Hi there, I haven't used this unit for years and today tried playing a DVD. It will not 'load' any DVD or CD disc.
It keeps on trying and I hear the motor speeding up then slowing down, repeating continuously.
I have run a lens cleaner CD a couple of times with no improvement.
Q. Is it just old and passed it's best by date.?
Q. IF it was working!! would I be able to record ONLY AUDIO in through the front RCA (input3) input onto a DVD-R disc (in LPCM format).??
cheers for any ideas and feedback... CD
I have Pioneer DVR-540H and I am guessing same models with slightly different features.
I haven't used it for many years but few weeks ago I needed to finalize several DVR-RW and only the original recorder would be able to finalize. Luckily everything worked as they did last time.
The first thing I would do is to try is to check the firmware software version maybe it is corrupted?
Contact Pioneer they might have the latest firmware for this model and install it according to their instructions.
In your case it could also be a problem with the DVD drive (most probably IDE not SATA). Not sure if you can replace it with exactly the same model because the firmware expects to see the original drive, but this might be worth a try.
The H means it has HDD inside. Have you tried recording to the HDD instead of the DVD disc?
If the DVD drive prevents you from doing this then you can just cut off it's power.
The problem with this option is how to get the recoding out of the box?
I remember few posts about another Pioneer DVR. Check the forum posts.
As to your question recording only audio. I remember I needed to record audio only from a tape cassette, but succeeded only when I had a video signal from a source like a satellite TV channel.
I am sure there are easier ways today to record audio only than going this route. -
Hi there and thanks for the prompt and full reply.
I am able to record with the HDD (though as you suggest I will need a video source) so I doubt I will continue down this path, thought it was a "quick" way to get my vinyl digitised. As you say there are many alternatives these days.
If I take a look inside later, I'll get back here.
Thanks again CD
Pioneer GGV 1305 Service Disc, Compatible with Pioneer DVR-560H?
By Big Al in forum DVD & Blu-ray RecordersReplies: 29Last Post: 1st Apr 2025, 06:51 -
Help Toshiba Dvd recorder clicking loading problem d-r400 dr430 dvr
By adam2514 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 13th Mar 2024, 15:42 -
Pioneer DVR-520 and DVR-560 functionality discussion
By jcool in forum DVD & Blu-ray RecordersReplies: 142Last Post: 17th Aug 2021, 19:45 -
Pioneer DVR-520H video to PC using the DV-Out port - no disc burning.
By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th May 2021, 14:26 -
Pioneer DVR-510H-S GGV1179 data disc download
By viperss in forum DVD & Blu-ray RecordersReplies: 31Last Post: 30th Mar 2021, 08:57
