I have recorded some woodworking classes I’ve taken with a GoPro. A week long class typically winds up with 7 hours of video that would be 466GB to store at 1080 resolution.
I’m using iMovie on an M1 Mac with 8gb ram. Currently storing things on a SanDisc ssd drive.
What’s the best long term storage solution if I want to keep this class for review down the road?
I was considering buying Toast and putting on an M-Disc.
I’m also unsure what resolution I really need to be saving this in.
Thanks!
Here is what I suggest ...
Purchase a 512G Flash Thumb Drive
Copy the 466GB of video to the Flash. Save in same resolution and file extension. Don't change anything.
Place a label on the Flash Drive so that you will find it easier.
If backup is required, then repeat the process. -
I agree with Gromyko in principle, the only thing I would change is to use an internal SSD or NVMe with an adapter, something like this:
https://www.amazon.com/FREEGENE-Enclosure-SATA-Based-Compatible-Thunderbolt/dp/B084ZKL...74ORFFJID&th=1
SSD no good for long term storage?
By mazinz in forum ComputerReplies: 10Last Post: 10th Jul 2022, 02:09 -
Should my long term storage master be de-interlaced?
By 22west in forum Capturing and VCRReplies: 3Last Post: 23rd Jan 2022, 21:11 -
Pioneer DVR a new experiment - long term m.2 storage
By jwillis84 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Jan 2020, 00:00 -
Compression for long term storage
By indijay in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2019, 11:17 -
Need long term plan! Save my DVDs
By Scott Maze in forum Video ConversionReplies: 3Last Post: 5th Sep 2019, 08:34
