LTO tape or MDisc Blu-ray + drive are expensive, what is the best media option for long-term archiving in cold storage without power?
Results 1 to 17 of 17
You can't afford it so why ask?
follow 3 2 1 backup and verify data every 3 years, when you detect failures you move to another format.make video everyday -
Usb flash drive,they are cheap and reliable when you get a good brand.
This is the answer, but you don't have to follow a set yearly regimen and definitely don't wait until you see a failure. Continually check, verify and copy to new devices/media
For price per TB, hard drives nearly universally worldwide, are the lowest cost per TB.
For longevity, only LTO (LTO tape is redundant, LTO = Linear Tape Open) has proven longevity of up to 30 years in proper storage. Newer drives such as LTO-8/9 are extremely expensive in the mid $$$$ range, but older drives are much lower, typically in the mid $$$ range used. LTO 5/6 is the current sweet spot for tradeoff between capacity, 1.5TB/3TB raw capacity* for LTO-5 and LTO-6. Tape cost per TB is roughly the same at $7-10 USD for used tapes. Rumors are LTO-10 may be released this year, which will lower LTO-8/9 drive prices, but it will be years before low $$$$ prices, if ever will be seen.
*Never rely on the advertised compressed capacity size. This will almost never be reached with anything but very heavy text only files. -
i see no reason to use such expensive solutions like lto or mtape + cold storage in normal situations.
that type of tech is really meant for extreme use, such as top secret data used by government agencies or similar uses.
for home use usb thumb drives as already stated or sdhc is fine for some people, though i much prefer the small laptop spinning rust hard drive.
my most important data is encrypted using pgp or gpg and backed up to one of those laptop drives, as well as uploaded to google drive and to a remote server i rent.
your really need to assess how important the data you want to archive is.
is it the birth of a child or some similar event that is irreplaceable? then a reliable physical backup + off site backup is called for.
is it porn, or some similar content? then a backup is questionable. -
M-Disc is a brand name, and they sell discs to newbie suckers that don't know any better. M-Disc is not, and has never been, the best blank optical media. It's mediocre at best, and poorly supported by most optical drives (both reading and writing).
Blu-ray is an inverted CD-R in construction. The lower polycarb layer is super thin, easy to damage, easy to lose data. The "solution" to this was the put goo on the bottom layer, but that didn't help much. HD-DVD was a vastly superior format, and it sucks that they lost this pathetic "format war". The movies long ago moved to streaming, and for archival optical data we're left with only DVD-R (and some DVD+R, and preferably single-layer for both).
"Cold" storage is often a bad idea due to humidity. The humidity content for truly "cold" film storage is vastly different for magnetic and optical media.
^ This.
^ This.
I have data on HDD, SSD, and optical. But costs and time matters. So most data goes to HDD, important + fast access needed (to get back up and running) to SSD, and "I never ever want to lose this" to optical stored in multiple locations. For that last one, mostly select photos, certain personal documents, a few rare DVD-Video movies, some rarer media (music, artwork, digital comics, etc).
BTW, I'd bet money this is gamemaniaco again.
Are all of your posts at this site going to be whinging about what stuff costs?
Projecting? You've said this same thing in other posts.
Hint: This is a video site, and video projects take tons of space. Some of us choose to backup our work files, not delete it. That's the difference between "video for work" and "video for play".
What a ridiculous statement.
people are creatures of habit and they have a view point that manifests itself in the advice they give to others.
i always consider the monetary cost of doing something, it's who i am and it comes out in the advice i give to people.
you, and one other, are self appointed experts on everything, know-it-alls that don't quite know even a fraction of what they think they do, that are self important dicks.
this manifests itself in the responses you give, which are full of contradictory viewpoints and disparaging remarks to anyone that you disagree with.
i do not understand why it is that this site's moderators have tolerated your, and that other person's. behavior for this long. -
You don't consider negative economics, aka "buy cheap, buy twice".
Such as?full of contradictory viewpoints
This is amusing. For starters, I never refer to myself as an "expert". I just know what I know (and don't what I don't).
For this exact topics, for example, I have literally signed NDAs with optical media companies, in order to share information with them, and they with me. In the 2000s into 2010s (stopped due to health decline + media phased out, heavy industry M&A), I conducted optical media experiments, with special attention paid to longevity (as it was still not mature). Datarius was nice and all, but it wasn't real-world, and the media companies did not do it. This is why manufacturer testing was largely bunk.
When it comes to physical media, it's all aged/obsolete/outdated. Everything is about streaming now. So discussions on capture hardware, optical media storage, etc -- it's all known knowns now. Here, for this topic, we (mostly referring to me/others here, clearly not you) know how the media is constructed, the longevity, humidity concerns, materials, costs, patents, etc.
So this is like a 10-year-old telling the teacher he doesn't know anything.
In summary, to this topic here:
- M-Disc is a joke, pure marketing
- never "cold" optical or magnetic media -- store only within recommended specs
- LTO has lots of negatives, in terms of convenience and costs -- HDD is better for almost all individualsWant my help? Ask here! (not via PM!)
For long-term archiving data, is best an Orico enclosure case + 500GB 2.5" HDD or is best SSD drive? what is more reliable?
LTO and MDisc blurau is very expensive -
best are HDD - to increase probability to not lost data you need to use few of them with same data - redundancy greatly increase longevity
I wouldn't put regular hdd in cold places,it screws up the mechanics if too cold.
patrion87 = gamemaniaco
"Programmers are human-shaped machines that transform alcohol into bugs." -
Yay! Gamie! Every time he repeats himself we all do a shot.
only 3.5" HDDs are better than SSDs for long term archiving? Are 2.5" HDDs + case usb 3.0 not superior to SSDs for archiving?
The most important thing is to try to avoid extreme changes in humidity levels. Easier said than done, I know.
is there a standard created by someone for archiving of still images?
By oduodui in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2022, 13:31 -
What to with discs & cases after archiving
By LilBro3 in forum DVD RippingReplies: 0Last Post: 12th Mar 2022, 19:09 -
Archiving VHS Tapes to digital
By FelipeArchives in forum Capturing and VCRReplies: 4Last Post: 13th Jun 2021, 17:25 -
Archiving
By JonathanG in forum Video ConversionReplies: 8Last Post: 10th Jan 2020, 05:44 -
Reboot at cold boot
By kyrcy in forum ComputerReplies: 25Last Post: 25th Sep 2019, 14:14
