Hello,
I have a modified Datavideo TBC-1000 with the audio distribution amp removed. I also have a Panasonic DMR-ES15 for its passthrough TBC-like ability. My analog capture device is a Black Magic Mini Converter analog-to-SDI box.
I want to capture vhs via Domesday Duplicator (DdD) and conventional, to later sync the DdD video with the conventional audio. Capturing linear audio is not possible with the DdD. That's why conventional capture is still needed. (I'm guessing it's easier to sync if both video & audio is captured vs only the audio, even though only the audio is used).
I assume the TBC-1000 has a better TBC than any dvd or BD recorder.
Because I need a TBC unit that helps with dropouts, so hopefully the two separately captured files will sync perfectly, which chain do think is better?
A) [VIDEO signal] vcr>TBC-1000>Black Magic [AUDIO signal] vcr>Black Magic
B) [VIDEO signal] vcr>DMR-ES15>Black Magic [AUDIO signal] vcr>DMR-ES15>Black Magic
I thought I read somewhere the DMR-ES15 has hardware sync that locks the video & audio signals together?
Thanks for any suggestions, opinions.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 16 of 16
TBC-1000 don't have any audio dist. amp to remove to begin with, it's video only device. Anyway, you can wait for the new hardware to come out which includes two stereo line level audio channels inputs (Linear + HiFi) and two RF inputs (Video + HiFi).
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS -
Originally Posted by Lordsmurf
Yes and no, Audio is a passthrough feature, it is not processed inside the TBC board. But I stand corrected in saying "don't have audio dis. amp", Apologies.
Yes and no.
ES15 has a non-TBC frame sync. But it syncs in audio. It's not "locked" whatsoever, but it is sync'd internal on output.
The most important factor to remember is that ES15 adds a delay, so you must use audio output from the ES15. If you bypass only video, it will be out of sync.
Better frame TBC, correct.
Internals matter.
- The TBC-1000 is video only via the VF-301x card.
- The TBC-1000 audio is a bypass direct into the VP-299 output distro amp card. So the audio is not "TBC'd" at any time.Want my help? Ask here! (not via PM!)
Internals matter.
- The TBC-1000 audio is a bypass direct into the VP-299 output distro amp card. So the audio is not "TBC'd" at any time.[/QUOTE]
Because the TBC-1000 doesn't process audio in any way, do you think it's better to use the Panasonic for input/output video/audio?
or use the TBC-1000 for video and feed the audio direct to the cap card?
I'm thinking in terms of less dropouts, so I can better sync the two captured files (DdD and conventional). -
I'm low on time, but I wanted to give a quick answer.
The ES10 is not a good option. The non-TBC frame sync will have some % of dupe frames, maybe drop if source is bad or falsely flagged. Non-TBC frame syncs don't correct errors, merely treat them as speed bumps.
The entire "separate audio and video" situation is major weakness of the RF methods, and I'm not convinced their MISRC will fix it. (I don't have time to expand on that thought..
Your goal is a visual assist in NLE for audio/video alignment, and I do this myself when merging sources (audio from one, video from another).
The capture card and capture software can affect this more than anything else, namely settings that attempt to sync.
I'd have to consider TBC-1000 + separate audio, with VirtualDub and proper timing settings.
I'd actually consider a distribution amp (audio only, non-DataVideo), then dual record to a computer using video capture software, and another that uses audio recording software (like Sound Forge). Then visually compare the waves. I'd seen instances where the was mismatch, and the "raw" audio recording would drift. The amp may add delay, so adjust accordingly in the NLE timeline.
How do you make video capture overly complicated? Use RF methods.Want my help? Ask here! (not via PM!)
[/QUOTE] ES15 has a non-TBC frame sync. But it syncs in audio. It's not "locked" whatsoever, but it is sync'd internal on output.[/QUOTE]
This is why I'm wondering if it's better to use the ES15, even though I'm guessing the TBC-1000 has a better TBC.
Which chain do you think is the better option?
A) Video: vcr> TBC-1000> Black Magic analog SDI
Audio: vcr> Black Magic
B) Video: vcr> ES15> Black Magic
Audio: vcr> ES15> Black Magic -
You're still stuck on the false idea that the ES10 will somehow "lock" (or "sync" or whatever) the audio. It does not. The ES10 syncs audio to itself, but with uncorrected frames. So it's a terrible timecode master.
If the goal is visual sync of video (which it is), in order to sync the audio, then the TBC-1000 is obvious. The delay is 1 field, not that it matters here, for this use.
You're really seeking genlock (sort of), which still won't work here.
BM is a terrible card for VHS capture, so TBC-1000 is especially recommended.Want my help? Ask here! (not via PM!)
The reason I went with Black Magic is all because of Domesday Duplicator capture. it's recommended capturing DdD with Linux, not Windows. Prior to using Linux, my analog setup was an Osprey 827/e, but it isn't Linux compatible. BM is cross platform.
I'm somewhat new at proper vhs capture. I've done it wrong for years admittedly. But I do have a AG1980 and TBC-1000, and now ES15.
What I'm also stuck on is if the whole point of TBC is to prevent dropouts. To me no dropouts means it will be easier to sync the two captured files (DdD and conventional). -
A "dropout" in video jargon is something else. I don't know the best term for what you're describing. I assume you mean discontinuities; especially where a recording ends and there's a gap of blank tape before the next one.
They claim it's compatible with the standard V4L2 in Linux. False advertising?
It is possible, by combining the DdD with a "clockgen lite". Only one user has tested this so far. The only real obstacle is that DdD still has no CLI capture software, so he can't easily script them to start at the same instant. He is using an auto-clicker to move the mouse and press the GUI "Capture" button simultaneously with CLI audio capture start.
Here is the Clockgen Lite documentation. It's normally used with CX card(s).
https://github.com/namazso/cxadc-clockgen-mod
Even if you got this set up, it's still not a bad idea to do a conventional reference capture at the same time.Last edited by Brad; 29th Aug 2024 at 18:26.
My YouTube channel with little clips: vhs-decode, comparing TBC, etc. -
There's two kind of jargon for dropout.
That link refers to the "magnetic dropout", caused by tape damage, often presenting as comets or tracking noise.
But the other dropout is "missing signal" (and thus leads to dropped frames). The signal literally drops out of existence for a portion of time, screwing up temporal timing. Some are analog induced (U-matic issues I've dealt with before), others digital induced (such as what the craptastic Blackmagic cards often do). It has nothing to do with recording gaps, tape snow, etc. Total loss of signal for whatever reason.Want my help? Ask here! (not via PM!)
I've been in contact with Terry Stephenson from Osprey Engineering and Support. He provided me with a few Linux drivers, none worked. He did say "to be truthful, myself and this company is not too swift when it comes to Linux. To my understanding, yes you should be able to use Osprey Preview and Ceylon with the Linux drivers".
With vhs, I do cap conventional simultaneously with DdD. I don't cap conventional with laserdisc, however.
Like Lordsmurf said, I thinking it's better to use the TBC-1000, with the audio from the vhs player going direct to the BM card, vs a dvd-recorder even though both video & audio are connected. -
Interesting topic. I don't think having "audio locked" to a traditional video capture really will affect anything when it comes to syncing linear audio up to your VHS_Decode capture.
Audio will continue to be captured even if there is no signal present at all (dropouts) as lack of audio is preserved as silence or other noise in the timeline. The issue with video syncing is when video frames drop and aren't appropriately compensated for, the video advances faster than the audio does when played back at the correct frame rate and the audio will sound like it gets a little further behind with each dropped frame.
In reality, the audio is correct and the video is advancing too quickly in the absence of all the frames it is supposed to contain.
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum CapturingReplies: 424Last Post: 10th Oct 2024, 09:24 -
Panasonic DMR-ES15 PAL - how to setup for TBC passthrough
By spotty in forum CapturingReplies: 9Last Post: 30th May 2023, 05:06 -
NTSC VHS newbie summary #2: TBC Budget option: Panasonic DMR-ES10 ES15
By brockway in forum CapturingReplies: 0Last Post: 14th Jan 2022, 10:39 -
DMR-ES15 or TBC 1000
By Beyonder123 in forum CapturingReplies: 2Last Post: 24th Apr 2020, 02:25 -
ES15 as TBC in combo with Panasonic NV-FS200?
By mathijsmathijs in forum CapturingReplies: 6Last Post: 14th Dec 2019, 11:32
