hi there....
i've been converting avi to mpeg for a long time using TMPEG never had any problems until now...
one of the files that is in avi format when i go and try to convert to mpeg it gives me an error"cannot open or unsupported" for the audio
in the video np but there is just no sound?
why is that the case..there are total of 22 files and i had np on any of the others except for this particular avi file....
please help!!!
thanx in advance
At a guess, it is a downloaded divx file you are trying to convert. If so there is a good chance that the problem you are seeing is due to it containing an AC3 audio stream. Use BEsweet (toold, to your left) to extract and convert to stereo .wav format. Use this as the audio stream when encoding with TmpGenc.
Hope this helps
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
Help With Audio Problem please!
By heidilynn08 in forum AudioReplies: 3Last Post: 16th Dec 2010, 11:08 -
Audio problem
By Goten in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2007, 21:44
