hi there,
as already talking here https://forum.videohelp.com/threads/415090-All-Hell-Let-Loose!/page5#post2746210
i would like to understand better if this works for you or not. i talk about window user, special for win 11 OS, maybe for linux work fine without error
i want to delve deeper because this also interests me for other things i do in windows. I preferred to open a new specific thread because maybe some of you are not interested in the Angela thread (or hell3.py script)
I have already found a solution, simple and easy solution, which is to bring the multiline command onto a single line: in this way with copy and paste in the terminal (or powershell because the error is on both) in this case there is no error and the command executes successfully.
so, question is: this behavior only happen to me? am i doing something wrong or is it really the cmd windows terminal? It seems incredible that it doesn't accept a multiline command and i can't find nothing on options that can solve this issue (and the same goes for powershell which should be more advanced). How do you do it in a similar case, with a multiline command ?
Results 1 to 1 of 1
To delete empty lines and lines with music symbols in subtitle edit at once
By Pusat in forum SubtitleReplies: 2Last Post: 9th May 2023, 11:20 -
Subtitle Edit command lines for multiple GUI operations
By pascor in forum SubtitleReplies: 3Last Post: 9th Apr 2023, 11:51 -
Thermal paste
By BlurayHD in forum Newbie / General discussionsReplies: 17Last Post: 17th Nov 2020, 14:48 -
Anyone know of a sub program that will break long lines into 3 lines?
By JeremyBrown in forum SubtitleReplies: 19Last Post: 13th Apr 2020, 18:03 -
Hot to move lines to next lines time?
By tevastevas in forum SubtitleReplies: 1Last Post: 23rd Aug 2019, 01:34
