I just got myself the complete seasons 1-4 on DVD (PAL) as box sets and backed them up to disk, and am now contemplating to also get the NTSC releases to compare them side-by-side. Before I pull the trigger, could someone kindly post the full mediainfo output for one or two of the disks (iso image or raw disk) of the NTSC releases, preferably season 1 disc 1?
If anyone is interested in the PAL output for season 1 disc 1, here it is:
Thanks a lot!Code:General Complete name : FUTURAMA_SEASON_1_DISC_1_PAL.iso Format : ISO 9660 / DVD Video Format profile : Program File size : 5.13 GiB Duration : 1 h 26 min Overall bit rate mode : Variable Overall bit rate : 8 504 kb/s Frame rate : 25.000 FPS Movie name : FUTURAMA_DISC_1 Publisher : FOX_INTERNATIONAL Encoded date : 2001-11-28 10:59:28.00+56:00 Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings : CustomMatrix / BVOP Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Format settings, picture structure : Frame Duration : 1 h 26 min Bit rate mode : Variable Bit rate : 7 459 kb/s Maximum bit rate : 8 000 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.719 Time code of first frame : 00:59:58:00 Time code source : Group of pictures header GOP, Open/Closed : Open GOP, Open/Closed of first frame : Closed Stream size : 4.50 GiB (88%) Source : VIDEO_TS/VTS_01_0.IFO Audio #1 ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Format settings : Dolby Surround Muxing mode : DVD-Video Duration : 1 h 26 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : -16 ms Stream size : 119 MiB (2%) Language : English Service kind : Complete Main Source : VIDEO_TS/VTS_01_0.IFO Dialog Normalization : -27 dB compr : 12.04 dB dynrng : 6.02 dB dsurmod : Dolby Surround encoded dialnorm_Average : -27 dB dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dB Audio #2 ID : 189 (0xBD)-129 (0x81) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Format settings : Dolby Surround Muxing mode : DVD-Video Duration : 1 h 26 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 119 MiB (2%) Language : German Service kind : Complete Main Source : VIDEO_TS/VTS_01_0.IFO Dialog Normalization : -27 dB compr : 12.04 dB dynrng : 6.02 dB dsurmod : Dolby Surround encoded dialnorm_Average : -27 dB dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dB Audio #3 ID : 189 (0xBD)-130 (0x82) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Format settings : Dolby Surround Muxing mode : DVD-Video Duration : 1 h 26 min Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 119 MiB (2%) Language : Spanish Service kind : Complete Main Source : VIDEO_TS/VTS_01_0.IFO Dialog Normalization : -27 dB compr : 12.04 dB dynrng : 6.02 dB dsurmod : Dolby Surround encoded dialnorm_Average : -27 dB dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dB Audio #4 ID : 189 (0xBD)-131 (0x83) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Format settings : Dolby Surround Muxing mode : DVD-Video Duration : 1 h 26 min Bit rate mode : Constant Bit rate : 96.0 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : -16 ms Stream size : 59.3 MiB (1%) Language : English Service kind : Complete Main Source : VIDEO_TS/VTS_01_0.IFO Dialog Normalization : -27 dB compr : 12.04 dB dynrng : 6.02 dB dsurmod : Dolby Surround encoded dialnorm_Average : -27 dB dialnorm_Minimum : -27 dB dialnorm_Maximum : -27 dB Text #1 ID : 189 (0xBD)-32 (0x20) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 2 s 360 ms Language : Danish Source : VIDEO_TS/VTS_01_0.IFO Text #2 ID : 189 (0xBD)-33 (0x21) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 6 s 560 ms Language : English Source : VIDEO_TS/VTS_01_0.IFO Text #3 ID : 189 (0xBD)-34 (0x22) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 2 s 160 ms Language : Finnish Source : VIDEO_TS/VTS_01_0.IFO Text #4 ID : 189 (0xBD)-35 (0x23) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 2 s 360 ms Language : German Source : VIDEO_TS/VTS_01_0.IFO Text #5 ID : 189 (0xBD)-36 (0x24) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 2 s 360 ms Language : Norwegian Source : VIDEO_TS/VTS_01_0.IFO Text #6 ID : 189 (0xBD)-37 (0x25) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 6 s 560 ms Language : Spanish Source : VIDEO_TS/VTS_01_0.IFO Text #7 ID : 189 (0xBD)-38 (0x26) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 6 s 680 ms Language : Swedish Source : VIDEO_TS/VTS_01_0.IFO Text #8 ID : 189 (0xBD)-41 (0x29) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 2 s 960 ms Language : German Source : VIDEO_TS/VTS_01_0.IFO Text #9 ID : 189 (0xBD)-42 (0x2A) Format : RLE Format/Info : Run-length encoding Muxing mode : DVD-Video Duration : 1 h 26 min Bit depth : 2 bits Delay relative to video : 2 s 960 ms Language : Spanish Source : VIDEO_TS/VTS_01_0.IFO Text #10 ID : 189 (0xBD)-32 (0x20) Format : RLE Format/Info : Run-length encoding Duration : 1 h 26 min Bit depth : 2 bits Language : German Source : VIDEO_TS/VTS_01_0.IFO Text #11 ID : 189 (0xBD)-32 (0x20) Format : RLE Format/Info : Run-length encoding Duration : 1 h 26 min Bit depth : 2 bits Language : Spanish Source : VIDEO_TS/VTS_01_0.IFO Menu #1 Duration : 21 min 34 s 00:00:00.000 : Chapter 1 00:03:26.640 : Chapter 2 00:08:47.920 : Chapter 3 00:14:31.240 : Chapter 4 00:20:58.400 : Chapter 5 List (Audio) : 0 / 1 / 2 / 3 List (Subtitles 4/3) : 0 / 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10 List (Subtitles Wide) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 List (Subtitles Letterbox) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 List (Subtitles Pan&Scan) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 Source : VIDEO_TS/VTS_01_0.IFO Menu #2 Duration : 21 min 35 s 00:00:00.000 : Chapter 1 00:01:38.520 : Chapter 2 00:06:13.720 : Chapter 3 00:12:42.680 : Chapter 4 00:20:57.440 : Chapter 5 List (Audio) : 0 / 1 / 2 / 3 List (Subtitles 4/3) : 0 / 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10 List (Subtitles Wide) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 List (Subtitles Letterbox) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 List (Subtitles Pan&Scan) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 Source : VIDEO_TS/VTS_01_0.IFO Menu #3 Duration : 21 min 36 s 00:00:00.000 : Chapter 1 00:00:29.440 : Chapter 2 00:06:55.440 : Chapter 3 00:15:15.120 : Chapter 4 00:20:58.320 : Chapter 5 List (Audio) : 0 / 1 / 2 / 3 List (Subtitles 4/3) : 0 / 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10 List (Subtitles Wide) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 List (Subtitles Letterbox) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 List (Subtitles Pan&Scan) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 Source : VIDEO_TS/VTS_01_0.IFO Menu #4 Duration : 21 min 36 s 00:00:00.000 : Chapter 1 00:00:47.440 : Chapter 2 00:06:04.040 : Chapter 3 00:13:12.360 : Chapter 4 00:20:58.240 : Chapter 5 List (Audio) : 0 / 1 / 2 / 3 List (Subtitles 4/3) : 0 / 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 / 9 / 10 List (Subtitles Wide) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 List (Subtitles Letterbox) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 List (Subtitles Pan&Scan) : 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 / 0 Source : VIDEO_TS/VTS_01_0.IFO
Results 1 to 1 of 1
Different bitrate of output video from which I set on Adobe Premiere
By MBlueSky in forum Video ConversionReplies: 1Last Post: 9th Dec 2022, 13:38 -
Full disc DVD ripping for preservation and playback on PC
By EmielBoss in forum DVD RippingReplies: 11Last Post: 12th Sep 2022, 12:35 -
Get-MediaInfo - a complete PowerShell MediaInfo solution
By stax76 in forum ProgrammingReplies: 6Last Post: 31st Mar 2021, 05:41 -
Unable set output name in Windows batch
By mmshasan in forum Newbie / General discussionsReplies: 6Last Post: 22nd Mar 2021, 09:27 -
DVD Box Set, one flawed disc
By Tom Saurus in forum DVD RippingReplies: 8Last Post: 13th Jul 2020, 17:32
