In the sample video (warning, flashing image), this is head clogging, which is caused by the tapes, right? I worry that something might be damaged, as I see this drastic dropout somewhat often (although for a way shorter period), and recapturing is dropout-free.
I ask because I haven't yet seen clogging or whatever this extreme on other VCRs.
Seems like it hit a patch of something on the tape that wiped on the head. You say you played the tape again and had no problems on the same part of tape. Seems like it was just dirt of some kind and it cleaned itself fine.
Had been thinking of the same thing. Still, I hope it's not vcr's fault, but now I can have a little less worry.
It can be anything such as dust or dirt got on the tape so no permanent damage.
How to capture with no head-switching noise (certain VCRs)
By Brad in forum Capturing and VCRReplies: 11Last Post: 7th May 2026, 01:36 -
VCR output from play head while recording. Possible?
By dogenigt in forum MediaReplies: 12Last Post: 16th Aug 2025, 02:16 -
Flying erase head noise
By lordsmurf in forum RestorationReplies: 18Last Post: 24th Apr 2024, 13:58 -
Panasonic NV-HS1000 video head replacement
By golenman123 in forum RestorationReplies: 1Last Post: 24th Jun 2022, 06:54 -
Is LP VHS being read by SP head or EP head?
By digicube in forum Capturing and VCRReplies: 2Last Post: 16th Feb 2021, 16:44
