Hi all!
Could only grab segments from France TV,a concert from Gossip this evening!
Link:
https://live-event.ftven.fr/ZXhwPTE3MjQzNzc5NjJ+YWNsPSUyZip+aG1hYz1lOTQxZGJhYTc3NjRjMD...s?m=1724338516
Parts from the txt.file
#EXTM3U
#EXT-X-VERSION:3
#EXT-X-TARGETDURATION:10
#EXT-X-MEDIA-SEQUENCE:993
#EXT-X-KEY:METHOD=AES-128,URI="https://d1y5bfp62l5lyv.cloudfront.net/wildmokajo/c00f3382-f51b-4637-88cd-3d68c10e8958"
#EXTINF:10.000,
index_monde_11_993.ts?m=1724338516
#EXTINF:10.000,
index_monde_11_994.ts?m=1724338516
#EXTINF:10.000,
index_monde_11_995.ts?m=1724338516
#EXT-X-KEY:METHOD=AES-128,URI="https://d1y5bfp62l5lyv.cloudfront.net/wildmokajo/8e2d4ba7-142c-41fc-9e89-90f5d453a5c4"
#EXTINF:10.000,
index_monde_11_996.ts?m=1724338516
#EXT-X-DISCONTINUITY
#EXTINF:10.000,
index_monde_11_997.ts?m=1724338516
#EXTINF:2.000,
index_monde_11_998.ts?m=1724338516
#EXTINF:0.640,
index_monde_11_999.ts?m=1724338516
#EXT-X-ENDLIST
Now I got all segments on my HD,want to mux to one file!
How could I go to run the without AES?
Greetings,
gr
Results 1 to 11 of 11
Give me channel (2/3/4/5/..) and the date + hours I'll send you a command to download. You will use N_m3u8DL-RE
Read his comment more carefully.
I believe he managed to downloading something from the livestream, before it ended (that's why it's not available right now). And he wants to know if he can salvage it. The gossip concert was in 22 aug
https://www.rockenseine.com/en/artist/gossip
The entire festival is between 21-25 aug
Edit: now that I look more closely at other concerts from the same festival in france.tv, they appear to be working, so maybe the issue is temporaryLast edited by 2nHxWW6GkN1l916N3ayz8HQoi; 23rd Aug 2024 at 03:04.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Now available.
Downloaded with yt-dlp
your fileCode:yt-dlp -N8 https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428750-gossip-en-concert-a-rock-en-seine-2024.html
https://www.swisstransfer.com/d/ff2e2ba2-c824-4217-a77e-0b265e99e0e0 -
He provided only a fragment link, we can't do anything with that..
Since the video is available now here is a download command with N_m3u8DL-RE :
Download link : https://gofile.io/d/XcRr6C (just in case)Code:Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428750-gossip-en-concert-a-rock-en-seine-2024.html N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ0MjQ4MjZ+YWNsPSUyZip+aG1hYz00YTliMzYxOTRjNDc1YmMzNjE3NzUwYjk1NDRjZDMzOGQ0MDNjMTE3MWZhMDA0MTlkMzkxMjYwZDM2Y2Q3MGQ1/ea87044a97c66/c2ed4841-58ce-41b4-a012-1a675408ebf4-1724359220_monde_TA.ism/manifest.mpd?hdnea=exp=1724403826~acl=%2f*~hmac=bd99250f6f40ab8ed9eafa41f3afddb53a8e81607cab6b44c891f3bbedc32fd1" --save-name "Gossip.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF
As cedric said, for DRM free content you better be using yt-dlp ! -
Hi all!
Today running all shows at once!
Link:
https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6429455-rock-en-sei...i-24-aout.html
Code for download,master file
https://live-event.ftven.fr/ZXhwPTE3MjQ1MzU2NTZ+YWNsPSUyZip+aG1hYz0yNTFiZDllOTQxODNjNT...dd93406cdba25c
I missed the first 90 min.
If similar .ts files are DRM protected...
Could I decrypt these?
Help was welcome
Those aren't protected, you can record the live using N_m3u8DL-RE.
Only last 5min are available.. I can't get 90min for you sorry. If the replay is available send like !
For now once N_m3u8DL-RE installed record using the index_monde.m3u8 link.
You can record for now like that :
Code:N_m3u8DL-RE 'https://live-ssai-v2.ftven.fr/ZXhwPTE3MjQ1MzcyNDh+YWNsPSUyZip+aG1hYz01OGQ3YjkyMWRmMDJjMmU4ZjYyZjM0YTE0NTdlOTIzZjAzY2NhZmQzNWQ2ODQ0ZGEwYmQ0YjEyMDdhODZjNjdl/daihttps://live-event.ftven.fr/out/v1/5e08de0e7446455c82454553c4d14e3d/start/1724503800/index_monde.m3u8?hdnea=exp=1724516248~acl=%2f*~hmac=90a2386b72bb6bf2eb7198dddf04d2bc2afcf8e295e5f3cc479ca435e3f1cfe9' --live-real-time-merge -M mkv --live-record-limit 4:22:00 --save-name "Rock.en.Seine.2024.Samedi.24.aout" -sa best -sv best -ds all --download-retry-count 60 --check-segments-count False --use-shaka-packager --decryption-binary-path SHAKAPATH
You can actually request all of the fragments that once played, but they're using AES-128 key rotation and the key changes every 60 seconds.
So it's impossible unless you knew every key that was in the manifest before.Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
I have recorded that for you : https://gofile.io/d/5ZXB0O, sorry for the trash quality
If you are interested by replays here https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/ 2024 :
Here is a reupload for you : https://gofile.io/d/8tqpb8Code:Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428762-olivia-dean-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjR+YWNsPSUyZip+aG1hYz1jYmQ4OWQ0NDJjZDVhMDVlNWU0MDdjZWFiNzQzMzYzMzQzYzgyNjJmZWJjYjRhMTU0ZjViNzk1ZDQ1ZDYwNzg2/d4391aacb8c66/17831b79-68b3-438c-b9fb-7926263508c6-1724433882_monde_TA.ism/manifest.mpd?hdnea=exp=1724590464~acl=%2f*~hmac=b8e731ef341cc9033198e1beab2115ab27560d4d8ae7f18920519a37923a66ee N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjR+YWNsPSUyZip+aG1hYz1jYmQ4OWQ0NDJjZDVhMDVlNWU0MDdjZWFiNzQzMzYzMzQzYzgyNjJmZWJjYjRhMTU0ZjViNzk1ZDQ1ZDYwNzg2/d4391aacb8c66/17831b79-68b3-438c-b9fb-7926263508c6-1724433882_monde_TA.ism/manifest.mpd?hdnea=exp=1724590464~acl=%2f*~hmac=b8e731ef341cc9033198e1beab2115ab27560d4d8ae7f18920519a37923a66ee" --save-name "Olivia.Dean.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428756-say-she-she-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjV+YWNsPSUyZip+aG1hYz1mYmY0ZDhhYmM5MGQ5ZmFmODZkYjU3OThmMDRkYjIzYTk1OTg0YjZhNjUzZmZjYzkzMDZhZmRkMTRlMzM3ZWQ0/aee5926a98c66/890cf79a-9ef4-4565-abf7-4709afa34ef0-1724423958_monde_TA.ism/manifest.mpd?hdnea=exp=1724590465~acl=%2f*~hmac=56a73157a315e8e9f927f385182c4d663b6e5a769bf61d3f09c877191b969633 N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjV+YWNsPSUyZip+aG1hYz1mYmY0ZDhhYmM5MGQ5ZmFmODZkYjU3OThmMDRkYjIzYTk1OTg0YjZhNjUzZmZjYzkzMDZhZmRkMTRlMzM3ZWQ0/aee5926a98c66/890cf79a-9ef4-4565-abf7-4709afa34ef0-1724423958_monde_TA.ism/manifest.mpd?hdnea=exp=1724590465~acl=%2f*~hmac=56a73157a315e8e9f927f385182c4d663b6e5a769bf61d3f09c877191b969633" --save-name "Say.She.She.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428750-gossip-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjV+YWNsPSUyZip+aG1hYz1mYmY0ZDhhYmM5MGQ5ZmFmODZkYjU3OThmMDRkYjIzYTk1OTg0YjZhNjUzZmZjYzkzMDZhZmRkMTRlMzM3ZWQ0/ea87044a97c66/c2ed4841-58ce-41b4-a012-1a675408ebf4-1724359220_monde_TA.ism/manifest.mpd?hdnea=exp=1724590465~acl=%2f*~hmac=56a73157a315e8e9f927f385182c4d663b6e5a769bf61d3f09c877191b969633 N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjV+YWNsPSUyZip+aG1hYz1mYmY0ZDhhYmM5MGQ5ZmFmODZkYjU3OThmMDRkYjIzYTk1OTg0YjZhNjUzZmZjYzkzMDZhZmRkMTRlMzM3ZWQ0/ea87044a97c66/c2ed4841-58ce-41b4-a012-1a675408ebf4-1724359220_monde_TA.ism/manifest.mpd?hdnea=exp=1724590465~acl=%2f*~hmac=56a73157a315e8e9f927f385182c4d663b6e5a769bf61d3f09c877191b969633" --save-name "Gossip.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428741-the-hives-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjZ+YWNsPSUyZip+aG1hYz1mNDFmYmM3OGRjMDdkMmMxZmJlZWUzODQ0ODA4OTczYmFiN2QxM2Q2NzFjY2FkY2U3OTU1OTE4YmE4ZWU1N2Uy/a0fa03b787c66/7bdf3f71-5fae-4348-a863-05032637e8fb-1724353937_monde_TA.ism/manifest.mpd?hdnea=exp=1724590466~acl=%2f*~hmac=7b6111a9e65c9c73cd947a5b56667f0c775cccb8b4a2e4089eaf523fe934ed40 N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjZ+YWNsPSUyZip+aG1hYz1mNDFmYmM3OGRjMDdkMmMxZmJlZWUzODQ0ODA4OTczYmFiN2QxM2Q2NzFjY2FkY2U3OTU1OTE4YmE4ZWU1N2Uy/a0fa03b787c66/7bdf3f71-5fae-4348-a863-05032637e8fb-1724353937_monde_TA.ism/manifest.mpd?hdnea=exp=1724590466~acl=%2f*~hmac=7b6111a9e65c9c73cd947a5b56667f0c775cccb8b4a2e4089eaf523fe934ed40" --save-name "The.Hives.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428753-destroy-boys-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjZ+YWNsPSUyZip+aG1hYz1mNDFmYmM3OGRjMDdkMmMxZmJlZWUzODQ0ODA4OTczYmFiN2QxM2Q2NzFjY2FkY2U3OTU1OTE4YmE4ZWU1N2Uy/f660de8977c66/a9eab2e7-7020-440f-a430-c0b465eb22e2-1724350747_monde_TA.ism/manifest.mpd?hdnea=exp=1724590466~acl=%2f*~hmac=7b6111a9e65c9c73cd947a5b56667f0c775cccb8b4a2e4089eaf523fe934ed40 N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjZ+YWNsPSUyZip+aG1hYz1mNDFmYmM3OGRjMDdkMmMxZmJlZWUzODQ0ODA4OTczYmFiN2QxM2Q2NzFjY2FkY2U3OTU1OTE4YmE4ZWU1N2Uy/f660de8977c66/a9eab2e7-7020-440f-a430-c0b465eb22e2-1724350747_monde_TA.ism/manifest.mpd?hdnea=exp=1724590466~acl=%2f*~hmac=7b6111a9e65c9c73cd947a5b56667f0c775cccb8b4a2e4089eaf523fe934ed40" --save-name "Destroy.Boys.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6436196-kasabian-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjZ+YWNsPSUyZip+aG1hYz1mNDFmYmM3OGRjMDdkMmMxZmJlZWUzODQ0ODA4OTczYmFiN2QxM2Q2NzFjY2FkY2U3OTU1OTE4YmE4ZWU1N2Uy/f1f3904077c66/bc10cb0f-ea19-4573-8540-835dafb0e35b-1724348019_monde_TA.ism/manifest.mpd?hdnea=exp=1724590466~acl=%2f*~hmac=7b6111a9e65c9c73cd947a5b56667f0c775cccb8b4a2e4089eaf523fe934ed40 N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0NjZ+YWNsPSUyZip+aG1hYz1mNDFmYmM3OGRjMDdkMmMxZmJlZWUzODQ0ODA4OTczYmFiN2QxM2Q2NzFjY2FkY2U3OTU1OTE4YmE4ZWU1N2Uy/f1f3904077c66/bc10cb0f-ea19-4573-8540-835dafb0e35b-1724348019_monde_TA.ism/manifest.mpd?hdnea=exp=1724590466~acl=%2f*~hmac=7b6111a9e65c9c73cd947a5b56667f0c775cccb8b4a2e4089eaf523fe934ed40" --save-name "Kasabian.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428744-dead-poet-society-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0Njd+YWNsPSUyZip+aG1hYz0zMDA3OGM0NjU1YTExNTMxYzNkMzM3ODUxYzRiZjYwNjQ5ZjhjMzlmN2ZiOGI4MTAxMmQwYTk4MzhhNDJkNjJj/e69d0a8367c66/69af0537-515c-4bce-955a-704860ed6712-1724344401_monde_TA.ism/manifest.mpd?hdnea=exp=1724590467~acl=%2f*~hmac=0c17b9e7fa9225463bd311b6d9c6ad407b3d3052c686ebf1e8d6cc4a561e1bab N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0Njd+YWNsPSUyZip+aG1hYz0zMDA3OGM0NjU1YTExNTMxYzNkMzM3ODUxYzRiZjYwNjQ5ZjhjMzlmN2ZiOGI4MTAxMmQwYTk4MzhhNDJkNjJj/e69d0a8367c66/69af0537-515c-4bce-955a-704860ed6712-1724344401_monde_TA.ism/manifest.mpd?hdnea=exp=1724590467~acl=%2f*~hmac=0c17b9e7fa9225463bd311b6d9c6ad407b3d3052c686ebf1e8d6cc4a561e1bab" --save-name "Dead.Poet.Society.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428738-the-last-dinner-party-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0Njd+YWNsPSUyZip+aG1hYz0zMDA3OGM0NjU1YTExNTMxYzNkMzM3ODUxYzRiZjYwNjQ5ZjhjMzlmN2ZiOGI4MTAxMmQwYTk4MzhhNDJkNjJj/cfb203a957c66/2b3182af-0f62-4f88-9358-e6696e460c19-1724342306_monde_TA.ism/manifest.mpd?hdnea=exp=1724590467~acl=%2f*~hmac=0c17b9e7fa9225463bd311b6d9c6ad407b3d3052c686ebf1e8d6cc4a561e1bab N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE0Njd+YWNsPSUyZip+aG1hYz0zMDA3OGM0NjU1YTExNTMxYzNkMzM3ODUxYzRiZjYwNjQ5ZjhjMzlmN2ZiOGI4MTAxMmQwYTk4MzhhNDJkNjJj/cfb203a957c66/2b3182af-0f62-4f88-9358-e6696e460c19-1724342306_monde_TA.ism/manifest.mpd?hdnea=exp=1724590467~acl=%2f*~hmac=0c17b9e7fa9225463bd311b6d9c6ad407b3d3052c686ebf1e8d6cc4a561e1bab" --save-name "The.Last.Dinner.Party.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428747-frank-carter-the-rattlesnakes-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE1NDJ+YWNsPSUyZip+aG1hYz03MmI0YjNhMTU1ZTYwYzJlM2YwMjllNGQ1M2I0MTBiMDFkMDA4ZjBhNDhmYzgyMGUwOGYwZTI5NzQ2NjlmODRh/3dd693aa77c66/98eaba55-fa69-4a77-b7b1-cb3924c42bb5-1724350676_monde_TA.ism/manifest.mpd?hdnea=exp=1724590542~acl=%2f*~hmac=62dc2b96ba8153da8681491da3e2ee0d061c9330d47b52bfb3eac20554358d21 N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE1NDJ+YWNsPSUyZip+aG1hYz03MmI0YjNhMTU1ZTYwYzJlM2YwMjllNGQ1M2I0MTBiMDFkMDA4ZjBhNDhmYzgyMGUwOGYwZTI5NzQ2NjlmODRh/3dd693aa77c66/98eaba55-fa69-4a77-b7b1-cb3924c42bb5-1724350676_monde_TA.ism/manifest.mpd?hdnea=exp=1724590542~acl=%2f*~hmac=62dc2b96ba8153da8681491da3e2ee0d061c9330d47b52bfb3eac20554358d21" --save-name "Frank.Carter.The.Rattlesnakes.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428768-the-kills-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE1NDN+YWNsPSUyZip+aG1hYz0zOTczZjRiZjg1Y2ZiNWQ4N2Q0ZDg5NWI0MmZiMmYwZmQxNzM5ZDIxODRiZGE0ZDFlM2UwMzA5NTE0Mzk0MjIx/90b9a65c0ac66/8c12ed11-1158-4293-a57c-3eba958d8378-1724519438_monde_TA.ism/manifest.mpd?hdnea=exp=1724590543~acl=%2f*~hmac=8742fcb8e60123cbdc962723cc9f6e3551b17404e164f8f554a99566a47a03f9 N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE1NDN+YWNsPSUyZip+aG1hYz0zOTczZjRiZjg1Y2ZiNWQ4N2Q0ZDg5NWI0MmZiMmYwZmQxNzM5ZDIxODRiZGE0ZDFlM2UwMzA5NTE0Mzk0MjIx/90b9a65c0ac66/8c12ed11-1158-4293-a57c-3eba958d8378-1724519438_monde_TA.ism/manifest.mpd?hdnea=exp=1724590543~acl=%2f*~hmac=8742fcb8e60123cbdc962723cc9f6e3551b17404e164f8f554a99566a47a03f9" --save-name "The.Kills.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF ---------------------------------------------------------------------------------------------------- Video url: https://www.france.tv/spectacles-et-culture/festival-rock-en-seine/6428765-sleater-kinney-en-concert-a-rock-en-seine-2024.html mpd_url: https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE1NDN+YWNsPSUyZip+aG1hYz0zOTczZjRiZjg1Y2ZiNWQ4N2Q0ZDg5NWI0MmZiMmYwZmQxNzM5ZDIxODRiZGE0ZDFlM2UwMzA5NTE0Mzk0MjIx/58f21053f9c66/6db0964e-5c23-4cfc-9826-862789a1e9d2-1724512476_monde_TA.ism/manifest.mpd?hdnea=exp=1724590543~acl=%2f*~hmac=8742fcb8e60123cbdc962723cc9f6e3551b17404e164f8f554a99566a47a03f9 N_m3u8DL-RE "https://cloudingest.ftven.fr/ZXhwPTE3MjQ2MTE1NDN+YWNsPSUyZip+aG1hYz0zOTczZjRiZjg1Y2ZiNWQ4N2Q0ZDg5NWI0MmZiMmYwZmQxNzM5ZDIxODRiZGE0ZDFlM2UwMzA5NTE0Mzk0MjIx/58f21053f9c66/6db0964e-5c23-4cfc-9826-862789a1e9d2-1724512476_monde_TA.ism/manifest.mpd?hdnea=exp=1724590543~acl=%2f*~hmac=8742fcb8e60123cbdc962723cc9f6e3551b17404e164f8f554a99566a47a03f9" --save-name "Sleater.Kinney.en.concert.a.Rock.en.Seine.2024" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF
