How to add a time code to H264
Time code of first frame: 01:00:00:00
General
Complete name : C:\Users\Use\Desktop\00000.264
Format : AVC
File size : 85.9 MiB
Overall bit rate mode : Constant
Frame rate : 23.976 FPS
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Format settings, Slice count : 4 slices per frame
Bit rate mode : Constant
Bit rate : 18.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.362
Time code of first frame : 01:00:00:00
I don't know how to add a time code?
something like:
might work, but I have never tried it on raw video.Code:ffmpeg -i "C:\Users\Use\Desktop\00000.264" -map 0 -map -0:d -c copy -timecode 01:00:00:00 "C:\Users\Use\Desktop\00000_adjusted.264"
users currently on my ignore list: deadrats, Stears555, marcorocchini -
No effect
This is the H264 RAW file with time code information above:Drive Google
ffmpeg time-code
By Bekkeh in forum Video Streaming DownloadingReplies: 7Last Post: 28th Jan 2024, 11:56 -
Subtitles Edit: how to delayed the subs only AFTER a given time code ?
By Nounours18200 in forum SubtitleReplies: 2Last Post: 6th Feb 2023, 17:16 -
Mini DV Time code issue
By hotcheeto in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 22nd Aug 2022, 14:15 -
Add time and date to 4k video?
By David22 in forum Video ConversionReplies: 1Last Post: 20th Feb 2021, 11:58 -
Set subtitles to start at a specific time code using Subtitle Edit
By seorimpaek in forum SubtitleReplies: 1Last Post: 28th Jul 2020, 22:03
