Results 1 to 10 of 10
  1. Could you please help me get this file: “https://www.visir.is/g/20242608143d/sjadu-myndirnar-fra-ungfru-island”? Yt-dlp does not cut it this time.
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    yt-dlp "https://vod.visir.is/hls/b34644f6-5713-4da1-8175-4d094148800f/b34644f6-5713-4da1-8175-4d094148800f-1723678221710.m3u8"
    https://www.transfernow.net/dl/20240823rJNmo7uq
    Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 23rd Aug 2024 at 10:20. Reason: changed to yt-dlp
  3. You are awesome!
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    No problem. Yt-dlp failed because you were using it wrong. It's meant to be used with m3u8's/mpd's. If you used yt-dlp with direct page URLs and it happened to work that's because you got lucky. They have a list of supported sites, but in general, just grab the m3u8/mpd and use it on yt-dlp. Stream detector is nice addon that displays m3u8/mpd and can be used to generate the download command with 1 click on a dropdown list
  5. i really need to move to iceland.
  6. Last edited by videoAI; 24th Aug 2024 at 15:28.
    Apr 2024
    Mediterranean
    quite accidenally i skipped to 32'.
    nah, same polit. correct all across eu....
    "stream recorder" chrome/edge extension dloads this....
  8. Thanks to all of you for your comments. I managed to download the file through the transfernow hosting service. By the way, Stream Detector in my Firefox browser does not detect any streams on even simplest web-sites. Are there any similar Firefox addons up-to-date?
  9. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    This one works fine
    https://addons.mozilla.org/en-US/firefox/addon/hls-stream-detector/
    Make sure you have "disable detection" not selected and refresh the page while keeping it open and look in "Current Tab". If it doesn't work on a site, then that's because it doesn't use m3u8/mpd. You can try it on
    https://bitmovin.com/demos/stream-test/
