from mpd i have this res available:
i need add RE command for my resolution to start download automaticallyCode:960x540 | 2053 Kbps | video-avc1-5 | 23.976 | avc1.4D401F 768x432 | 1468 Kbps | video-avc1-4 | 23.976 | avc1.4D401E 768x432 | 1077 Kbps | video-avc1-3 | 23.976 | avc1.4D401E 768x432 | 731 Kbps | video-avc1-2 | 23.976 | avc1.4D401E 384x216 | 350 Kbps | video-avc1-1 | 23.976 | avc1.4D400D
it's ok for 540p with -sv res="540*"
but if i want this res: 768x432 | 1077 Kbps how to ?
Select video streams by regular expressions. OPTIONS is a colon separated list of: id=REGEX:lang=REGEX:name=REGEX:codec=REGEX:res=REGEX:frame=REGEX segsMin=number:segsMax=number:ch=REGEX:range=REGEX:url=REGEX plistDurMin=hms:plistDurMax=hms:for=FOR * for=FOR: Select type. best[number], worst[number], all (Default: best) Examples: # select best video -sv best # select 4K+HEVC video -sv res="3840*":codec=hvc1:for=best # Select best video with duration longer than 1 hour 20 minutes 30 seconds -sv plistDurMin="1h20m30s":for=best
as you can see, have 3 available res 432p
i want 432 | 1077
so, -sv res="432*"
but how to choose 1077 ? -
how to force resolution to download with N_m3u8DL-CLI_v3.0.2?
By colebri in forum Video Streaming DownloadingReplies: 4Last Post: 6th Aug 2024, 08:05 -
N_m3u8DL-re - Command Advice Request
By geordie10 in forum Newbie / General discussionsReplies: 0Last Post: 28th Jun 2024, 06:48 -
Need help me getting the N_m3u8DL-RE
By mrsimple8x in forum Video Streaming DownloadingReplies: 2Last Post: 19th Dec 2023, 07:29 -
Looking for linux command line to add DRC to already encoded files.
By BobCadenza in forum AudioReplies: 4Last Post: 27th Nov 2021, 07:12 -
Command line to add audio to mkv files
By Nico Darko in forum Video ConversionReplies: 25Last Post: 12th Jul 2020, 21:27
