Dear videohelp community i would like to download a video from the dutch tv broadcaster site named Kijk this is the url htpps://kijk.nl.
and i would like to download this video https://www.kijk.nl/programmas/steenrijk-straatarm/LUdwP84njCV
--note this video is only accessible from a dutch IP but you don't need to sign up
i read a few post on this forum about downloading things from kijk.nl. but i dind't not came super far.
i also tried using AI but they just say bullshit.
what i do got is the following
-pageurl=https://www.kijk.nl/programmas/steenrijk-straatarm/LUdwP84njCV
-mpdurl=https://vod-ww.prd1.talpatvcdn.nl/kijk/LUdwP84njCV/2eaa7ab5c7934addbdec56e1f8035974/ba94badf69954f2b80c8016e0ccaad3d/f04bf2ba4ada4d28b0267d65f574f32e/index.mpd?Policy=eyJTdGF0ZW1lbnQiOlt7IlJlc291cmNlI joiKjovL3ZvZC13dy5wcmQxLnRhbHBhdHZjZG4ubmwva2lqay9 MVWR3UDg0bmpDVi8yZWFhN2FiNWM3OTM0YWRkYmRlYzU2ZTFmO DAzNTk3NC9iYTk0YmFkZjY5OTU0ZjJiODBjODAxNmUwY2NhYWQ zZC9mMDRiZjJiYTRhZGE0ZDI4YjAyNjdkNjVmNTc0ZjMyZS9pb mRleC5tcGQqIiwiQ29uZGl0aW9uIjp7IkRhdGVMZXNzVGhhbiI 6eyJBV1M6RXBvY2hUaW1lIjoxNzIzNjg0NTgxfX19XX0_&Key-Pair-Id=K1QF421Y6TW7LS&Signature=X~5BCuVuWnar1Ch8AfeKDO 9q5DB0fqiUZz3uBstujCHq4tlWMftmT~e47rlotWHCk8RyewZW tryqWDgqDQC4AILdB8UPA17BEn-pkdHRlFUGjdeDOvNI0vN1Fy9sGEasdkGTC5JriCkxSN2Q9aAN8 dIrwA3uEjkD2xr4p3JmWW0LSlCakxcIMuIASOJUAgJIFjIB1Be nDw0R75m5a6yd84ZKEZDXrI1-FmPNaIYF70eJgOp~kGcmzXP6NMw1zDyhjHfsXgRpymG2k4U7e1 Uura~~L5tzHodJfVOiXTmcROwQpPe~~1bFHQ9aXcZV2uRrOYEf LzVnra2a-AGTo6v9QA__
-this url https://widevine.entitlement.theplatform.eu/wv/web/ModularDrm?releasePid=aTpJH3qa_eD7&...son&schema=1.0
i hope some people can help me with this
mpd is tokenized so i give you the download link: https://www.transfernow.net/dl/20240815I6IwXLAwCode:
--key 2a0e0745e9a151aa9a9f6625192ee09a:2e011682932f7d4343fe762b65a81e93 --key b53da634e75c5ccab281adc31aa33c15:677ccdbe15303508d50cfc136de56898 --key 1127a898e3a45ed885929d1cb31e6bd5:9ad621ddd2b7840fae2ff36bf7d6556a --key 78be4b67349752f995279c6f65d97d42:7394f620d72ebc17d43e8c9e07842a5a
Useful if you want entire series at once
Or you can try one of the key extractors from the sticky threads.Code:python widefrog.py "https://www.kijk.nl/programmas/steenrijk-straatarm/LUdwP84njCV"
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Hi thank you so much your widefrog.py code is amazing i only have one question is it possible that widefrog.py does not burn in subtitels?
"burn in subtitles" ?? I suppose you meant muxed, cause nothing is reencoded so nothing is burned. You can get rid of subtitles by removing "-ss all" from the N_m3u8DL-RE parameters from config json file and also by setting "ADDITIONAL_SUBS" to false (instead of true). Everything is configurable, just read the guide and the help commands. Also check the use cases for your particular site. It's best used for mass downloading series.
Unable download from Kijk.nl
By Redfield in forum Video Streaming DownloadingReplies: 8Last Post: 20th May 2024, 11:46 -
Downloading an HLS stream: ONLY in sync when downloading with ffmpeg. Possi
By royjeon215 in forum Video Streaming DownloadingReplies: 6Last Post: 21st Jan 2024, 03:56 -
How to get the a video from dutch broadcasting kijk.nl & rtlxlgemist.nl?
By kevin-theman in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2023, 17:56 -
Help with kijk
By pdsremy in forum Video Streaming DownloadingReplies: 2Last Post: 30th Oct 2022, 15:04 -
error downloading from kijk.nl widevine
By TopSkillGamer in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Apr 2022, 00:29
