Hello,
currently i have some series in my Computer. These series are in mkv-format.
Every episode contains 6 chapters
Now i would like to remove the Intro and Outro (chapter 2 and 5) of every episode.
I started with some powershell code and tried MKVToolNix, but i stuck a bit.
What is the easies way to achieve this? I thought about extracting chapters information, splitting the file regarding the extracted information, delete chapters 2 and 5 from the splitted files and from the chapters information and then merge the remaining splitted chapters and the edited chapters information back into one file. Is that the most effective way or can you tell me a better way?
Many Thanks in advance![]()
This is the way to go.
You can use clever FFmpeg-GUI.
Load your episode, click main, click extract streams, diselect all streams except the chapters stream, click extract.
Then click chapters, click deactivate (to deactivate the embedded chaperts), click external file and search for the extracted chapters txt file.
Click Edit chapters, delete chapters 2 and 5 and save the file.
Click main, click multiplex and click multiplex.
Done.
how to cut out adverts from video files automatically need software to do i
By elm in forum EditingReplies: 5Last Post: 29th Apr 2024, 02:08 -
Software to automatically create chapters/ bookmarks in screen recorded vid
By nille1234567 in forum Video Streaming DownloadingReplies: 0Last Post: 15th Apr 2024, 02:48 -
delete files in a folder
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 9th Feb 2023, 19:57 -
Handbrake automatically resizing files
By techmot in forum EditingReplies: 5Last Post: 30th Dec 2022, 15:42 -
Chapters From (TXT) Text Files?
By TheShortStraw in forum EditingReplies: 4Last Post: 3rd May 2022, 21:47
