I'm after some triallers for my Easier-AVISynth package. You'll need a 64bit computer which doesn't have AVISynth Plus installed on it (or are prepared to remove it).
All I've done is collate the various files so that setting up the dependencies is easier.
If you already have AVISynth (and QTGMC) installed and running, this is not for you.
If you're interested, please PM me and I'll give you the link to the Avisynth files and instructions.
Results 1 to 19 of 19
Trial expanded to 32bit computers running something other than Win XP.
You might at least want to explain what your 'Easy-AVISynth package' is meant to do, when looking for folks to trash their pc,...
users currently on my ignore list: deadrats, Stears555, marcorocchini -
There will be no trashing of any PC. Why such hatred, Selur?
No hatred.
You do not write anything about what you want folks to help with, do what do you expect folks to think?
I mean, most phishing mails share more (fake) info.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
To be discussed via PM.
One could explicitly load the needed dll using LoadDLL instead of having to copy stuff into a system folder,...
Granted that Avisynth is not the easiest thing to get on with.
So I guess that if something makes it 'easier' then it has some merit. Yet confidence is somewhat shattered when the creater uses the words "Guinea Pigs" in the introduction.
Thus I must concur that Alwyn needs to be more 'open' to attract 'Beta Testers'. -
Yes, using:Does QTGMC actually run if you use LoadDLL?
works fine. Hybrid does this for 10+years.Code:LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LoadDll.dll") LoadDLL("F:\Hybrid\64bit\Avisynth\avisynthPlugins\libfftw3f-3.dll") LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\FFT3DFilter.dll")
Assuming you have LoadDll and FFT3DFilter already loaded through autoloading, you just need to load libfftw3f-3.dll through LoadDLL.
Personally, I use 'ClearAutoloadDirs()' to disable all autoloading and load everything manually (to really know what is loaded).
Cu Selur
Ps.: also loading libfftw3f-3 is only needed if you use it.users currently on my ignore list: deadrats, Stears555, marcorocchini -
There is a thread around here with a portable version of AviSynth+ and all the plugins required to use QTGMC(). Here it is:
https://forum.videohelp.com/threads/405720-FFmpeg-QTGMC-Easy! -
And LoadDLL() for Windows system dlls, like libfftw3f-3.dll.
I have dev systems, I'm game. (If it makes a mess, not hard to reload OS.)
And if I have anything that can help, I can give it to you.Want my help? Ask here! (not via PM!)
Need to make my life a little easier....
By paul92 in forum EditingReplies: 4Last Post: 23rd Jul 2024, 08:25 -
Audacity – Moving split track. Was there an easier way?
By Moralez in forum AudioReplies: 0Last Post: 11th May 2024, 15:02 -
What is an easier format to edit on modern systems?
By Waloshin in forum Capturing and VCRReplies: 5Last Post: 29th Jan 2021, 02:13 -
Easier ways to make split screen videos?
By SixStringSW in forum EditingReplies: 5Last Post: 15th Jan 2021, 13:31 -
Easier Cap can it damage my VHS/DVD player
By Rusty Tapes in forum Capturing and VCRReplies: 1Last Post: 26th Mar 2020, 17:44
