I use AviDemux on a 4K monitor. I've resized the window to the perfect size I like to use on my computer (running Win10) so that I can have other things visible in the background or around it. Every time however I drag and drop a video, whether its 1080p or 4K, the UI automatically resizes to something bigger. I then have to grab the corner and reduce the size. Is there a way I can "lock" the UI window so that dragging and dropping any video doesn't resize the entire program window? Thanks!
Results 1 to 1 of 1
Drag and Drop Tool
By Mr. Fanservice in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2024, 00:15 -
PotPlayer prevent video file from changing window size
By LAMBDA471 in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2022, 14:48 -
web address drag and drop no longer works, why is it?
By sommers in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2020, 12:13 -
PotPlayer - How to disable drag & drop choices? I want always to play now
By vlad992 in forum Newbie / General discussionsReplies: 3Last Post: 1st Feb 2020, 20:54 -
Windows, UAC, Firefox, drag-and-drop, and related issues
By abolibibelot in forum ComputerReplies: 7Last Post: 16th Jan 2020, 16:48
