Results 1 to 17 of 17
    Sep 2005
    Darkest Peru
    In the past, ripping Adult Swim videos was simple. Yt-dlp worked fine since there was no encryption.
    They've now gone to widevine. While getting a key is easy enough, I'm missing something.
    After the first commercial break, the download stops even though it continues in the browser.
    The playlists are warner media at
    https://vod-media-lln.warnermediacdn.com/adultswim/cenc/
    master_wv_de.m3u8 (there is no mpd) contains the different versions. So the 'layer6_wv.m3u8' will do 1080p.
    Grabbing that playlist I see the segments are wm_6_0_0.mp4 through wm_6_0_106.mp4.
    Then at the commercial break there is:
    #EXT-X-DISCONTINUITY
    #EXT-X-CUE-OUT:0
    #EXT-X-MAP:URI="wm_6_1.mp4"
    #EXTINF:6.006,
    Then the segments are wm_6_1_*.mp4 instead of wm_6_0_*.mp4.
    N_m3u8dl-re doesn't seem to know to resume after the next section of segments. Thoughts?
    I don't know what else to provide.
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You could provide a video URL? I'm asking because for this
    https://www.adultswim.com/videos/apollo-gauntlet/eros
    I can download it easily with no problems like you mentioned. So a URL would be nice to have
    Sep 2005
    Darkest Peru
    That video is short and probably doesn't have a commercial break.
    https://www.adultswim.com/videos/demon-slayer/someones-dream
    Playlist: https://vod-media-aka.warnermediacdn.com/adultswim/cenc/19d98c54340a04225722750ab11016...ame=top-2.15.0
    Key=
    7883dc804772f614d235809d00000000:f8d5c5c5840e9e888b584a1f3b5fcfde
  4. Member aqzs's Avatar
    Mar 2024
    Paris
    When fetching API by hand (my browser doesn't let me play this one for some reason) I got that video id :
    AZEtqNWaSaru9Cdsy7g4
    And got this media_id :
    85dd75a69f06a2a9846c7a92e11eada896564ca8
    Which returned 3 manifest (PR, FP, WV) :
    https://vod-media-aka.warnermediacdn.com/adultswim/cenc/19d98c54340a04225722750ab11016f400000000/master_wv_de.m3u8
    But I'm getting "08:18:55.616 ERROR: Input not supported" even with headers..
    HTML Code:
    import requests
    from pprint import pprint
    id = "AZEtqNWaSaru9Cdsy7g4"
    print('id: ', id)
    params = (('fields', 'title,type,duration,collection_title,poster,stream,title_id,auth,media_id,launch_date,auth_launch_date,disable_ads,season_number,episode_number'),)
    response = requests.get(f'https://www.adultswim.com/api/shows/v1/videos/{id}', params=params).json()
    media_id = response['data']['video']['media_id']
    print('media_id: ', media_id)
    season_number = response['data']['video']['season_number']
    episode_number = response['data']['video']['episode_number']
    title = response['data']['video']['title']
    params = (('appId', 'eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJuZXR3b3JrIjoiYWR1bHRzd2ltIiwicHJvZHVjdCI6InR2ZSIsInBsYXRmb3JtIjoid2ViLXRvcDIiLCJhcHBJZCI6ImFkdWx0c3dpbS10dmUtd2ViLXRvcDItZWphdWdvIn0.fjf3vyXbgvxlOQo8RBmic9FQtIUvE_oxVunWFpOiLwQ'),)
    response = requests.get(f'https://medium.ngtv.io/v2/media/{media_id}/desktop', params=params).json()
    mpd_url = response['media']['desktop']['widevine']['cenc']['url']
    print('mpd_url: ', mpd_url)
    media_id:  85dd75a69f06a2a9846c7a92e11eada896564ca8
    mpd_url:  https://vod-media-aka.warnermediacdn.com/adultswim/cenc/19d98c54340a04225722750ab11016f400000000/master_wv_de.m3u8
    appId token doesn't contains sensitive data and is static :
    HTML Code:
    var i = Cn.PlayerConfigBuilder.forSetup().withContainer(e.container).withMetadata(Cr({}, Object.assign({}, {
        env: "production" === window.AS.Environment.getEnv() ? "prod" : "ite",
        companyId: "e1b9076f-e876-436d-ba0a-d0fac24ff03e",
        appId: "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJuZXR3b3JrIjoiYWR1bHRzd2ltIiwicHJvZHVjdCI6InR2ZSIsInBsYXRmb3JtIjoid2ViLXRvcDIiLCJhcHBJZCI6ImFkdWx0c3dpbS10dmUtd2ViLXRvcDItZWphdWdvIn0.fjf3vyXbgvxlOQo8RBmic9FQtIUvE_oxVunWFpOiLwQ",
        adType: "SSAI"
  5. Manually remove the ads from m3u8 then download with this command
    N_m3u8DL-RE --check-segments-count false --base-url https://vod-media-aka.warnermediacdn.com/adultswim/cenc/19d98c54340a04225722750ab11016f400000000/layer6/ layer6_wv.m3u8 --key 7883dc804772f614d235809d00000000:f8d5c5c5840e9e888b584a1f3b5fcfde --save-name hentai
    Modified m3u8
    https://gofile.io/d/htPMSA
  6. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Downloading the video (only) using your command and edited m3u8 works fine. It has 47:30. But after muxing it to mkv, around ~30 min mark, there's an encrypted section.
    Edit: @OP, I don't think there's a straight solution for this. You could take @frieren's solution and just manually cut out the encrypted parts. Those are most likely the remaining ads.
    Edit 2: here's a download link to the full uncorrupted video https://www.transfernow.net/dl/20240819qViM8cNv
  7. After extensive consultation with Pepe, we were able to come up with this:
    The reason the video was not correctly downloaded is because N_m3u8DL-RE gives up an '#EXT-X-DISCONTINUITY' HLS tag.
    This tag is used when there are changes in the video fragments (a discontinuity). In this case, the tag only changed the initialization fragment, which would have been fine, if one the init fragments didn't have a single byte difference. This is the reason N_m3u8DL-RE stopped processing the manifest.
    So 'forcing' the complete download of the manifest by removing the discontinuity tags would still leave the one part encrypted.
    What had to be done is splitting the manifest before and after the discontinuity section, which left three separate manifests that had to be downloaded individually.
    I also removed the first fragment of parts 2 and 3 so the text at the start of the video wouldn't repeat itself in the middle. There is still an about one second long black screen between part transitions.
    Merging there manifests results in this file:
    https://www.swisstransfer.com/d/5c0bb331-238b-4760-8648-fb63a1fe939b
    @2nHxWW6GkN1l916N3ayz8HQoi:
    Your download seems to be unavailable.
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  8. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Weird. I just tested it in Tor browser with a random country and works. I guess I should stop using transfernow if it fails
  9. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Until N_m3u8DL-RE fixes their program, here's a script that does all the steps that were explained here
    import re
    from os import makedirs, listdir
    from os.path import join, exists
    from subprocess import run
    import requests
    MASTER_M3U8 = "https://vod-media-aka.warnermediacdn.com/adultswim/cenc/19d98c54340a04225722750ab11016f400000000/master_wv_de.m3u8?playername=top-2.15.0"
    KEY = "7883dc804772f614d235809d00000000:f8d5c5c5840e9e888b584a1f3b5fcfde"
    VIDEO_RESOLUTION = ""
    AUDIO_BANDWIDTH = ""
    TEMP_FOLDER = "temp"
    if not exists(TEMP_FOLDER):
        makedirs(TEMP_FOLDER)
    def split_m3u8(m3u8_name, m3u8_url):
        response = requests.get(m3u8_url).text
        m3u8_url = m3u8_url.split("/")
        m3u8_url.pop()
        init_m3u8 = response.split("#EXT-X-MAP:")[0]
        end_m3u8 = "#EXT-X-ENDLIST"
        m3u8_maps = response.split('#EXT-X-MAP:')[1:]
        m3u8_maps = [f'#EXT-X-MAP:{m.strip()}' for m in m3u8_maps if m.strip()]
        fragment_name = m3u8_name.split("_")[0] + "_"
        fragment = 0
        commands = []
        for current_map in m3u8_maps:
            fragment += 1
            current_map = current_map.split(end_m3u8)[0]
            current_map = current_map.splitlines()
            last_lines = current_map[-2:]
            has_disco = False
            for line in last_lines:
                for tag in ['#EXT-X-DISCONTINUITY', '#EXT-X-CUE-OUT']:
                    if tag in line:
                        has_disco = True
                        break
                if has_disco:
                    break
            if has_disco:
                current_map.pop()
                current_map.pop()
            for i in range(0, len(current_map)):
                if "#EXTINF:" in current_map[i]:
                    current_map[i + 1] = "/".join(m3u8_url + [current_map[i + 1]])
                elif "#EXT-X-MAP:" in current_map[i]:
                    uri = re.findall(r'URI="([^"]+)"', current_map[i])[0]
                    new_uri = "/".join(m3u8_url + [uri])
                    current_map[i] = current_map[i].replace(uri, new_uri)
            current_map = "\n".join(current_map)
            current_map = "\n".join([init_m3u8, current_map, end_m3u8])
            m_name = f'{m3u8_name}_part_{fragment}.m3u8'
            output_path = join(TEMP_FOLDER, m_name)
            with open(output_path, "w") as f:
                f.write(current_map)
            output_name = m3u8_name.split("_")[0] + "_" + str(fragment)
            commands.append(
                f'N_m3u8DL-RE "{output_path}" '
                f'--key {KEY} -M format=mkv '
                f'--save-name "{output_name}"'
        for c in commands:
            run(c)
        files = listdir(".")
        ffmpeg_txt = ""
        for f in files:
            if f.startswith(fragment_name) and ".MUX." not in f and "_dec" not in fragment_name:
                if "_full" not in f:
                    ffmpeg_txt += f"file '{f}'\n"
        fragment_name = fragment_name.split("_")[0]
        ffmpeg_txt_path = "ffmpeg_txt.txt"
        with open(ffmpeg_txt_path, "w") as f:
            f.write(ffmpeg_txt)
        full_name = f'{fragment_name}_full.mkv'
        run(f'ffmpeg -f concat -i "{ffmpeg_txt_path}" -c copy {full_name}')
        return full_name
    def process_master_m3u8():
        response = requests.get(MASTER_M3U8).text
        lines = response.splitlines()
        stream_inf_tuples = []
        for i in range(len(lines)):
            line = lines[i].strip()
            if line.startswith("#EXT-X-STREAM-INF"):
                m3u8_path = lines[i + 1].strip()
                stream_inf_tuples.append((line, m3u8_path))
        video_tuples = []
        audio_tuples = []
        for stream_inf, m3u8_path in stream_inf_tuples:
            paths = MASTER_M3U8.split("?")[0].split("/")
            paths.pop()
            paths.extend(m3u8_path.split("/"))
            m3u8_path = "/".join(paths)
            if "RESOLUTION=" in stream_inf:
                resolution = re.findall(r'RESOLUTION=\d+x(\d+)', stream_inf)
                video_tuples.append((int(resolution[0]), m3u8_path))
            elif "BANDWIDTH=" in stream_inf:
                bandwidth = re.findall(r'BANDWIDTH=(\d+)', stream_inf)
                audio_tuples.append((int(bandwidth[0]), m3u8_path))
        video_tuples = sorted(video_tuples, key=lambda v: v[0], reverse=True)
        if VIDEO_RESOLUTION not in [None, ""]:
            video_tuples = list(filter(lambda v: str(v[0]) == VIDEO_RESOLUTION, video_tuples))
        video_tuple = video_tuples[0]
        audio_tuples = sorted(audio_tuples, key=lambda a: a[0], reverse=True)
        if AUDIO_BANDWIDTH not in [None, ""]:
            audio_tuples = list(filter(lambda a: str(a[0]) == AUDIO_BANDWIDTH, audio_tuples))
        audio_tuple = audio_tuples[0]
        fulls = []
        fulls += [split_m3u8(f'video_res_{video_tuple[0]}', video_tuple[1])]
        fulls += [split_m3u8(f'audio_band_{audio_tuple[0]}', audio_tuple[1])]
        mkvmerge = f'mkvmerge {" ".join(fulls)} -o content_full.mkv'
        run(mkvmerge)
    if __name__ == '__main__':
    Run it on a empty folder. You're gonna need N_m3u8, mkvmerge, ffmpeg, mp4decrypt. The final output is "content_full.mkv". Don't forget to delete the temp files. The input is the master m3u8 URL and the decryption key.
    Sep 2005
    Darkest Peru
    Modified m3u8
    Edited a bunch...:
    Another problem is the audio is in Layer7, so you'd have to edit both playlists.
    But it still doesn't work. The file size is increased, but nothing after the break plays. Remuxing even removes the data after the break.
    Tried yt-dlp with ffmpeg as downloader and then mp4decrypt. It seems to download the master playlist audio and video okay (based on size), but doesn't decrypt.
    Mind you, yt-dlp w/o ffmpeg errors that 'initialization fragment found after media fragment' and ffmpeg errors A LOT 'Failed to seek for auxiliary info, will only parse senc atoms for encryption info'.
    Edit... and so...:
    Just to prove this was doable, you need to edit the audio and video m3u8 files and SPLIT them at the commercial breaks. So in this case layer6_wv is split into L6a and L6b. layer7_wv_0 is L7a and L7b.
    N_m3u8DL-RE.exe -M format=mp4 --check-segments-count false --key a8099fd53564a923956eca3000000000:e52353c682f180e478712f2237df91aa --base-url "https://vod-media-cf.warnermediacdn.com/adultswim/cenc/b69aa9fd1a102d803a270d13b8f753a300000000/layer6/" l6a.m3u8 --save-name 6a
    N_m3u8DL-RE.exe -M format=mp4 --check-segments-count false --key a8099fd53564a923956eca3000000000:e52353c682f180e478712f2237df91aa --base-url "https://vod-media-cf.warnermediacdn.com/adultswim/cenc/b69aa9fd1a102d803a270d13b8f753a300000000/layer6/" l6b.m3u8 --save-name 6b
    N_m3u8DL-RE.exe -M format=mp4 --check-segments-count false --key a8099fd53564a923956eca3000000000:e52353c682f180e478712f2237df91aa --base-url "https://vod-media-cf.warnermediacdn.com/adultswim/cenc/b69aa9fd1a102d803a270d13b8f753a300000000/layer7/" l7a.m3u8 --save-name 7a
    N_m3u8DL-RE.exe -M format=mp4 --check-segments-count false --key a8099fd53564a923956eca3000000000:e52353c682f180e478712f2237df91aa --base-url "https://vod-media-cf.warnermediacdn.com/adultswim/cenc/b69aa9fd1a102d803a270d13b8f753a300000000/layer7/" l7b.m3u8 --save-name 7b
    (echo file '6a.mp4' & echo file '6b.mp4' )>listv.txt
    ffmpeg -safe 0 -f concat -i listv.txt -c copy test.mp4
    (echo file '7a.mp4' & echo file '7b.mp4' )>lista.txt
    ffmpeg -safe 0 -f concat -i lista.txt -c copy test-a.mp4
    ffmpeg.exe -i test.mp4 -i test-a.mp4 -c copy -disposition:s:0 default -metadata:s:1 language=eng Complete.mp4
    ...never bothering with this again. Ugh.
  11. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    I think I found an easy fix for this site that skips over their broken ad manifest. Do you have another video URL where you get ads? The demon slayer one is gone.
    Sep 2005
    Darkest Peru
    I don't know what info you need. Here's an episode: https://www.adultswim.com/videos/common-side-effects/pilot
    N_m3u8DL-RE "https://vod-manifests-fly.warnermediacdn.com/csm/builder/734364842,proxy.1,735184591,729790619,735061713,734609818,734487686,672057476,734778148,proxy.2.m3u8?yo.p.si=csm-e-cewbdause1vprlf-0bd7db27f8a5204a6-45-1741292602151&yo.p.hn=csm-e-cewbdause1vprlf-0bd7db27f8a5204a6.bln1.yospace.com&yo.p.ci=478924639&yo.p.fn=aHR0cHM6Ly92b2QtbWVkaWEtZmx5Lndhcm5lcm1lZGlhY2RuLmNvbS9hZHVsdHN3aW0vY2VuYy83ZDFiODM3NWNjZWU1NTJhYWJiYTJjNzhlYWU2MGVhZDAwMDAwMDAwL21hc3Rlcl9tZC5tM3U4&yo.p.bp=MANIFEST&yo.p.cu=Q3dRQg==&_fw_ae=&user_ids=&nw=48804&yo.me=true&afid=325214640&prof=48804%3Aadultswim_web_vod&yo.oh=Y3NtLWUtd2JkLXZsZi1lYi50bHMxLnlvc3BhY2UuY29t&yo.kf=wv-cenc&yo.up=https%3A%2F%2Fvod-media-fly.warnermediacdn.com&_fw_ar=&yo.av=3&caid=51470adab5b4ff0235de4c378ddefe616d01011e&yo.aas=true&conf_csid=as.com_vod_web&context=478924639&playername=top-2.14.0&vdur=1289.054&vip=184.164.175.47"  --key 2995ba01b09e5cede9700f7700000000:9cd3d6f7ecc0b58a258f4f9ad021e2b1 --use-shaka-packager -M format=mkv
    There's about 10 manifests with this to select from.
  13. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Link was enough. Thanks for the url. Interesting, seems the trick can't be used for all videos. Good to know. For example for this video
    https://www.adultswim.com/videos/dragon-ball-z-kai/a-boundary-pushing-brawl-goku-friez...nd-ginyu-again
    You can download the video in 1 easy command by skipping over the drm.
    yt-dlp "http://amd.cdn.turner.com/adultswim/episodes/us_geo/dragonballzkai/2015/11/dragonballzkai_cc_044/hls/dragonballzkai_cc_044_stream_tv.m3u8"
    Or if you're outside the US
    yt-dlp "http://amd.cdn.turner.com/adultswim/episodes/us_geo/dragonballzkai/2015/11/dragonballzkai_cc_044/hls/dragonballzkai_cc_044_stream_tv.m3u8" --add-headers "X-Forwarded-For: 143.231.249.138"
    But the link you sent can't be used for that.
    A custom script for splitting the manifest still seems to be better suited for this site in the end since you can't do it like that for all videos.
    Sep 2005
    Darkest Peru
    Are you saying you can't get Common Side Effects to rip? I was working on a script for something else and found that rips easy. Just let yt-dlp do all the work:
    yt-dlp.exe "https://www.adultswim.com/videos/common-side-effects/pilot" -o "Common_Side_Effects_S01E01.mp4"
    Could be because the first few episodes don't require a log in.
    Edit: If your provider is supported, you can look up the ap_mso with
    yt-dlp.exe --ap-list-mso
    and then add
    --ap-mso MSO --ap-username USERNAME --ap-password PASSWORD
    Sep 2005
    Darkest Peru
    Sorry to double post, but found something interesting. With these streams, yt-dlp can download them properly, but can't decrypt if your cable provider isn't supported. N_m3u8dl-RE can decrypt them, but can't download them properly (it cuts off at the first commercial break).
    Is it possible to get n_m3u8dl-re.exe to use yt-dlp to perform the download? Or have yt-dlp.exe download but get n_m3u8dl-re to decrypt?
  16. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    yt-dlp is not a suitable program for adultswim drm content. You can see for yourself
    yt-dlp -f 1110 "https://vod-media-aka.warnermediacdn.com/adultswim/cenc/19d98c54340a04225722750ab11016f400000000/master_wv_de.m3u8?playername=top-2.15.0"
    Will download encrypted 360p for that demon slayer episode. Even though the page is gone, the m3u8 is still on their servers. Then for decrypting you can try
    mp4decrypt --key 7883dc804772f614d235809d00000000:f8d5c5c5840e9e888b584a1f3b5fcfde video.mp4 video_decrypted.mp4
    or
    shaka-packager in=video.mp4,stream=video,output=video_decrypted.mp4 --enable_raw_key_decryption --keys key_id=7883dc804772f614d235809d00000000:key=f8d5c5c5840e9e888b584a1f3b5fcfde
    In both cases it will result in an unplayable video. So yt-dlp is useless for this particular case even if it can download the full encrypted video (it's still broken because of issues that were already explained). I suppose you could attempt with a plugin for yt-dlp that has mp4decrypt included. But if base yt-dlp+mp4decrypt/shaka doesn't work, then I doubt a plugin would be more effective.
    https://github.com/pratikpatel8982/yt-dlp-mp4decrypt
    or
    https://github.com/aarubui/yt-dlp-mp4decrypt
    If you're curious, you can give it a shot
    Edit: in your case it seems it found a drm free stream, that's why it worked. I don't think it's guaranteed that you'll find one for all videos though
    Sep 2005
    Darkest Peru
    As a follow up:
    I discovered that the extension 'Live Stream Downloader' works wonders with this.
    Play the video, click on the extension, select layer6_wv. You'll be told there are different timelines. Click 'Download Each Separately'.
    Download layer7_wv_0 the same way.
    Then I wrote a simple Windows batch script that finished everything afterwards:
    The parts are saved as four .mkv files. I use mp4decrypt on them with the key I get with WidevineProxy2.
    The video then audio parts need to be concatenated.
    I run the video through CCExtractor then mux the whole thing finished into an mkv file with ffmpeg.
    Finally, this is a piece of cake for me.
    Edit: This works very well. Anyone interested, just ask. It's a Windows .bat file for n_m3u8dl-re, ffmpeg & ccextractor. Your browser needs widevineproxy2 for the keys and Live Stream Downloader for the files themselves. The script does the rest of the work.
