Results 1 to 30 of 51
  1. Good day/evening,
    Roy here,
    First time poster, long time lurker…
    I’m relatively new to this hobby, and don’t seem to have an eye for detail (yet). Looking for VHS capture advice, evaluations and helpful opinions.
    My hardware workflow:
    JVC HR-S7800U (purchased though LS)
    I-O Data GVUSB2 (opinions welcomed, has been suggested that I upgrade)
    Asus H110M-C motherboard (1151 socket)
    Intel Core 17-7700K Processor
    32G DDR4 2133
    Kingston 240GB SSD (Win 10 Pro x64 22H2 operating system)
    Seagate BarraCuda 2TB HDD – 3.5 Inch SATA 6Gb/s 7200 RPM (storage/staging and or transfer)
    500-watt power supply
    My software workflow:
    AmaRecTV 3.10 w/HuffYUV 2.1.1 (AVI capture, has no sync issues that I can see)
    Handbrake 1.8.2 (AVI to mp4 convert, a work in progress, sync issues)
    VLC (AVI to mp4 convert, a work in progress, sync issues)
    Attached:
    AmaRecTV Avi clip
    Handbrake conversion Mp4 clip
    AmaRecTv screenshot settings
    I-O Data GVUSB2 screenshot settings
    HandBrake screenshot settings
    Thank you for your consideration,
    Roy
  2. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Originally Posted by 916Area52 View Post
    Attached:
    AmaRecTV Avi clip
    Before going further, where is the head switching noise?
  3. Originally Posted by lollo View Post
    Attached:
    AmaRecTV Avi clip
    Not familiar with that term "where is the head switching noise". Please explain... The audio comes from the VCR through the GVUSB , if I understand the question.
  4. Capturing Memories dellsam34's Avatar
    Jan 2016
    He may have crop enabled in the capture software.
  5. Originally Posted by 916Area52 View Post
    Attached:
    AmaRecTV Avi clip
    Not seeing any "head switching noise" as described here http://www.avartifactatlas.com/artifacts/head_switching_noise.html
  6. Originally Posted by dellsam34 View Post
    Not that I'm aware of.
    May 2005
    Australia-PAL Land
    @916Area52, well done on a comprehensive post. Hopefully, we'll be able to help you out.
    @Dellsam, here, AmarectV is set to not crop.
    @Lollo, what's this then?
    [Attachment 81548 - Click to enlarge]
  8. Originally Posted by Alwyn View Post
    Alwyn, Thank you
    May 2005
    Australia-PAL Land
    @916, the AVI sample you gave us looks like it has been snipped by VLC Player (MediaInfo shows). Could you crank up AVIDemux and do a snippet with that; then we'll get a true copy of your capture. Snippet instructions on my site here. Basically, open your capture file, leave video and audio both on Copy, set the Output format to AVI Muxer and set up a small snip (15 seconds for AVI) of an area with movement with the A and B buttons and then save and attach here. Max attachment is 500mb.
    That should satisfy Lollo.
    From what I can see so far, the AVI video is ~4 frames slow on the audio, but that could be from the VLC Player re-encode.
    Also, your MP4 encode is showing 3:2, when I think it should be 4:3. AVI capture files don't have the display aspect ratio stored in them so apps just use 720-480, which is incorrect. We can deal with that later.
  10. @916Area52:
    The capture looks ok. The .avi is 2-3 telecined.
    The Handbrake MP4 is flawed. You should IVTC (Inverse telecine) your captured .avi, and then you will get the original 23.976fps progressive film frames.
    Edit: IVTC is called 'Detelecine' in Handbrake. So set it to 'Default' rather than 'Off' (your screenhot#15) and see what you get. (I didn't try as I usually use Avisynth for video processing).
    Or if you don't get along with Handbrake try this ffmpeg commandline:
    ffmpeg -y -i "your.avi" -c:a aac -c:v libx264 -preset slow -crf 18 -pix_fmt yuv420p -vf detelecine=first_field=top:pattern=23:start_frame=0,crop=704:480,setdar=4/3 "IVTC_out.mp4"
  11. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Nice VCR.
    Excellent capture card, no need to upgrade anything.
    AmarecTV 3.10 is the best capture software.
    Handbrake is useless.
    VLC can be used as player, not as editor.
    Attached:
    In "Graph2(Preview)" disable deinterlacing (useless resource consuming feature)
    In "Advanced" set Priority to High, enable "Match the start timing of the audio with a video" and enable Make a report file, to have a full log of what happens during capturing; in particolar you can check there where are located the inserted and dropped frames (if any) and understand why.
    Attached:
    AmaRecTV Avi clip
    As others have noticed, this is probably not the raw capture, but a processed file. I still do not understand why the head switching noise is not present, having you disabled the cropping option and being the final size 720x480. Follow Alwin recommendation or use VirtualDub trimming to provide an untouched sample of your capture.
    Based on the provided file I can say that the capture looks ok. The is some halo somewhere, use edit mode in your VCR and disable all sharpening features in the VCR and in the capture card:
    The levels are correct and no action is required:
    As Sharc already wrote the source needs inverse telecine prior to filtering.
    To check that, you can run a simple AviSynth script to separate the fields, load it into VirtualDub and step frame-by-frame, recognizing the field architecture ... a a a b b c c c d d ...
    AviSource("HuffYuv-007-30fps-02-sample03Ama.avi-Trim.avi")
    # separate fields tff
    AssumeTFF().separateFields()
    A basic AviSynth processing is appropriate, and improves a little bit the overall look. Here a sample (no halo removal):
    video_org=AviSource("HuffYuv-007-30fps-02-sample03Ama.avi-Trim.avi")
    # trimming
    	trim_start=418
    	trim_end=986
    video_org_trim=video_org.trim(trim_start,trim_end)
    # cropping
    	crop_left=4	# | rimozione esatta delle bande nere sinistra, sopra, destra e del disturbo sotto
    	crop_top=0	# | 720-(8+8)x480-(0+0)=704x480
    	crop_right=8
    	crop_bottom=0
    video_org_trim_crop=video_org_trim.crop(crop_left,crop_top,-crop_right,-crop_bottom)
    # plugins directory
    plugins_dir="C:\Users\giuse\Documents\VideoSoft\MPEG\AviSynth\extFilters\"
    	# TIVTC
    loadPlugin(plugins_dir + "TIVTCv105\TIVTC\TIVTC.dll")
    	# TemporalDegrain2
    Import(plugins_dir + "TemporalDegrain-v2.2.1_modGMa.avsi")
    	# RgTools
    loadPlugin(plugins_dir + "RgTools-v1.0\x86\RgTools.dll")
    	# MaskTools2
    loadPlugin(plugins_dir + "masktools2-v2.2.23\x86\masktools2.dll")
    	# MVTools
    loadPlugin(plugins_dir + "mvtools-2.7.41-with-depans20200430\x86\mvtools2.dll")
    	# FFT3DFilter
    loadPlugin(plugins_dir + "FFT3dFilter-v2.6\x86\fft3dfilter.dll")
    	# FFTW
    loadPlugin(plugins_dir + "LoadDll\LoadDll.dll")
    loadDll(plugins_dir + "fftw-3.3.5-dll32\libfftw3f-3.dll")
    	# LSFmod
    Import(plugins_dir + "LSFmod.v1.9.avsi")
    ### inverse telecine
    ivtc=video_org_trim_crop.AssumeTFF().TFM(order=1, PP=0).TDecimate()
    ### convert to YV16
    ivtc_yv16=ivtc.convertToYV16()
    ### denoising
    denoised_yv16=ivtc_yv16.TemporalDegrain2(degrainTR=3)
    ### convert to YUY2
    denoised=denoised_yv16.convertToYUY2()
    ### convert to YV12
    denoised_yv12=denoised.convertToYV12()
    ### sharpening
    sharpened_yv12=denoised_yv12.LSFmod(defaults="slow")
    ### convert to YUY2 with chroma from YUY2 color space
    sharpened=sharpened_yv12.convertToYUY2().MergeChroma(denoised)
    ### adding_borders
    restored=sharpened.addborders((crop_left+crop_right)/2,(crop_top+crop_bottom)/2,(crop_left+crop_right)/2,(crop_top+crop_bottom)/2)
    return(restored)
    Final outcome: restored.avi
    Comparison:
    Comparison with slider: https://imgsli.com/Mjg4NzQz
    For final encoding you can run a simple ffmpeg command line (you may want to add a ConvertToYV12() at the end of the AviSynth script):
    ffmpeg.exe -i restored.avs -c:v libx264 -crf 17 -preset slow -aspect 4:3 -c:a aac -b:a 128k restored.mp4
    Final outcome: restored.mp4
    You can do all this by yourself on the raw capture
    May 2005
    Australia-PAL Land
    I think it's too dark (Histogram all in the bottom half) and too saturated. The skin colours are too red.
    Here's my attempt, all in VDub2 64bit (De-telecine with ITVC filter, denoise with CCD and Temporal smoother filters, levels and saturation adjusted with Colormill filter, crop and resize to 720x540 and export as MP4).
    Apart from the levels and colour, IMO, the essential difference is Lollo's use of the AVISynth TemporalDegrain2 filter to denoise, which does a good job (possibly a bit too good in this case; the skins are a bit smooth).
  13. Originally Posted by Alwyn View Post
    To me the colors look a bit "washed out" in Alwyn's version. I agree though that lollo's degraining makes the faces too much look like wax IMO (the lady may like it though). But discussing personal preferences and taste is usually moot ....
    ... and eventually watch it on your TV as well. The impression may be different again.
    May 2005
    Australia-PAL Land
    Sharc, what's your opinion of the levels? All on the bottom half (or left half) of the histogram?
  15. Originally Posted by Alwyn View Post
    The scene plays in a dark environment with artificial light. So I think it's ok ....
    Added:
    Here the waveform of the capture (*.avi). It's a good capture, and the GV-USB2 dongle did a good job
  16. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    I never use color correction for these examples here in the forum, it is really a question of personal taste.
    Moreover, for capture of movies, in general a solid reference exist in DVD or Blu Ray releases, so the AviSynth matching histograms or matching gamma filters can be used with success.
    Concerning the denoise strength (and then plastic look), it can be sligthly softened reducing the temporal radius of the filter (for example).
    Some comparison here: https://imgsli.com/Mjg4NzY2/2/1 (more grain on the face, maybe the lady won't be happy )
    As we always say, the user has to experiment a lot with all the parameters to find the best (for him) solution
    edit:
    Yes, Hauppauge USB-Live 2 and IOData GV-USB2 are really nice cards!
    May 2005
    Australia-PAL Land
    OK thanks, Still reckon it's a bit dark.
  18. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Yes. It's always the doubt about being close to the source master or to the real world...
  19. Well now…
    Thank you All for your feedback and time spent.
    As my Sunday unfolds, I now have a plethora of information and new (to me) software to digest.
    @ lollo “You can run a simple AviSynth script to separate the fields”
    Coding/script is waaaaay beyond knowledge base and my talents, perhaps I’ll give a go at a later time.
    @ lollo “Use edit mode in your VCR and disable all sharpening features in the VCR and in the capture card”
    Thank you, and Done.
    @ Alwyn “Could you crank up AVIDemux and do a snippet with that; then we'll get a true copy of your capture?”
    Got an error flag when I stopped the recording on AmaRecTV for avidemux01. Unfortunately, I just blew by it, something to with hard drive space, I think. Error did not reoccur when AmaRecTV stopped recording for avidemux02.
    Opened both .avi files in VLC to view. VLC wanted to do something with the file structure, I opted to run as is.
    Did the "snippet" with Avidemux. Nice piece of software.
    Please see attached…
  20. Originally Posted by 916Area52 View Post
    Capture ok. As said before, just IVTC (Inverse Telecine (='Detelecine' in Handbrake)) it, see post#10 for example.
  21. Originally Posted by Sharc View Post
    Will give a go, Thank you.
  22. Originally Posted by 916Area52 View Post
    Here Handbrake settings which should work (I don't really use Handbrake though):
    [Attachment 81600 - Click to enlarge]
    [Attachment 81601 - Click to enlarge]
    [Attachment 81606 - Click to enlarge]
    or alternatively try the ffmpeg commandline of post#10.
  23. Member
    May 2005
    Australia-PAL Land
    Unless you specifically want to use Handbrake's denoising, I'd give it a miss. It looks pretty and modern, but the people who set up the cropping and resizing section must have been high on drugs at the time.
    VDub does a great job here: use the IVTC filter and you can crop/resize and export to MP4 in one hit. Set up the IVTC filter like this:
    [Attachment 81619 - Click to enlarge]
  24. Member
    May 2005
    Australia-PAL Land
    Found on Reddit. Deserves a chuckle...
    Perfect is the enemy of finished, after all.
  25. Originally Posted by Alwyn View Post
    Eh? Not to defend or bash any GUI, but just because you don't understand what to click-click in Handbrake for resizing, and yourself having been spoonfed recently only with what to click-click in Vdub for IVTC, you feel entitled to call developers of Handbrake having been "high on drugs"?
    End of rant
  26. Member
    May 2005
    Australia-PAL Land
    Eh? indeed.
    Geez Sharc, calm down. Have you ever actually tried to set a specific frame size and crop with Handbrake?
    And what on earth has being spoon fed (aka like extracting teeth) on the IVTC filter in VDub got to do with cropping in Handbrake? Or maybe you could continue spoon-feeding me and set me straight on that too...
    PS: "Click click" that's what GUIs are for. If you have to spend hours trying to work something out and then fail, that is not a good GUI.
  27. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Moreover, there is no need to resize anything!
  28. Member
    May 2005
    Australia-PAL Land
    Just setting square pixels, Lollo. Or is that against the law too?
  29. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    There is no need to set any square pixels through a lossy resizing. Keep 720x480 with a 4:3 display aspect ratio.
  30. Originally Posted by Alwyn View Post
    ...Have you ever actually tried to set a specific frame size and crop with Handbrake?
    It's all about knowing and personal experience how to use a specific GUI for a specific purpose, be it Vdub, Handbrake, Avidemux .....
    A learning curve and likes/dislikes, pros/cons for every GUI, no? In order to help the OP with Handbrake (his original tool & preference) I had to learn and try how to use it (instead of a commandline or Avisynth, or something else). And yes, I cropped to 704x480 and set the DAR correctly. Hopefully it works for him (?). Handbrake file attached: 704x480, PAR 10/11, DAR 640x480 = 4:3, no resizing.
