Results 1 to 14 of 14
  1. Hey currently I Was trying to install vdocipher videos using multiple methods, from my failure on all methods, I knew that the problem with my CDM (which was provided with the allhell3.py script) because it is from an android emulator.
    I also knew that I need an physical rooted device to get my own physical CDM.
    So, is this the only way to download VdoCipher videos? should I use a rooted device? Is there any alternatives? because I don't have access to a rooted device and I wanted to download multiple videos so I can't just ask someone to do it for me.
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Having a real CDM is a minimum requirement and necessary. You also need the right script (I haven't seen any public scripts that still work). I don't think allhell3.py is meant to be used with vdocipher. You could post the video URLs and hope someone that knows what to do with vdo will help you.
  3. I'd love to create a module for WidevineFetch that supports VdoCipher, but I don't have a CDM from a physical device, so I can't.
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Somehow unrelated question, but could you generate lots of valid cdms from the same device if you install a fresh android custom OS each time? If that's the case, you could get lots of real cdms just from a single device. The problem with vdo isn't the tricky license call. It's just that you get banned for a bad call and your cdm gets toasted fast. Makes testing and developing a solution a nightmare.
  5. This is pure speculation:
    The L3 CDM (because software based) is definitely not in the ROM (because huge security issue), must be generated while (re-)flashing the device.
    So I don't think that the CDM will be different because the firmware is the same and the device is the same, so why should the CDM be different? This makes me believe that the CDM "version" is based on some kind of "hardware value".
  6. I have created a script for vdocipher long ago based on https://www.vdocipher.com/ "demo"
    But I don't have a cdm from a real device to test it yet
    from pywidevine.device import Device
    from pywidevine.pssh import PSSH
    from pywidevine.cdm import Cdm
    from bs4 import BeautifulSoup
    import requests
    import base64
    import json
    import re
    wv_CDM = "cdm_l3.wvd"   # <--- CDM LOCATION
    input_token = input('Token: ')
    json_data = json.loads(base64.b64decode(input_token).decode("utf-8"))
    iframe = requests.get(f'https://player.vdocipher.com/v2/?otp={json_data['otp']}&playbackInfo={json_data['playbackInfo']}').content.decode()
    soup = BeautifulSoup(iframe, 'html.parser')
    script_tag = soup.find('script', {'type': 'application/json'})
    mpd_path = json.loads(script_tag.string)
    mpd_link = mpd_path['dash']['manifest']
    get_pssh = re.search('<cenc:pssh>(.*)</cenc:pssh>', requests.get(mpd_link).text).group(1)
    print('PSSH:',get_pssh)
    print(f'\n[MPD]: {mpd_link}')
    pssh = PSSH(get_pssh)
    device = Device.load(wv_CDM)
    cdm = Cdm.from_device(device)
    session_id = cdm.open()
    challenge = cdm.get_license_challenge(session_id, pssh)
    json_data["licenseRequest"] = base64.b64encode(challenge).decode("utf-8")
    token_value = json.dumps(json_data, separators=(',', ':'))
    token = {
        "token": base64.b64encode(token_value.encode('utf-8')).decode('utf-8')
    headers = {
        'content-type': 'application/json',
        'origin': 'https://player.vdocipher.com',
        'referer': 'https://player.vdocipher.com/',
        'vdo-sdk': 'VdoWeb/2.5.2'
    response = requests.post("https://license.vdocipher.com/auth", headers=headers, json=token)
    if not response.ok:
        print(f'{response}\n{response.text}')
        cdm.close(session_id)
        exit(0)
    license = base64.b64decode(response.json()["license"])
    cdm.parse_license(session_id, license)
    for key in cdm.get_keys(session_id):
        if key.type != 'SIGNING':
            print(f"[KEY]: {key.kid.hex}:{key.key.hex()}")
  7. Member aqzs's Avatar
    Mar 2024
    Paris
    Sorry to say that but posting a script like that will give you a loooot of DMs from vdocipher course resellers..
  8. Originally Posted by aqzs View Post
    at first does it work?
    Jul 2023
    India
    <Response [403]>
    {"code":2074,"message":"Please update app from Play Store","isErrorRecoverable":true}
  10. Originally Posted by sarvo99 View Post
    <Response [403]>
    wondering what's wrong
    don't burn your CDM
  11. Member aqzs's Avatar
    Mar 2024
    Paris
    <Response [403]>
    That's the error I'm getting since a month.. I don't what they changed.. I tried using android headers too (because CDM is dumped from android device, maybe they are checking that too) but got :
    {"code":2074,"message":"Please open in Android app","isErrorRecoverable":true}
    or :
    {"code":2074,"message":"Device not supported. Please try another device.","isErrorRecoverable":true}
  12. Originally Posted by aqzs View Post
    <Response [403]>
    or :
    what if we used headers from an android browser like kiwibrowser?
        'authority': 'license.vdocipher.com',
        'accept': '/',
        'accept-language': 'ar-SA,ar;q=0.9,en-US;q=0.8,en;q=0.7',
        'sec-ch-ua': '"Not-A.Brand";v="99", "Chromium";v="124"',
        'sec-ch-ua-mobile': '?0',
        'sec-ch-ua-platform': '"Linux"',
        'sec-fetch-dest': 'empty',
        'sec-fetch-mode': 'cors',
        'sec-fetch-site': 'same-site',
        'user-agent': 'Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36',
        'vdo-sdk': 'VdoWeb/2.5.2',
  13. Member aqzs's Avatar
    Mar 2024
    Paris
    I tried with those one :
        "Content-Type": "application/json",
        "vdo-sdk": "Aegis/1.26.7",
        "User-Agent": "Dalvik/2.1.0 (Linux; U; Android 14; motorola edge 50 fusion Build/U2UUI34.40-64-1)",
        "Host": "license.vdocipher.com",
        "Connection": "Keep-Alive",
        "Accept-Encoding": "gzip",
        "Content-Length": "4716"
    Jul 2023
    India
        'accept': '/',
