Hi everyone,
With some help from here, we got an easy way to download from cine.ar. And with this we get the supposed best resolution 720p.
(through convert.php/...m3u8) and thousand thanks for that.
[Attachment 81702 - Click to enlarge]
But apparently, the stream in 1080p is existing even if it's not visible by the online player.
(Because at least 2 videos have been found from them in 1080p and not streamcast, proper download confirmed)
Does someone see a way to get it please ? Can anyone confirm it ?
example :just need free account.Code:https://play.cine.ar/INCAA/produccion/5169
				Results 1 to 21 of 21
	Were those found videos available in 1080p in browser?
 Edit: I think I may have found a possible formula based on OP's video
 I took the m3u8 with all the resolutions, 240p -> 720p. For each of them I took the link of the first fragment. They are all identical, across all resolutions, except for a small section. That section is based on bandwidth and some base64 encoding of a name value. If you could deduce those for 1080p, you could attempt to download it.NAME="240p (100k)",RESOLUTION=428x240,BANDWIDTH=260000
 b260000_t64MjQwcCAoMTAwayk
 NAME="240p (200k)",RESOLUTION=428x240,BANDWIDTH=360000
 b360000_t64MjQwcCAoMjAwayk
 NAME="270p (350k)",RESOLUTION=480x270,BANDWIDTH=510000
 b510000_t64MjcwcCAoMzUwayk
 NAME="360p (650k)",RESOLUTION=640x360,BANDWIDTH=810000
 b810000_t64MzYwcCAoNjUwayk
 NAME="480p (1050k)",RESOLUTION=854x480,BANDWIDTH=1242000
 b1242000_t64NDgwcCAoMTA1MGsp
 NAME="600p (1600k)",RESOLUTION=1068x600,BANDWIDTH=1792000
 b1792000_t64NjAwcCAoMTYwMGsp
 NAME="720p (2350k)",RESOLUTION=1280x720,BANDWIDTH=2542000
 b2542000_t64NzIwcCAoMjM1MGsp
 NAME="???",RESOLUTION=1920x1080,BANDWIDTH=???
 b???_t64???
 b<bandwitdh value>_t64<name value base64 encoded>
 No idea if it's possible though. Maybe there's a smarter trick around.Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 22nd Aug 2024 at 02:44. --[----->+<]>.++++++++++++.---.--------.
	Create an account
 [Attachment 81708 - Click to enlarge]
 Debugger doesn't even block you
 The manifest url come from this function embeded in 'https://player.cine.ar/odeon/?' :
 As pepe said each resolution have his id like :HTML Code:function _manifestUri_() { x = '8bexXPN2BQvbt2GMKvRLpM8uTsaZ8GkyEw0o7Dz9AZiP3VpNf_LPslHQyOs3tk91ZVn7bxJa9SP3qzvHghnUmKQ0W8536zrCpyz8ekD0sFVoe8bPjVLS1eGbJzsG80UKkzlgFYaWJsdqv3xCb4GcpPSO5AUeis1is9rFqAdG71JmF0Vr4S3PVNe_WPoGXK-_sJggk-i=H_Z3NLe3aXOwZWZ3jSceQ2-dj&3fcV5O6GYTAMQdYNfVAZ0fnjviKfx7GyBwu2oh5A6xJYNlpRKfMa4Akk3CShKq2TKEk6NUMecnc-wvb-feL1gUJIPopDD_cWo4-kpJpeeEumj/soSXb7F7ml7tS2oIIULQBJwWMj0xtunwUfMLX_kGRuHCIqtomWllAwwVFfzS33hHQEayjFTipTkX5Xdi7cPRLhIiti7Ssk0naRQX-DivsqBgXsQKOas1y0J_6j=mzAYcy10sKWU_FgeOqFLuTTrZTBcc3wDPSYjhpxP-QSrU8F9RoMPIWqi0U9UISboWbf2XbNxo23IzjZq6gYfhtqMSRuaZeQ8VeXqkKC21i4cDlbIaAOBsQQljCAVqKjzP7txB0fyKGK3_EWTeMTtSvNaARtbQKLUjtef7VfUfAxKS45HPAUnaJu2xIS8kb8a2m9JTphi9X1QMGGbNXwT56zSBEV4MJ0qxR8zYGnRgilkKK_dAeawc_wlAISEn_7yg-3OdRMqOPEkvCSMc?-jMvf6Wod_J7TyprhAqnkXETX'; return '' + x[298] + x[383] + x[248] + x[727] + x[603] + x[748] + x[424] + x[335] + x[732] + x[11] + x[458] + x[329] + x[268] + x[259] + x[677] + x[257] + x[637] + x[104] + x[695] + x[131] + x[561] + x[699] + x[516] + x[485] + x[414] + x[707] + x[698] + x[100] + x[115] + x[25] + x[746] + x[87] + x[212] + x[325] + x[125] + x[71] + x[606] + x[313] + x[739] + x[267] + x[43] + x[548] + x[405] + x[753] + x[328] + x[599] + x[422] + x[12] + x[717] + x[301] + x[251] + x[370] + x[586] + x[34] + x[413] + x[28] + x[62] + x[663] + x[204] + x[352] + x[312] + x[486] + x[633] + x[749] + x[429] + x[53] + x[408] + x[273] + x[88] + x[522] + x[145] + x[507] + x[475] + x[307] + x[444] + x[247] + x[21] + x[128] + x[613] + x[141] + x[189] + x[570] + x[348] + x[337] + x[592] + x[624] + x[381] + x[172] + x[217] + x[341] + x[520] + x[652] + x[512] + x[656] + x[82] + x[657] + x[169] + x[412] + x[729] + x[609] + x[751] + x[466] + x[755] + x[614] + x[510] + x[620] + x[139] + x[308] + x[108] + x[501] + x[176] + x[432] + x[356] + x[284] + x[584] + x[594] + x[462] + x[60] + x[704] + x[109] + x[165] + x[688] + x[7] + x[138] + x[643] + x[363] + x[147] + x[225] + x[20] + x[199] + x[182] + x[327] + x[669] + x[589] + x[404] + x[451] + x[549] + x[587] + x[508] + x[410] + x[581] + x[434] + x[398] + x[757] + x[99] + x[690] + x[291] + x[653] + x[52] + x[359] + x[196] + x[644] + x[525] + x[181] + x[285] + x[107] + x[575] + x[715] + x[607] + x[597] + x[735] + x[95] + x[37] + x[602] + x[238] + x[736] + x[675] + x[454] + x[574] + x[354] + x[553] + x[683] + x[529] + x[433] + x[618] + x[274] + x[521] + x[264] + x[517] + x[117] + x[347] + x[679] + x[39] + x[365] + x[167] + x[559] + x[30] + x[734] + x[96] + x[242] + x[689] + x[228] + x[35] + x[483] + x[184] + x[218] + x[565] + x[64] + x[752] + x[621] + x[701] + x[303] + x[40] + x[569] + x[426] + x[288] + x[393] + x[324] + x[703] + x[319] + x[472] + x[188] + x[275] + x[26] + x[33] + x[159] + x[502] + x[316] + x[459] + x[756] + x[531] + x[8] + x[4] + x[171] + x[533] + x[195] + x[626] + x[518] + x[369] + x[90] + x[305] + x[42] + x[77] + x[435] + x[279] + x[280] + x[571] + x[731] + x[528] + x[498] + x[79] + x[634] + x[83] + x[118] + x[333] + x[572] + x[376] + x[155] + x[723] + x[560] + x[490] + x[659] + x[235] + x[174] + x[45] + x[126] + x[558] + x[310] + x[394] + x[456] + x[250] + x[636] + x[271] + x[344] + x[98] + x[223] + x[173] + x[655] + x[143] + x[465] + x[46] + x[124] + x[685] + x[600] + x[474] + x[209] + x[93] + x[72] + x[152] + x[144] + x[702] + x[377] + x[744] + x[119] + x[69] + x[391] + x[660] + x[582] + x[318] + x[493] + x[194] + x[686] + x[480] + x[428] + x[708] + x[24] + x[478] + x[390] + x[278] + x[706] + x[101] + x[573] + x[743] + x[338] + x[375] + x[14] + x[214] + x[567] + x[523] + x[27] + x[406] + x[551] + x[227] + x[29] + x[378] + x[538] + x[170] + x[166] + x[441] + x[557] + x[712] + x[479] + x[457] + x[615] + x[47] + x[331] + x[59] + x[372] + x[106] + x[505] + x[54] + x[576] + x[666] + x[380] + x[353] + x[163] + x[436] + x[206] + x[453] + x[487] + x[258] + x[129] + x[13] + x[74] + x[49] + x[281] + x[175] + x[542] + x[471] + x[460] + x[611] + x[265] + x[287] + x[120] + x[190] + x[179] + x[718] + x[121] + x[544] + x[342] + x[692] + x[418] + x[205] + x[202] + x[210] + x[409] + x[596] + x[136] + x[367] + x[191] + x[234] + x[299] + x[537] + x[215] + x[1] + x[733] + x[56] + x[57] + x[340] + x[509] + x[345] + x[449] + x[50] + x[160] + x[407] + x[705] + x[635] + x[661] + x[389] + x[494] + x[292] + x[10] + x[514] + x[266] + x[577] + x[243] + x[226] + x[470] + x[496] + x[334] + x[256] + x[728] + x[366] + x[726] + x[668] + x[710] + x[203] + x[464] + x[193] + x[610] + x[233] + x[346] + x[80] + x[31] + x[691] + x[135] + x[650] + x[103] + x[294] + x[67] + x[473] + x[3] + x[168] + x[207] + x[400] + x[540] + x[358] + x[111] + x[737] + x[197] + x[66] + x[511] + x[51] + x[430] + x[355] + x[272] + x[612] + x[534] + x[402] + x[719] + x[349] + x[260] + x[513] + x[237] + x[556] + x[437] + x[491] + x[317] + x[306] + x[156] + x[15] + x[477] + x[693] + x[321] + x[450] + x[192] + x[222] + x[724] + x[627] + x[276] + x[539] + x[552] + x[246] + x[65] + x[140] + x[411] + x[396] + x[382] + x[283] + x[630] + x[213] + x[595] + x[309] + x[419] + x[85] + x[151] + x[187] + x[714] + x[127] + x[229] + x[230] + x[38] + x[114] + x[629] + x[467] + x[70] + x[102] + x[22] + x[91] + x[711] + x[198] + x[239] + x[19] + x[545] + x[468] + x[241] + x[385] + x[591] + x[78] + x[63] + x[61] + x[665] + x[566] + x[395] + x[130] + x[332] + x[161] + x[649] + x[745] + x[18] + x[658] + x[323] + x[684] + x[154] + x[252] + x[339] + x[640] + x[463] + x[438] + x[289] + x[221] + x[484] + x[590] + x[674] + x[0] + x[387] + x[357] + x[619] + x[388] + x[632] + x[425] + x[244] + x[730] + x[427] + x[270] + x[384] + x[532] + x[440] + x[713] + x[696] + x[527] + x[16] + x[392] + x[452] + x[2] + x[133] + x[336] + x[158] + x[314] + x[55] + x[9] + x[362] + x[297] + x[667] + x[605] + x[178] + x[580] + x[664] + x[709] + x[216] + x[350] + x[442] + x[694] + x[137] + x[364] + x[94] + x[6] + x[322] + x[421] + x[506] + x[315] + x[236] + x[374] + x[116] + x[439] + x[601] + x[269] + x[500] + x[295] + x[286] + x[720] + x[578] + x[231] + x[44] + x[682] + x[373] + x[504] + x[738] + x[263] + x[92] + x[290] + x[123] + x[379] + x[646] + x[616] + x[547] + x[639] + x[183] + x[546] + x[420] + x[211] + x[105] + x[232] + x[604] + x[224] + x[741] + x[68] + x[489] + x[23] + x[134] + x[628] + x[368] + x[343] + x[415] + x[495] + x[326] + x[648] + x[625] + x[676] + x[254] + x[448] + x[81] + x[492] + x[148] + x[86] + x[524] + x[670] + x[481] + x[515] + x[261] + x[585] + x[208] + x[185] + x[673] + x[535] + x[360] + x[680] + x[296] + x[249] + x[36] + x[180] + x[651] + x[593] + x[200] + x[153] + x[543] + x[563] + x[681] + x[401] + x[220] + x[399] + x[550] + x[562] + x[32] + x[97] + x[132] + x[351] + x[445] + x[149] + x[431] + x[311] + x[697] + x[488] + x[443] + x[747] + x[75] + x[583] + x[555] + x[17] + x[526] + x[503] + x[150] + x[671] + x[262] + x[455] + x[146] + x[530] + x[157] + x[622] + x[446] + x[416] + x[330] + x[164] + x[631] + x[564] + x[89] + x[579] + x[386] + x[721] + x[654] + x[201] + x[253] + x[461] + x[122] + x[598] + x[255] + x[750] + x[482] + x[5] + x[403] + x[678] + x[186] + x[397] + x[623] + x[497] + x[541] + x[476] + x[76] + x[293] + x[361] + x[58] + x[617] + x[641] + x[722] + x[645] + x[112] + x[48] + x[469] + x[423] + x[113] + x[725] + x[647] + x[300] + x[282] + x[642] + x[371] + x[219] + x[162] + x[754] + x[41] + x[672] + x[519] + x[447] + x[177] + x[84] + x[740] + x[499] + x[638] + x[568] + x[716] + x[302] + x[73] + x[687] + x[554] + x[142] + x[417] + x[608] + x[240] + x[245] + x[320] + x[742] + x[662] + x[700] + x[304] + x[536] + x[110] + x[588] + x[277]; } console.log(_manifestUri_()); > convert/?b=eJwVyUsKgCAUBdAdeSsy0Zk0atIWxPRFkp_It3-iMz0X89MNIJc5hklpRWo4ROeXfMkt3KISo0VqFS7SmWpnh15SNq0EbPtqLeS4aBSKyYt_8AG2dxxc&p=eJwtj1uPokAQhX8RE9sWkIfNhosgSKMCDTQvBJBLQxNRUKb59etM9uGkkjpfncoZWc4ZneavAb72f-c_FXfawirpmToBXm3gUUf5-izXAkacbPHHUGmAReOKD9TVVUqgz6vAlmzd0TC1p88EeXz95bwu7bxVXVDYgzTsITLw4lkOJSGGZDWZTZfGHqJdqX_ujQNE3XVFHQbIUF-e0cBz2P_krf_zAAqJ-POztFiPLZOTGJw_YnZ3b-yObMlaLsiwP1wjkvi6QV3UpjGCnkXE3yJaG7gygWa0N7gx73QgwPf-nIP0QpRIad2uqMeDPDfiMFlWss-PfM6e0VvX3tCKWK1RKOGyKV5zLxsJD83nidLqKNWBv1kGcSlu98TRi4RUKXJciT2TxS8lJjA4iAMSNm2s7KXKFyeYs1PQQ0eNT3CGSjoBkstrNoh9oAk1vWYQUKRlO3q_86h6KGC8KSa_MLwF6MjdbwuaAU7ihpbfExOhSpQbTT02jaPzzMJMj7V2fHAh10EQHa2EyFIsPnU_3gp3qVv2US5o_GxsfQ7eqSi8jlMJ_fAs37ArPy4o37xYqq6jsLuqSjfWiVEkc32LerXZ6IKSmo-nl-wSY8xcvYZc_Qebjb7a
 We could guess the id (even though +2M possibilities) but without the last part 't64NzIwcCAoMjM1MGsp' it's impossible..Code:media_w1416110396_b2542000_t64NzIwcCAoMjM1MGsp (720p) (2350k) media_w1416110396_b1792000_t64NjAwcCAoMTYwMGsp (600p) (1600k)
 The only way I see would be to legitimately get the 1080p _manifestUri_ from there API.Last edited by aqzs; 22nd Aug 2024 at 05:44.
	You can lower down the number by seeing the bandwidth is a multiple of 50 or 2000. After a fast calculation for 20000 possibilities, you would have to spam request for 16 hours in a script (~3 seconds per request). Doable, but who would be crazy to do that. You could lower down that number even more, but I think it's useless. --[----->+<]>.++++++++++++.---.--------.
	Actually, it's a URL and not Base64 in the App. The master playlist is also a URL, just like every other master playlist. Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
	Yes. I know. I was talking about the unique section from the URL of the first fragment. They are all the same, except a section. That section contains a base64 that could be bruteforced in < 1 day for 1080p --[----->+<]>.++++++++++++.---.--------.
	So what about the bitrate? Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
	By last part I mean 't64NzIwcCAoMjM1MGsp' in 'media_w1416110396_b2542000_t64NzIwcCAoMjM1MGsp'.
 Here is a junky script to get manifest url :
 Code:import requests from bs4 import BeautifulSoup TOKEN = 'TRUNCATED' USERID = 'TRUNCATED' VIDEOID = '5169' params = (('i', VIDEOID),('p', USERID),('s', 'INCAA'),('t', TOKEN),) response = requests.get('https://player.cine.ar/odeon/', params=params) soup = BeautifulSoup(response.content, 'html.parser') script_content = soup.findAll('script', type='text/javascript')[1].string script_content = script_content.split("'; return") script_content[0] = script_content[0].replace("function _manifestUri_(){x='", '') script_content[1] = script_content[1].replace(";}", '') script_content[1] = script_content[1].replace("''", ']') nums = script_content[1].split(']+x[') string = '' for n in nums: if n != ' ': if len(n) <= 3: string += script_content[0][int(n)] elif len(n) > 3: string += script_content[0][int(n[:3])] else: print('error', n) manifest_url = 'https://player.cine.ar/odeon/' + string + '&c=1' print('manifest_url: ', manifest_url)
	I don't think I understand your question. The bitrate is tied to the base64. I explained it in #3. It's useless anyway, even if feasible. Should wait for a proper trick to be found.
 @aqzs, that string "t64NzIwcCAoMjM1MGsp", remove t64. You will get "NzIwcCAoMjM1MGsp". Decode that content since it's base64
 So in short, guess both bitrates, the k value and the normal one, and you'll get 1080p, in theory--[----->+<]>.++++++++++++.---.--------.
	If you want to get the link to the 1080p manifest, you not only need the video bitrate (aka. the base64 value) but also the bandwidth:
 (Yes, I know I said bitrate, but meant the following value)
 Code:chunklist_w1972170616_b2542000_t64NzIwcCAoMjM1MGsp.m3u8 ^^^^^^^^Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
	Yes. That fact was stated as well in post #3  --[----->+<]>.++++++++++++.---.--------. --[----->+<]>.++++++++++++.---.--------.
	My question was based on post #9, where you said that we only had to bruteforce the base64. But my question lead to confusion because I accidentally called it bitrate instead bandwidth. The reason for my confusion was just that you didn't mention the bandwidth in post #9. Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
	Oh. My bad. I meant bruteforced, as in bruteforcing the entire section, not just the bandwidth/bitrate. Poor choice of words on my side. --[----->+<]>.++++++++++++.---.--------.
	this is what interrogate me in the first place :
 in some downlad forum, i saw this release :
 and i was really puzzeled to understand how it was done because 720p was supposed to be the best resolution...Code:Los.Paranoicos.2008.1080p.CINEAR.WEB-DL.H.264.AAC.2.0
	best resolution for this video or any other video but always from this website...
 Just confirmation that 1080p is existing on the videos from that website and if possible to get it.
 no, this website is totally free. you just can pay if you want to get the latest latest videos, all the rest is totally free.
	From what I've seen, unless there's a magic device like Samsung TV, etc whatever, that can play 1080p content from them or from their app (non-browser), then I don't think there's even 1080p available. If someone has another idea, feel free to correct me
 If you find a device like that, you could take their headers/endpoints and reproduce the API call flow.--[----->+<]>.++++++++++++.---.--------.
  Cine-Can this be Made Better?By Alwyn in forum RestorationReplies: 28Last Post: 5th May 2024, 07:09
  How to download from cine.arBy abacaxi in forum Video Streaming DownloadingReplies: 21Last Post: 7th Jul 2023, 06:16
  Trying to install cine encoder in UbuntuBy ricardouk in forum LinuxReplies: 17Last Post: 14th Jun 2022, 21:42
  play.cine.arBy oopargentina in forum Video Streaming DownloadingReplies: 2Last Post: 18th Nov 2021, 11:01
  Minimising/Removing Cine Film FlickerBy Alwyn in forum RestorationReplies: 3Last Post: 10th Apr 2021, 04:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
						 Visit Homepage
				Visit Homepage
