Hi, where does the halo effect come from? I got a bunch of old vhs tapes from a friend which all have halo effects.
Is there a way to reduce or remove this ugly fault? Use a better vhs machine?
Thanks for help!
Best to do a quick lossless capture of 15 seconds or so and attach here so the experts can take a look. Max attachments 500mb.
1- use a high-end S-VHS VCR (basic VCRs tend to highlight edges for “better” playback)
2- disable all sharpening features in this VCR, and preferably use “edit” mode
3- disable all sharpening features in the capture card
4- sometimes the halos are baked in the video master (I found all my recordings of Thunderbirds series suffering of excessive halos in the source) -
Because of VHS's inherently low resolution most players apply a sharpening filter during playback. The result is oversharpening halos.
If these are first generation VHS recordings you can just use a player that doesn't apply the sharpening (some have a "sharpness" setting which you can turn down or off). If these are multigeneration tapes the halos are probably burned in. Removing them can be done with AviSynth but that doesn't work as well as avoiding them in the first place. -
Some info here https://gleitz-info.translate.goog/forum/index.php?thread/48526-%C3%BCbersicht-%C3%BCb..._x_tr_pto=wapp and here https://www.digitalfaq.com/forum/video-restore/1567-vcr-buying-guide.html
In general a single VCR being best for all purposes does not exist, and for optimal results you may need different machines for different tapes.
Halo/ring effect around objects in video frames
By SVAPrjm in forum Video ConversionReplies: 47Last Post: 30th Jul 2024, 14:48 -
Making SD music videos or found footage movies.. VHS, Super VHS or Hi8?
By part12studios in forum Newbie / General discussionsReplies: 0Last Post: 10th Aug 2021, 09:57 -
VHS Halo Reduction Help
By Dry Paint Dealer Undr in forum RestorationReplies: 0Last Post: 28th Jul 2021, 13:16 -
VHS/CRT video effect question
By farabundo in forum EditingReplies: 2Last Post: 8th May 2021, 03:28 -
Vertical rainbow effect when capturing some vhs tapes.
By C3PU in forum Capturing and VCRReplies: 1Last Post: 28th Jul 2020, 11:52
