I would like to be able to show the entire file name but am having issues with longer Anime TV Shows sometimes things have multiple seasons and the show title is so long the file name is difficult to make out.
I am using a free TV Show renamer program for the renaming but the file names are sometimes out of place when somethings don't download correctly. Example:
If I try to download a anime with a name that is to long and I am downloading several episodes at once and a episode dose not start downloading right away the episodes are in the wrong order.
So is there a way to download with Video Downloadhelper and use some kind of settings to change the file naming length.
	I had to use the older version in UI to make this work but so not to bad. The only thing I don't like is how I need to click the icon and then select the download thing just to get the downloads started. I really wish I could have stuck with the newer version so I could use hotkeys to activate the download. I will do some more tinkering to see what I can do with the newer version though. But so far at least the naming is better.
  Video Downloadhelper Question About Always Showing Downloads?By DrPepper88 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Jan 2024, 12:51
  video & audio out of sync - Video DownloadHelper & vimeo videosBy sparkles in forum Video Streaming DownloadingReplies: 10Last Post: 5th Aug 2023, 12:32
  download directory of "Video Downloadhelper" in FirefoxBy blanc in forum Video Streaming DownloadingReplies: 7Last Post: 27th Dec 2022, 19:32
  Basic instructions on use of Video DownloadhelperBy plecenik in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2022, 01:43
  Renaming video files using a text list.By sambat in forum Newbie / General discussionsReplies: 11Last Post: 10th May 2021, 11:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
