Hello!
I'm trying to capture this stream: https://3voor12.vpro.nl/artikelen/overzicht/2024/lowlands/Dit-is-het-programma-van-de-...ivestream.html
I think I've managed to get N_m3u8DL-RE to download it, but it's encrypted. Could anyone help me find the key, please?
Edit: you need to use a VPN for the Netherlands for the stream to work.
Results 1 to 9 of 9
Bugged? (fixed now)
Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
It disappeared, yes! I'm not sure why. This is what I said:
I'm trying to capture this festival stream: https://3voor12.vpro.nl/artikelen/overzicht/2024/lowlands/Dit-is-het-programma-van-de-...ivestream.html
I think I've figured out how to download it with N_m3u8DL-RE, but the stream is encrypted and I don't have a key. I was wondering if anyone could find it for me - the stream starts in about an hour!
Thank you! -
You can see a snippet of his comment if you hover over his post in the section forum. Basically he wants a key for this
@OP you should try this key
Code:8d3c85fa30730fdc39efc09de476415f:8fdccd948bb2cc6d99d5305ccffebcb7
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
With Windscribe VPN I'm getting {'message': 'Forbidden'}, with Tunnelbear and without VPN I'm getting {'status': 451, 'body': 'Dit programma mag niet bekeken worden vanaf jouw locatie.'}.
I'm able to download others content without issue weird :
Code:Enter the video url: https://3voor12.vpro.nl/speel~WO_VPRO_16961064~mura-masa-live-at-best-kept-secret-2022~.html keys: ['847e5e05555afba005aaab58418a8265:662b105c6bdb8944295407581a600123'] N_m3u8DL-RE "https://npo-nl-ams-p17-am5.cdn.streamgate.nl/TRUNCATED/vod/npo/usp/TEST/npo/dash_cenc/WO_VPRO_16961064/WO_VPRO_16961064_v1658162863.ism/stream.mpd" --save-name "Mura Masa - Live at Best Kept Secret 2022" -sv best -sa all -ss all -mt -M format=mkv --log-level OFF --key 847e5e05555afba005aaab58418a8265:662b105c6bdb8944295407581a600123
This seems to work, thank you!
I'm a newbie at this. The command line says this:
And the decrypted fragments are correctly being saved in the folder. Since this stream goes on for a long time and I only want to record one show, what should I do to cut it short? Do I just close the command window and then merge the fragments myself? Or is there an easier way? -
Add these parameters
Code:--live-pipe-mux --live-record-limit 00:02:00
Edit: for more parameters, read the help from https://github.com/nilaoda/N_m3u8DL-RE it explains all types of params--[----->+<]>.++++++++++++.---.--------.
No problem. Since you can handle N_m3u8DL-RE, you should take a look at the sticky threads to learn how to get the decryption keys yourself.
Download stream key challenge
By maxjrzv84 in forum Video Streaming DownloadingReplies: 1Last Post: 14th Aug 2023, 22:44 -
Help getting this stream WV Key
By dappaulu in forum Video Streaming DownloadingReplies: 10Last Post: 19th Jan 2023, 07:23 -
Need help finding live stream key !!!
By iconaclaster in forum Video Streaming DownloadingReplies: 2Last Post: 11th Oct 2022, 09:25 -
ACL Festival stream MPD encrypted
By dappaulu in forum Video Streaming DownloadingReplies: 1Last Post: 8th Oct 2022, 16:19 -
How can get key from stream.mpd?
By davidbdn1994 in forum Video Streaming DownloadingReplies: 4Last Post: 20th Aug 2022, 08:15
