I am a newbie... I want to to have chapters on my vcd so I think (fron info from this website) that i need to do that with Vcd easy and burn it trhough it. But it doesnt read my cd-rw layer.....Its a samsung and seems to be supported. Anyway I downloaded like it explains on the sefy's page the aspi to solve this problem...it still hasnt solve it..it can't read my cd-rwburner Any ideas on how to solve this?![]()
Results 1 to 9 of 9
try to download the forceASPI file.
run a google searcf for forceASPI and download it into your current aspi folder, may or may not work though.... -
You don't need to use ForceASPI anymore (though it will work just fine).
Adapatec now releases their ASPI layer as a download for free: http://www.vcdhelp.com/tools.htm
Regards.Michael Tam
w: Morsels of Evidence -
for NO reason! do NOT use the latest v4.7 ASPI that Adaptec released! ask anyone who used it for anything, it causes troubles!, stick to 4.6, you can download an installation from the homepage of CladDVD.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I'm curious as to what problems have been described Sefy?
I myself actually just used ForceASPI on my WinXP installations with no problems (I already had it around).
Regards.Michael Tam
Also I already had troubles using the latest ASPI (v.4.70) of Adaptec. If you're using the aspichk-tool of the v.4.60 aspi-drivers, you would see there are both 4.70 and 4.60 files installed.
In some cases this would lead to troubles, in others it would work fine.
Therefore better install ASPI 4.60 - As it seems, there are many utils to hack the ASPI to force to install; even if no scsi is initialy installed.
Anyway, if you can get ASPI 4.60 installed at you windows system (for all win-versions), you won't get any problems with for instance cdrDao ever. -
vitualis, well, as you know me, I like experimenting with everything, so when those 4.7 came out, I tried them, at first it doesn't seem to have problems, but then I suddently started having buffer under run problems, i've lost 2 CD's, and before you tell me it might be my system, i'll tell you this, i've not lost a single CD before that incident, I immediatly removed and reinstalled the 4.6 and i've not had troubles since.
But if you don't take my words for it, I think I can find a few emails left from people who told me they were having problems as well since installing 4.7 and going back to 4.6 solved their problems.
You can also see on CladDVD's homepage that the author himself said those drivers were the buggiest piece of software he saw.Email me for faster replies!
Best Regards,
Sefy Levy,
Hey Sefy, I believe you!
I just hadn't bothered "updating" to the newer version yet and was wondering what problems people have had.
It seems like ForceASPI is still the way to go...
Regards.Michael Tam
Actually you can get a better installer for the 4.6 Build 1021, you can find it on the CladDVD homepage in the latest downloads section.
Best Regards,
Sefy Levy,
Easy way to find commercial breaks?
By lj01 in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2008, 13:16 -
VCD movies - I can't find a ripper!
By robsamui in forum Video ConversionReplies: 10Last Post: 18th Mar 2008, 07:20 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43 -
Is there an easy way to find out how wide the black border is?
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 22:26 -
EASY DvD to Divx Ultra (with chapters)
By daisbrown0722 in forum DVD RippingReplies: 3Last Post: 16th Aug 2007, 20:26
