
    Translate into the required language in browser.
    Ctrl + A
    Ctrl + C
    Create new srt file
    Ctrl + V
  5. Subtitle Edit can do the job in a batch, chrome does it one by one (worthless).
  6. Member Cornucopia's Avatar
    Sounds reasonable if you're doing this regularly.
  7. Apparently it's a fake option.
  8. I asked the Creator of Subtitle Edit,
    Hi ,
    This freeze in Ollama batch translate is a bug - should hopefully be fixed in next update.
    Best regards
    Nikolaj
    Hail Nikolaj.
  9. Originally Posted by Cornucopia View Post
    Wrong answer
  10. Member Cornucopia's Avatar
  11. The Ollama plugin works now, nice, its not fast enough to be called a commercial tool but i can be satisfied.
  12. What format are the subs? If it's SRT or VTT you can translate 10 subtitles at once here:
    https://subtitleone.cc/translation/
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    Crappy site.
    Please allow ads on our site
    Your browser seems to have prevented ads from showing on our site. It may be caused by one of the following:
    An adblocker prevented ads from being shown on our site
    Your browser privacy settings is set to Strict mode
    Your browser (especially Firefox) is in private or incognito mode
    Your VPN is blocking the ads
    Your have (anti-malware) browser guard installed that also blocks our ads
    Please allow or whitelist ads from our site as we rely on advertising to help fund our site. Let us know if the issue persists after addressing the possible cause above and refreshing the page. You can also try the following to fix the issue:
    Turn your VPN off
    Use other browsers like Firefox, Chrome, Microsoft Edge, or other modern browsers
    Upgrade your browser to the latest version
    Use another device or computer
    Check whether your antivirus or firewall program is blocking the ads, and whitelist our site (We don't recommend turning off your antivirus or firewall program)
    We do not collect Personally Identifiable Information on this site. Our site is 100% safe and does not contain malware whatsoever. Please see our privacy policy if you have questions about your privacy.
    I have no adblocker or vpn or anything like that. Ads works on ALL other sites.
  14. I have no adblocker or vpn or anything like that. Ads works on ALL other sites.
    It works for me. Not sure what's wrong there.
    Were you able to see ads at all?
Name:	Screenshot 2024-11-20 at 1.40.04 AM.png
